Old 11-19-2002, 09:23 PM   #5401
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by HEYALIGNMENTGUY
Thanks and for those who give a Damn my PM box is empty
I did I did !
Manticore is offline   Reply With Quote
Old 11-19-2002, 09:32 PM   #5402
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
Originally posted by Manticore
I did I did !
I saw I saw
HEYALIGNMENTGUY is offline   Reply With Quote
Old 11-19-2002, 09:48 PM   #5403
RClover's Avatar
Default Re: Re: Re: Re: Re: Re: Agree...
if you have a track that requires 8.5 ride high, you should play your rally car there instead !
u're right man....
BTW, are u still using the same K-factory fuel tank since last November? Any sign of leakage or any breakage?
Cheers.....
RClover is offline   Reply With Quote
Old 11-20-2002, 04:35 AM   #5404
dtm
dtm's Avatar
Send a message via ICQ to dtm
Default Re: Re: Re: 2 speed shaft...
Originally posted by RClover
i c...so which shaft r u running right now? its your second shaft?
I'm taking a rest from GP right now.....but I went back to the original shaft because Ti shafts where out of stock at the time!
dtm is offline   Reply With Quote
Old 11-20-2002, 04:55 AM   #5405
RClover's Avatar
Default Re: Re: Re: Re: 2 speed shaft...
What is Ti shaft? Which manufacturer? pardon me if i am too ignorant...
Old 11-20-2002, 05:03 AM   #5406
dtm
dtm's Avatar
A shaft made of Titanium (Ti).....I think Square makes one...but it can be from any manufacturer really.
Old 11-20-2002, 04:11 PM   #5407
Send a message via Skype™ to JordanC
i've only ever seen one rear lay shaft replaced (stock)... The only reason for that was it had done so many miles it literally wore out.
JordanC is offline   Reply With Quote
Old 11-20-2002, 04:55 PM   #5408
Jack's Avatar
Default Re: Re: Re: Re: Re: 2 speed shaft...
RClover...
If i rem correctly
I think Kyosho also came out with a lighten shaft that is Ti
i am not sure..
you could go to the shop and check it out
Jack is offline   Reply With Quote
Old 11-20-2002, 08:16 PM   #5409
RClover's Avatar
Default rear diff.....
Is the Negative Diff from kawahara also known as the LSD?
So, they are self-adj. ?
Is running Solid axle in the rear is better than LSD or normal diff with 100K grease? Which is the best combination if Front One-way is used?
Old 11-20-2002, 09:36 PM   #5410
They have a lot of differential action at low speed, but at higher speeds it stiffens up.
Old 11-21-2002, 09:41 AM   #5411
jedi's Avatar
Default V one R vs V one RR
Hi1 I'm a newbie to gas powered racing and recently bought a used v one r. I ran it a few times and raced once and am satisfied with it. My buddy also wants to get into gas powered rc racing and has offered to buy my car. There's a new v one rr at my lhs that seems to be begging me to take it home. My question is: Is it worth it to upgrade to the v one rr, if it can be called an upgrade? What are the basic differences between both cars? I run on a small to medium sized cement track with low to medium bite. What tires should I use? And what general set-uo?
I know these topics must have been discussed earlier in this thread but please to ask me to search for them. I really don't have the time to go over 5000+ posts. Any help would be greatly appreciated.
Jedi
jedi is offline   Reply With Quote
Old 11-21-2002, 10:32 AM   #5412
patelladragger's Avatar
Send a message via AIM to patelladragger
only about 10-15 pages back there was a listing of all the differences between the kits. I will list what I can remember:
RR upgrades:
Centax clutch
floating body mount/ different rear end
low-friction belts
wide front bumper
blade-style front sway bar
190mm reinforced rear dogbones
different front shock tower
25T side pulley for overdrive
I'm certain there is something else i'm leaving out...
patelladragger is offline   Reply With Quote
Old 11-21-2002, 10:49 AM   #5413
jedi's Avatar
Default Worth the upgrade?
Thanks for the info. But would it be worth it to upgrade to the RR?
Jedi
Old 11-21-2002, 11:05 AM   #5414
Default Re: Worth the upgrade?
Jedi
I dunno that's totally your call. If you're new and you already have a car my advice would be to keep it and learn how to set it up and drive it well before buying anything new. None of the upgrades that are on the RR are as important as practice time for the newer driver.
That was one of the mistakes I made when I first started - buying too many different cars instead of just focusing, practicing, and learning on one.
Old 11-21-2002, 11:16 AM   #5415
RClover's Avatar
Default To Patelladragger...
Do u have a pic of your car?
What do u think of the K factory tank?
My stock tank is leaking like hell...i saw some smoke out from the fuel cap while fuel somehow leak out from the cap... i check on the fuel cap spring, it still tight and seems nothing wrong...but the inner foam of the fuel cap seems worn out...
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
