Kyosho VoneR Thread
#5371
Manticore: Are you picking on the Kiddies again
They are just trying to learn
#5372
Hey dude, try to be a bit more respectful. I'm not a kid, so dont refer to me as one.
about the tank, i've been debating it....
#5373
Sorry
#5374
cool, its all good
The tank, hmm well, yeah I was oringinally against it, trying to avoid K factory stuff, but then, it seems nobody has had a problem with the tank. I dont like the fact that i cant use the Kawa pro upper deck with the tank. That's the only thing thats stopping me. I'm partial to the Kawa pro deck. Just seems more solid and it looks cooler.
#5375
cool, its all good
cool, its all good
The best part of this hobby is the tinkering and custom fitting of parts
#5376
yeah good idea...
#5377
btw, the ss sent out today
#5378
Re: 2 speed shaft...
Originally posted by RClover
2) Could this be the reason that the 2 speed shaft snapped into two? The breaking point is located at the pin hole of the brake pulley position. Or it is due to fatique/ wear and tear/ merely poor quality of this K factory shaft?
cheers....
cheers....
#5379
Re: Re: 2 speed shaft...
Originally posted by dtm
The K factory shaft is a little weaker than the original...normally you will be fine....but if you run a solid rear axle, this will load the shaft more. I've had a K factory shaft break on me before simply from the torque of my engine....I was coming out of a corner when it decided to give up! Ti would be a better bet.
BTW, i need some setup info on a parking lot temporary track which is rather bumpy. Would appreaciate if you could help to give comments to my datasheet as below:
Front Geometry:
- One-way
- Stock spring
- Stock Shock Oil
- Anti roll bar (vertical)
- Droop -1
- Camber -1.5
- Toe-Out 1
- Ride Height 7.5mm
- Ennetti 35 Shore 26mm Foam Tyre
- No shock tower used
Rear Geometry:
- Diff with 100K silicone grease
- Fivestar Yellow spring
- Stock Shock Oil
- Stock Sway bar
- Droop 4
- Camber -2.5
- Toe-In 2.5
- Ride Height 8.5mm
- Ennetti 35 Shore 30mm Foam Tyre
- Shock mounted on the lowest hole of Fivestar carbon fibre
shock tower
I find that this setting is lack of grip at the back end but lot of steering. I have to back off power a little earlier than other racers to enter the sweeper after a long straight.
PLs advise......cheers
#5380
Re: Re: Re: 2 speed shaft...
Firstly, try using the same front and rear ride height.
Secondly, limit your rear droop (i.e. from 4 to 6). This will limit the weight transfer from the rear to the front during off throttle.
The reason why your rear is loose can also be due to the rear droop. Limit it to 6 or 7 and try it out.
#5381
you also may want to try a harder shore up front. 35 is pretty aggressive a shore on the front especially if you're oversteering already. Try 40-42. If that doesn't do it try stiffening your front springs. If your track is bumpy you may not want to take out your droop.
#5382
active diff
Seems pretty good, responded to adjustments, and has held settings so far.
#5383
My gear diff seems to be leaking quite a bit. Is this normal?
#5384
Manticore posted the fix a few pages back, using slightly longer screws. Coating the leaking edges with RTV after you rebuild it helps seal it also.
#5385
thanks, kev, thanks RJL as well. I found Manti's post. Thanks guys.
