Old 02-06-2003, 09:57 AM   #6046
kevink2's Avatar
Default Re: Re: Re: Head Temp
Originally posted by Bounty Hunter
Sure man! I trust you with my bodies, I may as well with my car! Hehe! Not a problem Kev. I read that you will be at Rev later on today. I will be there for the night session! See ya there!
Cooolio! Hope to see ya there...
kevink2 is offline   Reply With Quote
Old 02-06-2003, 09:58 AM   #6047
kevink2's Avatar
Originally posted by AMGRacer
I dont want to tell you something you already know but another thing which helps engine temps on these big tracks is to add in some additional caster oil into the fuel. Mayby another 2-5% will lower temps.
Thanks AMG...
Old 02-06-2003, 11:49 AM   #6048
rskoncepts's Avatar
Trader Rating: 21 (100%+)
Originally posted by kevink2
Nah not yet. Rev's only got one big sweeper and the rest of the turns are mostly hairpins, so I'm not sure how much it'd help there. It's tempting though...
However, I've got the full Mugen mod now, (i.e., the whole car, and will be trying it out hopefully tomorrow night.) I've already driven my friend's, and liked what I felt. Can't wait.
Kevin, I'm on a similar track but I get push when I use a little throttle on the sweeper. What's your full setup? Thanks!
rskoncepts is offline   Reply With Quote
Old 02-06-2003, 03:32 PM   #6049
kevink2's Avatar
Similar track? In Honolulu? Aay, where's dat brah? You talking to one forma island boy (well almost, move to Calif. when I was three!). All my relatives are there though, so I'd like to find out where you guys are driving...
Don' t know if I want to publicly post my setup (highly secret, have to kill ya' if I told you, etc.) . j/k I'll PM you with details when I get a chance.
Old 02-06-2003, 04:12 PM   #6050
rskoncepts's Avatar
We're running at the HCC Aeronautical School parking lot down Lagoon Drive. I'll send some pictures if you want. As far as the setup, I'm just trying to find a starting point. Have my rubber tire car running okay but trying to get back to the foam car. Thanks Kevin!
Old 02-06-2003, 04:29 PM   #6051
AMGRacer's Avatar
Woah nice track!
For what it is worth here is what I am using on a similar track to that one.
Front:
Oneway diff
4mm ride height
1mm droop
Swaybar 75%-100% stiff (depending on how many sweepers and how long)
Yellow or Red fantom springs
50-70wt oil (depending on how many sweepers and how long)
Fantom piston
11 pitch servo saver
2 degrees camber (change to suit tire wear)
1-1.5' toe out
10-14 degree caster (more caster for more high speed corners)
GRP Powers to suit, i usually run 40shore on my track
Rear:
Kyosho LSD with 10K oil
4mm ride height
6mm droop
Gold springs
Black/Gold swaybar
Mugen MTX3 conversion
2' toe in
3' camber
lower inner hole, 3mm of shims on outer hub
GRP Powers to suit, i usually run 40shore 30mm on my track
Motor:
JP RS12 S1 with novarossi outlaw inline pipe
Clutch:
Mugen centax, .3mm endfloat and 1.7mm on adjuster nut with lighten flyweights and grey clutch shoe
Gearing:
With my motor/pipe on that track probably 17/21 with 48/44
Other:
Stratus body with 5th body post
K factory tank
Graphite top deck
5 cell AAA hump pack lowered 4mm
AMGRacer is offline   Reply With Quote
Old 02-06-2003, 04:33 PM   #6052
AMGRacer's Avatar
The above setup comes from 18 months of experimentation and a HECK of a lot of track testing. It is not too different to the setup used by Ito at the Hong Kong race which was a lower traction carpark style track.
Old 02-06-2003, 04:58 PM   #6053
rskoncepts's Avatar
Thanks AMGRacer. I'll try your settings and see what happens. We race twice a month so it's hard to test. Our track is on the tighter sided but it's fun. Come over some time.
Old 02-06-2003, 05:02 PM   #6054
performula's Avatar
What consists of an MTX3 rear conversion? Never heard of it.
performula is offline   Reply With Quote
Old 02-06-2003, 05:06 PM   #6055
rskoncepts's Avatar
AMGRacer, what is the 5th body post and what difference is the Fantom pistons? What is your rear shock oil and I'm assuming you vary the front from 50-70?
performula, AMGRacer starts talking about the MTX3 mod from page 185 I think. Check it out.
Old 02-06-2003, 06:04 PM   #6056
AMGRacer's Avatar
The 5th body post is installed in front of the steering servo:
Fantom pistons are the pistons used in the Fantom Evolution the latest car. They have different sized holes in them.
Old 02-06-2003, 09:34 PM   #6057
RClover's Avatar
Default solid rear setup
well, i managed to test the solid rear setup but i was not able to keep pace with another RR (Rear LSD, rubber tyre).
My car tends to spin when exiting corner if i give it full gas. Overall, compared to 100K rear diff which i had been running, the car feels lot more responsive in steering but the solid rear make the rear end spin if i get on the gas too soon...Its a medium size technical track
Here's my setup:
Front Geometry:
Shock Spring - 5Star Pink
Shock Oil - 80wt
No Shock Tower used
Downstop - -1
Toe - 1
Camber - 2
Castor - one thin behind upper a-arm
Anti Roll - softest
Front One-way
Ride Height - 5
Tyre - 40 shore
Track Width - 198mm
Rear Geometry:
Shock Spring - Kyosho Orange
Shock Oil - 25wt
Shock Mounted on the lowest hole (5star Shock tower)
Downstop - 3mm
Toe - 2.5
Camber - 4
Sway Bar - black
Ride Height - 6mm
Rear Diff - solid
Tyre - 40 shore
Track Width - 200mm
Appreciate helps.
RClover is offline   Reply With Quote
Old 02-06-2003, 10:19 PM   #6058
InitialD's Avatar
Default Re: solid rear setup
RClover, throttle control is the key word. It requires different style of driving. As for your steering problems, you need to setup the car for more steering when with a solid axle rear.
Old 02-07-2003, 07:26 AM   #6059
NitroNut's Avatar
Quick question my tr engine the one place where u put the tubing in for the fuel, it's pointing towards my heatsink and so how would i reposition it out the other side?
NitroNut is offline   Reply With Quote
Old 02-07-2003, 07:35 AM   #6060
university_dave's Avatar
The top-end needle should have a hex-shaped milling just above the fuel inlet. Losen this off then you can move the inlet around. Once you've found the ideal angle then simply tighten it back up again.
university_dave is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
