Old 11-21-2002, 11:30 AM   #5416
chippy's Avatar
Jedi the most important thing that Pattella forgot to mention.
ie a front oneway not the easiest thing to drive if you are a newby as you have to drive with a lot less brakes.
So as he said learn to drive the V1R and set it up.
then when your confident driving that car and can see what changes to setup does what to the car then upgrade.
Because just getting a newer car wont make you a better diver..
chippy is offline   Reply With Quote
Old 11-21-2002, 11:46 AM   #5417
Default front diff
I am need help I need to put a front diff from parts and need to get the part # please help
Where do you all get parts for the y-oner over seas or from tower
emt152 is offline   Reply With Quote
Old 11-21-2002, 12:28 PM   #5418
patelladragger's Avatar
Send a message via AIM to patelladragger
Default Re: To Patelladragger...
Originally posted by RClover
Do u have a pic of your car?
which one?
Na seriously I've had no problems with the kfactory tank or the stock tank.
patelladragger is offline   Reply With Quote
Old 11-21-2002, 02:06 PM   #5419
rjl
rjl's Avatar
New fuel tank seals can be purchased for the voner tank. The part No. is 92050-01. There is no real difference in the handling of the car between the two tanks.
rjl is offline   Reply With Quote
Old 11-21-2002, 06:48 PM   #5420
RClover's Avatar
Default So the culprit is...
which means that the real culprit is the fuel tank seal? anyway, my k tank is on the way, will install it this weekend. but i am quite sceptical that this tank does improve the overall stability of the car...
RClover is offline   Reply With Quote
Old 11-21-2002, 07:22 PM   #5421
DCR1TWO's Avatar
Default Re: front diff
These are the parts you need to build Front and Rear Diffs:
Item #
BS107 Bevel Shaft
VZ012 Diff Gear Set
VZ009 Diff Pulley Set
VZ015 Diff Joint
Diff Oil
You will need 2 of the VZ015 if you plan on building both front and rear diffs. I believe Tower has all of the items in stock.
DCR1TWO is offline   Reply With Quote
Old 11-21-2002, 10:52 PM   #5422
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
Patella: Did you order those gears
HEYALIGNMENTGUY is offline   Reply With Quote
Old 11-21-2002, 10:53 PM   #5423
Manticore: I got my package in the mail today
Boy that was faster than the last one you sent me
Old 11-21-2002, 11:26 PM   #5424
Manticore's Avatar
R/C Tech Charter Subscriber
Great!!
Manticore is offline   Reply With Quote
Old 11-22-2002, 05:49 AM   #5425
dtm
dtm's Avatar
Send a message via ICQ to dtm
Originally posted by Manticore
Great!!
Manticore- your favourite friend from PG says the Rossi engine SUX......Siro Rulez!!!!
Did you hear the story about Kyosho getting the 3 ports and 5 ports mixed up in the boxes???
dtm is offline   Reply With Quote
Old 11-22-2002, 06:15 AM   #5426
Manticore's Avatar
who are you talking about??
I know that. It is simple to find it out looking from the exhaust port. There should have 2 small ports at each corners of the exhaust.
Old 11-22-2002, 09:53 AM   #5427
dtm
dtm's Avatar
Your favourite guy who likes to replace his conrods after 1 gallon of fuel!!
Old 11-22-2002, 10:09 AM   #5428
Manticore's Avatar
I think he is so nice to run in conrod for his customer !
Old 11-22-2002, 12:01 PM   #5429
RCLover
Use a #4 or 3mm split lock washer to keep the caphead screw from backing out on the 2 speed. I would use one on the Centax also if you have one.
No mess from threadlock and you can take the screw out when you want.
Sydewynder is offline   Reply With Quote
Old 11-22-2002, 03:10 PM   #5430
What hop up parts are recomended to lighten up the V1rr? Ive been looking into Kawahara parts but I am not exactly sure what would actually make the car lighter. Ive also seen that Kyosho makes some titanium parts. Which ones would be helpful? I was thinking turnbuckles and titanium screws, but I'm not sure if Kyosho makes a screw set specifically for the RR. Any advice would be great. Thanks
UndrGrndRziztnz is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
