Kyosho VoneR Thread >
Kyosho VoneR Thread
Like Tree1Likes
Kyosho VoneR Thread
Old 11-19-2002, 03:48 PM
  #5386
rjl
rjl's Avatar
If a rear diff, replace the 2.6x8 screws with 3x8. This will not work in the front as it distorts the pulley.
rjl is offline
Old 11-19-2002, 03:53 PM
  #5387
asd
i found that my front diff was leaking a bit(my front gear diff), so i took it out, and then i made aure all teh screws were in all the way, and evenly, so i did so, and i tightened all 4 screws(i tink 4!)
adn found that it doesnt leak anymore
asd is offline
Old 11-19-2002, 04:33 PM
  #5388
asd
also, does any1 know wat a "hatori" pipe is?
its a company that makes tuned pipes but i wasjus wondering if any1 knew about them
asd is offline
Old 11-19-2002, 04:45 PM
  #5389
rjl
rjl's Avatar
They make high end pipes for pattern aircraft and helis.
rjl is offline
Old 11-19-2002, 04:46 PM
  #5390
asd
lol, i have a dual chambered one for my v one rr,
i guess my lhs is lying to me, cause i jus cheked out hatori's website, and they dun even make tuned pipes for cars, oh well, its still a nice pipe i got.
asd is offline
Old 11-19-2002, 06:25 PM
  #5391
RClover's Avatar
Default Agree...
Originally posted by patelladragger
you also may want to try a harder shore up front. 35 is pretty aggressive a shore on the front especially if you're oversteering already. Try 40-42. If that doesn't do it try stiffening your front springs. If your track is bumpy you may not want to take out your droop.
agreed with what you've suggested...i have change to 40 shore front tyres and droop set to 3 b'cos the track is really uneven and bumpy.
I found the rear is harder when i raised the ride height to 8.5mm via the adj. shock collar.
I am thinking of changing to a Kyosho orange spring and raised the shock mounting position to 4th hole (counting from the lowest hole).
This way, i can raise the chassis more w/o having to adj. too much on the adj shock collar to avoid a harder compressed spring.
I will test it out this weekend, but what you guys' comments on this?
RClover is offline
Old 11-19-2002, 06:27 PM
  #5392
Jack's Avatar
Default Re: Agree...
8.5mm???
u change your front droop to 3???
Jack is offline
Old 11-19-2002, 06:32 PM
  #5393
RClover's Avatar
Default Setup on bumpy track......
Originally posted by InitialD
It seems that you have too much off power steering from what you have described.
Firstly, try using the same front and rear ride height.
Secondly, limit your rear droop (i.e. from 4 to 6). This will limit the weight transfer from the rear to the front during off throttle.
The reason why your rear is loose can also be due to the rear droop. Limit it to 6 or 7 and try it out.
InitialD, r u using the LSA Carbon Shock Tower on your Impulse?
In my case, i have a carbon shocktower which is rather similar to the LSA ones. If raising the shock mounting position from the lowest to the 4th/ 5th hole on the shocktower, what would happen to the rear end handling?
RClover is offline
Old 11-19-2002, 06:36 PM
  #5394
RClover's Avatar
Default Re: Re: Agree...
Originally posted by Jack
8.5mm???
The track is bumpy, my chassis was bottoming out at the rear the other day. I think 8.5mm is lowest ride height at that track...
Rear droop is 3.
RClover is offline
Old 11-19-2002, 06:41 PM
  #5395
Jack's Avatar
Default Re: Re: Re: Agree...
Rear droop is 3.
wait at Jurong track or MS track?
at Jurong. mine was at 5.5
rear droop at 4
Frnt at -1
my spring are pretty hard.. maybe your rear spring is too soft.
I am using the silver spring with pretty good result
Jack is offline
Old 11-19-2002, 06:58 PM
  #5396
DCR1TWO's Avatar
Default Re: Setup on bumpy track......
Raising the rear shock position or making the shock stand more vertical will make the rear springs feel stiffer, allowing less weight transfer to the rear, and effectively giving you more on power steering.
If you have to much off power steering you may want to try some of the following:
Stiffer front springs
Thicker frong shock oil
Stiffer front sway bar
Less front camber
More Caster
Less front toe out
Less rear droop
If your loose on power you may want to try one of the following:
Softer rear springs
Thinner rear shock oil
Softer rear sway bar
More rear camber
Less Caster
More Rear toe in
More Front Droop
DCR1TWO is offline
Old 11-19-2002, 08:43 PM
  #5397
RClover's Avatar
Default Re: Re: Re: Re: Agree...
[QUOTE]Originally posted by Jack
rear droop at 4
Frnt at -1
[/QUOTE
nope...i am back in Malaysia already...
if it were Jurong or MS, shouldnt have too much problem...
RClover is offline
Old 11-19-2002, 08:51 PM
  #5398
Manticore's Avatar
Default Re: Re: Re: Re: Re: Agree...
[QUOTE]Originally posted by RClover
rear droop at 4
Frnt at -1
[/QUOTE
if you have a track that requires 8.5 ride high, you should play your rally car there instead !
Manticore is offline
Old 11-19-2002, 08:55 PM
  #5399
Jack's Avatar
Default Re: Re: Re: Re: Re: Re: Agree...
what rally....???
buggy time
Jack is offline
Old 11-19-2002, 09:03 PM
  #5400
I didnt pick on you kiddie!
btw, the ss sent out today
Thanks and for those who give a Damn my PM box is empty
HEYALIGNMENTGUY is offline
