Old 01-01-2003, 09:24 PM   #5611
AMGRacer's Avatar
Originally posted by patelladragger
I still have that setup on a car - I put it on the car I rebuilt from Diva actually. The car carries plenty speed in the sweeper but it requires lots of attention to stay fast in the tight stuff as the azz end will come around quick with any sudden steering input. I don't however have many laps experimenting with it so It's going to be the candidate for the camber link mods.
Are you still running the negative diff in that car?
Yep the back end is a problem with mine as well. The things which I have found which helped are:
- Softer rear springs/remove swaybar (try gold springs)
- More camber, try 4 degrees and maximum camber change (or the rear camber mod)
- less caster
- less rear droop
Negative diff is gone now. I have returned my car back to almost stock. I use the graphite top deck, low cg tank, aaa battery, side stiffener for rear exhaust, low cg engine mounts and Mugen clutch. Rest is stock now.
AMGRacer is offline   Reply With Quote
Old 01-01-2003, 09:46 PM   #5612
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
[i]Softer rear springs/remove swaybar
Negative diff is gone now. I have returned my car back to almost stock. I use the graphite top deck, low cg tank, aaa battery, side stiffener for rear exhaust, low cg engine mounts and Mugen clutch. Rest is stock now. [/B]
AMGracer
Just wondering what track did you run yours in QLD???
I ran my one at Moorebank and I can flat stick though the sweeper with soft suspension setup without rear end lose but a bit slow when switching direction in the esse, where I lose about 0.3s to the MTX3.
tl2111 is offline   Reply With Quote
Old 01-01-2003, 09:48 PM   #5613
Taylor-Racing's Avatar
Originally posted by AMGRacer
Manti I think is using the same spring combo as me, fantom yellow front and rear, the 1.8mm thick coil. This combo is incredible, you will be stunned at how the car handles. It requires a lot of concentration to drive, many people tell me my car is taily, but if you can control the car with the throttle it is the ticket.
OK, great, thanks.
I'm a bit confused though - your previous post said "I like the fantom yellows and greens for springs."
Are you saying that yellow front and rear is the go?
I'm guessing this is going to be somewhat harder than the kit Gold springs ant that's the area I want to experiment with. "Tailiness" we can handle, I reckon - I'm not really unhappy with our existing set-up but am looking for improvements getting out of corners, hence my tinkering with rear camber and adding weight to the Neg. diff clutch shoes etc.
Lilydale for the Vic's will have plenty of grip, and my theory says to tie it down tight and get that rear camber change happening in a smaller suspension movement. Comment welcome.
Taylor-Racing is offline   Reply With Quote
Old 01-01-2003, 09:59 PM   #5614
Originally posted by chippy
I lowered the steering servo so it just sit s just off the front lay shaft ..
then just moved the balls on the servo saver from bottom to top steering arms are just about the same angle as original..
Of course - gee I'm a dill. That's exactly what I used to do with the Neo's.
My servo is already under the top deck, but moving the balls will get it down another 10mm, I'd reckon.
Dr Dremel can take care of the slight clearence issue with the mid shaft block.
Thanks for jogging my brain fade, chippy.
Old 01-01-2003, 10:05 PM   #5615
Originally posted by tl2111
Our racing season starts at the end of January with the Victorian titles in February.
Taylor-racing
I thought the Vic's is on 26 Jan 03????
BTW the spring I got is from Bartman.
Thanks, tl2111
Gawd, I did it again - I think I must have had a "senior's moment"
Yes, the Vic's are on Australia Day weekend, 25th - 27th January.
I was looking at the 1/5th titles which are in February.
So who's Bartman?
Old 01-01-2003, 10:19 PM   #5616
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
I wen't to track to day to turn some laps before Big race on Sun.
I myself witnessed 3 brand new MTX3s and I was not that impressed
These people who had them are capapble drivers and are not new. seemed to me the car would not stick and was all over the place.
The track was untreated and was some what dusty, but my R was holding its line a hole lot better, gonna have to wait and see, what happens SUN if there are any people who show up with one.
I myself will stick with the R
Other thing I noticed was I got some Nitro Shoes to try out and didnt realise when I got them that the front tire width is 28mm,
I cut them down to 26 so they dont rub.
HEYALIGNMENTGUY is offline   Reply With Quote
Old 01-01-2003, 10:33 PM   #5617
AMGRacer said:
Manti that looks awesome!!!!!!!
So far we need the MTX3 hub, and the MTX3 dogbone. Can we adapt the V1R outdrive and hexes with different size bearing or do we need the whole MTX3 rear end?
Also, Manti,
What is the length of the camber link on the "MoneR".
It's going to be shorter than the stock VoneR, isn't it?
We'll also need the balls for the top of the upright, yeah?
Probably also need a Mugen camber link, presuming it's shorter.
Will the VoneR pillow balls fit the Mugen upright? - I'd just like to retain the Titanium/Teflon ones if possible.
Old 01-01-2003, 10:44 PM   #5618
sparksy's Avatar
Trader Rating: 14 (94%+)
Correct me if I'm wrong, but I'm 99% sure the balls are the same size....
I do know the serpent ones are a little smaller in diameter
sparksy is offline   Reply With Quote
Old 01-01-2003, 10:56 PM   #5619
tl2111's Avatar
Originally posted by Taylor-Racing
Thanks, tl2111
So who's Bartman?
Bartman=Rick Bartalozzzzz
Old 01-01-2003, 11:13 PM   #5620
AMGRacer's Avatar
AMGracer
Two tracks I tested at. One is Meakin Park a smaller parking lot style track and the other is Brendale, a Moorebank style track.
The main reason I like the fantom greens and yellows (I use them paired normally but feel free to play!) is I find that 80% of the direction change loss to the MTX3 comes from too soft springs. Soft springs = more roll = less transition speed. But as you stiffen the springs (I do it equally) your car loses overall traction. This is felt in the rear first by most people.
The other 20% again in my opinion is due to the lower cg of the Mugen.
Old 01-01-2003, 11:16 PM   #5621
Thank gawd for you, HAG.
Actually, I think the MTX-3 may well be a better car - slightly.
Will it make my driver (13 year old son) any quicker? - probably not.
Will he go faster with the AMG/Manti "MoneR" mod's? - if they work, probably yes.
Why? - because we have a lot of development time, experience and effort tied up in the VoneR.
I've watched (boy do I watch) a couple of the top guys down here struggle with the understeer of the MTX-3 box set-up. They've made some good headway with their development and undoubtedly will continue to do so.
We have the Vic's on in 4 weeks and the last thing I need is to sort a brand new car. I reckon I can make the MoneR mod's work in that time, though.
After the last year's Vic's we figured we needed three seconds per lap to get into the pointy end of the field for this year. Well, we got about 2.5 seconds of it, but didn't count on the top guys finding another second or so, also. - drat.
Besides, as I said, I've already bought five cars this year, and that's enough - ouch.
And here's another opportunity to repeat my creed:
Most of the differences between cars is at the transmitter end, not the receiver end.
So, what's the go with these Nitro Shoes - Japanese rubber, are they?
Old 01-01-2003, 11:18 PM   #5622
AMGRacer's Avatar
OK, great, thanks.
I used yellow all around and I have used green all around as well.
All I am saying is that in my opinion I find the Kyosho is too stable. Ie it is damn easy to drive but is sluggish and unresponsive (relatively). Add some stiffness (feel the MTX3 springs they are quite hard) for a more responsive but less tractive car.
I personally found more turnin, better corner stability and better out of corner speed with the yellows. But the rear gets loose off power much easier, solution stay on power! Or brake I guess.
Old 01-01-2003, 11:20 PM   #5623
Manticore's Avatar
R/C Tech Charter Subscriber
Also, Manti,
seem like it is a direct fit to the mugen hub. but yet to set up suspension and I will see.
Manticore is offline   Reply With Quote
Old 01-01-2003, 11:23 PM   #5624
Manticore's Avatar
no, the mugen pivot ball is a bit smaller in diameter
Old 01-01-2003, 11:23 PM   #5625
AMGRacer's Avatar
Well thats good to hear HAG! On many of our local tracks MTX3s have been breaking lap records, but I am beginning to think it is because people are upgrading from older cars. Serpent and Yokomo to be precice. The MTX3 is hands down better than these cars. The more I am doing to the Kyosho to make it like the Mugen (copycat?) the more it is performing well.
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
