Old 01-27-2003, 09:06 AM   #5956
nova racer's Avatar
here is a link for the fantom update kit
http://www2.towerhobbies.com/cgi-bin...?&I=LXALW2&P=7
nova racer is offline   Reply With Quote
Old 01-27-2003, 04:06 PM   #5957
AMGRacer's Avatar
Originally posted by nova racer
I think that they will up date it just like they did the fantom.
Hey i got a question will the fantom hubs bolt on the v1r look at the fantom evolution they did the mtx3 hub mod and the front bulk head has the hinge pins 1mm lower to lower the roll center. I will let you guys in on somthing lol the reflex front bulk heads have the hinge pin location 1mm lower than the v1r bulk head. I only know this because i picked up some v1 bulk heads in case i break 1 on my reflex
They wont fit, far too big.
AMGRacer is offline   Reply With Quote
Old 01-27-2003, 04:19 PM   #5958
NitroNut's Avatar
Are the diff fluid that came wit the v1r good? or should i get diff ones.
NitroNut is offline   Reply With Quote
Old 01-27-2003, 04:31 PM   #5959
AMGRacer's Avatar
They are a good starting point. You need to run it on your track first and see how it feels to you then change from there.
Old 01-28-2003, 04:31 AM   #5960
nova racer's Avatar
crap
Old 01-28-2003, 03:46 PM   #5961
AMGRacer's Avatar
crap
You should just use the Mugen parts for now. They fit perfect and are cheap.
Old 01-28-2003, 06:12 PM   #5962
NitroNut's Avatar
Would u recommend putting universals in the front or the rear or both?
Old 01-28-2003, 06:17 PM   #5963
NitroNut's Avatar
Old 01-28-2003, 06:18 PM   #5964
NitroNut's Avatar
Ne one help
Old 01-28-2003, 11:29 PM   #5965
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
Fronts for sure, the rear doesnt have stearing so I feal it isnt worth the extra coin
HEYALIGNMENTGUY is offline   Reply With Quote
Old 01-28-2003, 11:30 PM   #5966
Ne one help
I try
Old 01-29-2003, 12:04 AM   #5967
AMGRacer's Avatar
CVDs do two things. They work more efficiently when the cvd bone is on an angle compared to the axle and they reduce one pin end fitting to slightly reduce drivetrain slop.
In the case of the first point it is mainly useful on the steering since only the steering gets significant angles on it like HAG said. However remember that the friction between the axle and dogbone when subjected to an angle actually has two effects on the suspension itself. When a dogbone is working on an axle at an angle it produces friction, this friction robs drivetrain power but ALSO binds the suspension as it is trying to work. Ie a dogbone at an angle under power will make your suspension stiffer. Also when a dogbone is raked forwards in relation to an axle the friction between the dogbone and axle produce a downwards and rearwards force which actually improves rear traction.
In the case of the second point the slop reduction will make the drivetrain smoother if both CVDs are used and there will be a marginal improvement in acceleration and braking response and smoothness.
Old 01-29-2003, 07:30 AM   #5968
nova racer's Avatar
OK when i seen this pic my pulse stoped and i eyes bugged out my head and i think i got a bit turned on lol http://www.teammagic.com.tw/index.htm
Old 01-29-2003, 08:02 AM   #5969
NitroNut's Avatar
Old 01-29-2003, 10:00 AM   #5970
kevink2's Avatar
Whoa, receiver and all servos on lower deck.... trippy looking tank! Looks good on "paper"... but don't know about K Factory quality.
kevink2 is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
