Old 01-04-2003, 08:02 PM   #5686
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by Taylor-Racing
I spent some time on a friend's lathe yesterday - made a nice alloy brake disk carrier to replace the one that my driver . . er . . . lost. I didn't like the large K Factory one and some have had trouble with the grub screw coming loose.
spend a little more time with the grup screw instead of cross pin. it worths the effort.
Manticore is offline   Reply With Quote
Old 01-04-2003, 08:18 PM   #5687
Taylor-Racing's Avatar
Hmmm, your pic shows a disk carrier pretty much like the one I made.
The K Factory one I saw at the LHS also included an alloy pulley.
It appears that the position of your grub screw doesn't utilise the 2mm pin hole as it is further along the shaft, yeah?
It would be easier to drill and tap a thread for a grup screw than mill the slot for a pin. I guess just grinding a flat for the grub screw should work OK.
Your pic shows a 4mm grub screw by the looks of it, yeah?
Taylor-Racing is offline   Reply With Quote
Old 01-04-2003, 08:20 PM   #5688
Manticore's Avatar
the adaptor is a 3racing one which made for cross pin. and I modifast it to make it grub screw mounted.
yes, make a flat spot on the shaft and it is a 4mm screw
Old 01-04-2003, 08:31 PM   #5689
"modifast"
Thanks, Manti. I'll finish that carrier this afternoon.
Old 01-04-2003, 08:35 PM   #5690
Manticore's Avatar
"modifast"
need to be specific. some people does modislow !
Old 01-04-2003, 08:43 PM   #5691
Ohhh . . . you mean all those people STILL using the standard rear end.
Old 01-04-2003, 09:36 PM   #5692
dtm
dtm's Avatar
Send a message via ICQ to dtm
Originally posted by AMGRacer
I will sure be funny when we all turn up at the track with Mugen rear ends
Well, I use to run an MTX2 with an RR backend....so I guess its logical that you should run the RR with an MTX3 backend!!
dtm is offline   Reply With Quote
Old 01-04-2003, 11:22 PM   #5693
Manticore's Avatar
this is evolution !!
Old 01-04-2003, 11:53 PM   #5694
Data's Avatar
more like genetic engineering to me, Dr. Mankenstein
Data is offline   Reply With Quote
Old 01-05-2003, 02:14 AM   #5695
Manticore's Avatar
hot topic
Old 01-05-2003, 06:53 AM   #5696
dtm
dtm's Avatar
Next challenge....stick a 705 backend to the RR!!
Old 01-05-2003, 07:18 AM   #5697
Manticore's Avatar
no way !! i dont like snake !!
Old 01-05-2003, 10:27 PM   #5698
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
MMMM.......Taste's like chicken
HEYALIGNMENTGUY is offline   Reply With Quote
Old 01-05-2003, 10:34 PM   #5699
DCR1TWO's Avatar
Hey Manti,
Do you have to run special tires for the MTX-3 Rear hubs? I noticed that fast tires now have foams specially designed for the MTX-3.
DCR1TWO is offline   Reply With Quote
Old 01-05-2003, 11:21 PM   #5700
popsracer's Avatar
Default V1R universals/CVD's
Hey Guys;
Do any of you know if Universals/CVD's for the V1R will also fit the Reflex NT and if so, what brand/type would you recommend.
The ones on the NT seem to bend VERY easily.
Thanks again,
popsracer is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
