Old 11-13-2001, 07:54 PM   #541
Diva's Avatar
Send a message via Yahoo to Diva
Kyosho has 3 flying weight as well. But is more FW better? I know someone encountered a problem of the clutch engaged when pulling throttle but never lose back so the engine died when entering the corner.
For the Serpent CC, since it has 2 springs - one for pushing and one for pulling, the above problem will never happen. Indeed, I believe that Serpent should be one of the best designs.
Diva is offline   Reply With Quote
Old 11-13-2001, 08:06 PM   #542
Manticore's Avatar
R/C Tech Charter Subscriber
all of the mugen centax dont have the clutch problem tht you descript. it doenst have any small spring inside except the one for clutch engaging timing.
Manticore is offline   Reply With Quote
Old 11-13-2001, 11:19 PM   #543
Send a message via ICQ to SirSpeedy Send a message via AIM to SirSpeedy Send a message via Yahoo to SirSpeedy
What weight of diff oil are you guys running on high-bite asphalt with foams?
Have you found any other springs that seem to work on these shocks? I would like to have more than three tensions. AE springs seem to be a little small, and Losi springs are too long....too much pre-load with the collar at the very top.
That is all for now.... : )
Tim Davis
SirSpeedy is offline   Reply With Quote
Old 11-13-2001, 11:39 PM   #544
Regional Moderator
Originally posted by Manticore
how did you know that?
From some 1/5th scale website. LSD is also getting popular in 1/5th scale racing.
White cat is offline   Reply With Quote
Old 11-14-2001, 12:40 AM   #545
Trader Rating: 15 (100%+)
guys, im about to buy another v-one r as ive sold my old one (want to start fresh, and im not losing out )
whats the difference with the GRP kit and the RR kit?
witht he kyosho cc, can it be used on a std shaft as well as a SG shaft?
thanks
Kyosho Superten FW-04, O.S. 4 stroke conversion, fully optioned, shelf queen... my baby!
nitro dave is offline   Reply With Quote
Old 11-14-2001, 12:54 AM   #546
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
thanks
You guys should check out this V-One-R page :
http://homepage2.nifty.com/shunyosi/...ice_v-oner.htm
ITS IN JAPANESE, so just go to http://world.altavista.com/ and convert it over.
Dave, is this Kyosho CC your talking about ?
Michael_T is offline   Reply With Quote
Old 11-14-2001, 03:11 AM   #547
sparksy's Avatar
Trader Rating: 14 (94%+)
Has anyone cut the clutch that comes with the kit to tune it? Is it worth it? I did it with the HPI clutch, the MIP one.... Worked nice...
sparksy is offline   Reply With Quote
Old 11-14-2001, 03:19 AM   #548
AMGRacer's Avatar
Nitro Dave you cannot use the standard shaft with the centax. However Sparksey has a Ofna standard shaft centax which you could use.
AMGRacer is offline   Reply With Quote
Old 11-14-2001, 03:38 AM   #549
Mauler's Avatar
Send a message via ICQ to Mauler
You don't cut the clutches that come with the kit... drilling a couple of holes is a popular choice but if you really want the punch, changing to a stiffer spring might help...
Mauler is offline   Reply With Quote
Old 11-14-2001, 03:42 AM   #550
Mauler's Avatar
No wonder... the Kyosho LSD is not very much different from the appearence other than the floating blocks... Don't quote me but I think the material used for the bevels could be inconel... other than that, given the density and price, I could not think of other materials that could withstand the wear!
By the way White Cat...you have the 1/5th site for reference?
Old 11-14-2001, 04:44 AM   #551
AMGRacer's Avatar
The foam setup from Kyosho calls for using the lower bottom shock mounting hole. The rubber calls for using the top. What would be the effect of changing the top to the bottom or vice versa??
Old 11-14-2001, 07:03 AM   #552
could be?
Old 11-14-2001, 07:13 AM   #553
Manticore's Avatar
could be?
yes it is !! the three pieces on the left bottom of the picture are the cone shape fly weights.
Old 11-14-2001, 07:19 AM   #554
Manticore's Avatar
I am going to get the k factory low CG fuel tank, TI pivot balls or may be the 4mm main chassis.
Old 11-14-2001, 12:34 PM   #555
Mauler's Avatar
Hey Manti...are the floating blocks suppose to be free to slode up and down the shaft or is it suppose to be tight on the case... Mine seems rather tight and it makes no sense at all! Made any modifications to ur casing?
Anyone too?
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
