Old 01-24-2003, 01:12 AM   #5941
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: Re: Re: Re: Re: Re: Re: Manti...your setup pls..
Originally posted by RClover
my solid axle is on the way. hope i will like the handling and find a good setup for my 1st ever race after lunar new year. There is a new track near where i live, approx 38km away. A permanent parking lot converted track about 120ft x 35ft.
I tested out there yesterday and found the track is to be medium-high traction. Overall the handling is much predictable now than another temporary parking lot track that i used to play. Tyre wear now is much reasonable and i will try out 40/ 42 shores.
But one thing i noticed though is that the car seemed drifting quite a bit when i powered through the corner. Drifting effect means more tyre wear? the car run wide if i powered too hard through the corner... How should i correct this?
Thanks Manti and guys...
the cause of this is mainly due to not enough rear camber and incorrect tire used.
What rear camber you ran on your V1RR?
Manticore is offline   Reply With Quote
Old 01-24-2003, 06:17 AM   #5942
RClover's Avatar
Default Re: setup...
well, i run -4 on the rear and 35 shores. Downstop is 4mm.
Also, does your clutch bell spins backwards when idling/stationary?
RClover is offline   Reply With Quote
Old 01-24-2003, 06:23 AM   #5943
Manticore's Avatar
Default Re: Re: setup...
give more then 4 and see how it goes! some people run at 5'
that's the only direction the bell/spur may spin when the car sits still ! AMGracer is correct.
Old 01-24-2003, 09:47 AM   #5944
RClover's Avatar
Default Re: Re: Re: setup...
will do more testing tomorrow.
thanks for confirming on the clutch bell issue...
i know AMG's answer is correct but still i was too worried about it and therefore was looking more people to comfort me a little...
Thanks again manti and AMGracer.
Old 01-24-2003, 02:48 PM   #5945
patelladragger's Avatar
Send a message via AIM to patelladragger
Originally posted by AMGRacer
The advantages of living in the asia region
Come'on man! Quit being coy and tell me where you got that engine! I haven't seen it anywhere for less than well over 3 hun.
patelladragger is offline   Reply With Quote
Old 01-25-2003, 11:23 AM   #5946
NitroNut's Avatar
NitroNut is offline   Reply With Quote
Old 01-25-2003, 09:46 PM   #5947
asd
Send a message via ICQ to asd
WOW, i ahvent been on da forum for some time now, lol. well, my V1RR is sleepin under my bed rite now,
asd is offline   Reply With Quote
Old 01-25-2003, 10:34 PM   #5948
AMGRacer's Avatar
No big secret! It comes from my supplier of everything to do with RC. Harmony Models in Hong Kong. There are contact details and a website in the Hong King forum under online shops.
http://www.rctech.net/forum/showthre...threadid=12146
AMGRacer is offline   Reply With Quote
Old 01-25-2003, 11:08 PM   #5949
Data's Avatar
Originally posted by asd
Poles? Poles? Poles, are meant to be danced on by naked women
wonder where you had been lately, bet you have a box full of dollar bills under your bed too.
Data is offline   Reply With Quote
Old 01-26-2003, 08:47 AM   #5950
RClover's Avatar
i had done some testing today and the car handling had improved overall. I was running 35 shore Front and 37 shore Rear, rear camber was set to -4 and at the end of 1 hr run, i took the camber angle and it was -5. The left rear tyre was not cone shape but a rather balanced surface both inner and outer diameter (the Right Rear tyre was a normal cone shape). I supposed this is due to the aggressive left turns after the long straight.
I was wondering if by changing to MTX-3 rear hub would correct this problem?
Old 01-26-2003, 10:13 AM   #5951
DCR1TWO's Avatar
If you have a sweeper at the end of the straight, the outside tires will generally wear more. I usually rotate tires left to right after every tank to get even wear.
DCR1TWO is offline   Reply With Quote
Old 01-26-2003, 10:23 AM   #5952
Thumbs up
thanks - their site isn't english but I'm assuming emails can do the trick.
Old 01-26-2003, 10:06 PM   #5953
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
Tried the Mod today, seemed to be verry stable in the sweeper, but the track was not prepped so its hard to say, how it will be when the track is really tacky, but I did have my rear diff loose all its fluid, looks like I missed a spot with the lock tight
HEYALIGNMENTGUY is offline   Reply With Quote
Old 01-27-2003, 04:08 AM   #5954
Send a message via ICQ to rbgti
Default VONER REPLACEMENT?
Anyone know if and when they will be producing a replacement for the V-one series cars? Feels about time, all the other companies are releasing new cars.
The local V-one R guru here is trying to get me into a MTX-3, but I figure I'll wait for some news from Kyosho. I prolly hang on to my R for another year.
Anybody know? And where can I find out about this? (Kyosho websites are awfull)
rbgti is offline   Reply With Quote
Old 01-27-2003, 09:04 AM   #5955
nova racer's Avatar
I think that they will up date it just like they did the fantom.
Hey i got a question will the fantom hubs bolt on the v1r look at the fantom evolution they did the mtx3 hub mod and the front bulk head has the hinge pins 1mm lower to lower the roll center. I will let you guys in on somthing lol the reflex front bulk heads have the hinge pin location 1mm lower than the v1r bulk head. I only know this because i picked up some v1 bulk heads in case i break 1 on my reflex
nova racer is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
