Old 01-09-2003, 10:16 PM   #5761
Originally posted by AMGRacer
I dont use them!! Kyosho does not include them
But aren't you converting to a Mugen rear end?
The K car has one side of the adjuser nut concaved to form to the pivotball. I don't think the Mugen adjuster nut is curved enough to run without the pad.
Sydewynder is offline   Reply With Quote
Old 01-09-2003, 10:27 PM   #5762
AMGRacer's Avatar
Really? Well I got it all in there without them so far. I will see how they go and get the pads if it looks like it is gonna be a problem.
AMGRacer is offline   Reply With Quote
Old 01-09-2003, 10:43 PM   #5763
It'll all fit without the pad. Does the nut look like it's sunken deep into the upright?
Old 01-09-2003, 11:44 PM   #5764
AMGRacer's Avatar
Yep sure does.
Old 01-10-2003, 12:02 AM   #5765
Yep sure does.
Well then you might want to look into getting the pads before you put in the adjuster nuts. You might want to compare the K car and the Mugen ones to see what I'm talking about the concavity on the nuts.
Old 01-10-2003, 01:16 AM   #5766
Manticore's Avatar
R/C Tech Charter Subscriber
i dont have that problem !! i use delrin adjusting nuts !!
Manticore is offline   Reply With Quote
Old 01-10-2003, 02:10 AM   #5767
sparksy's Avatar
Trader Rating: 14 (94%+)
I think AMG will be ok, it stands to reason that with all his kyosho spares, he would have used the kyosho retainers. And if there is a problem, the mugen dealer trackside should be able to fix him up....
sparksy is offline   Reply With Quote
Old 01-10-2003, 11:10 AM   #5768
popsracer's Avatar
Default Please explain the "Mugen" mod
Guys;
I've been watching your discussion of the "Mugen" Mod to the V1R(R) and am curious. What are the benefits gained by doing all of this?
popsracer is offline   Reply With Quote
Old 01-10-2003, 05:08 PM   #5769
Robo's Avatar
Default V one RR set-up
Hey guys what shock oils do you use? I'm thinking of going to 80wt for a high traction/high tyre wear car park track.
Also any ideas on camber, toe, caster, etc?
Here's a pic of the track:
For the big straight I've so far set the car to:
1.5 degrees toe-in front
2 degrees toe-in rear
-2 degrees camber all round
10 degrees caster
Thats my basic set-up, any ideas on whether a rear stabiliser is needed, and as for shock oil, 80wt sound about right? I would go with 70wt but I dont have any as of yet, I only have Integy 50, 60 and 80 wt......
Thanks.
Robo is offline   Reply With Quote
Old 01-10-2003, 05:42 PM   #5770
popsracer's Avatar
Default Your racetrack
Robo;
I REALLY like the corners on that racetrack. Do you know how they are built? Would like to be able to duplicate out here for our track.
Thanks,
Old 01-10-2003, 07:52 PM   #5771
Robo's Avatar
Hey, I love your Speed Racer avatar hehehehe.
Here is a diagram of the track layout:
Old 01-10-2003, 07:53 PM   #5772
Robo's Avatar
The track is mostly 100mm pvc pipe cut in half with plywood ripple strips on corners.
I haven't raced there yet, I am next weekend though with my V1RR
Old 01-10-2003, 07:54 PM   #5773
Robo's Avatar
BTW:- The cars go clockwise on the track.
Old 01-10-2003, 08:01 PM   #5774
Robo's Avatar
Default Springs
What springs do you guys use other than Kyosho?
I tried getting Kyosho front gold springs for the V1RR but my hobby store (RMS for you Australian guys) are out of stock
Old 01-10-2003, 08:02 PM   #5775
sparksy's Avatar
Default Re: Please explain the "Mugen" mod
Originally posted by popsracer
Guys;
It alters the rear roll center, and allows greater adjustment. So the rear end can roll less in the corner.
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
