Old 11-11-2001, 09:09 PM   #496
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by AMGRacer
LOL, it is like the ocean...... the variation is over 2 feet or so areas.....
so you dont need to worry about the main chassis from hitting the ground !!
Manticore is offline   Reply With Quote
Old 11-11-2001, 10:15 PM   #497
AMGRacer's Avatar
This is kinda going around in circles
Let me ask then, does anybody think that uptravel limiters are worthwhile setting up? Some 1/8th drivers I talk to say that they are useful........
AMGRacer is offline   Reply With Quote
Old 11-11-2001, 11:03 PM   #498
Manticore's Avatar
yes it does if you want to limit front end from chassis roll !
Old 11-12-2001, 12:44 AM   #499
Originally posted by Manticore
so what do you do to handle that?
Pull the throttle and play rally car.
Sydewynder is offline   Reply With Quote
Old 11-12-2001, 12:50 AM   #500
Manticore's Avatar
that will make your TC more realistic!!
Old 11-12-2001, 02:35 AM   #501
Diva's Avatar
Send a message via Yahoo to Diva
Exclamation
Originally posted by White cat
Sure! I will take some pictures when I go there.
This is our track in HK.
Diva is offline   Reply With Quote
Old 11-12-2001, 02:45 PM   #502
AMGRacer's Avatar
OK I have some questions about the Kyosho setup sheet:
1. Next to camber angle it has 0G/1G with 1G circled.... Any idea what that means?
2. The toe angle is measured in mm?? What the..... How do you measure that??
3. Rebound stop...... Is that the number of mm below the bulkhead?? As in +2 means the setscrew is 2mm long???
Old 11-12-2001, 04:40 PM   #503
Trader Rating: 15 (100%+)
not sure what 1G means
For the toe, i have setup tools (similar to Hudy) and all the measurements on that are in mm.
for rebound/stop, in the pic you can see the area they measure which is the bottom of the susp. arm and bottom of the chassis. ive never adjusted those, too much hassle so i leave all those tricky bits free.
Kyosho Superten FW-04, O.S. 4 stroke conversion, fully optioned, shelf queen... my baby!
nitro dave is offline   Reply With Quote
Old 11-12-2001, 05:30 PM   #504
AMGRacer's Avatar
Oh my Hudy is in degrees not mm......
Old 11-12-2001, 05:32 PM   #505
adelmundo's Avatar
Send a message via ICQ to adelmundo Send a message via AIM to adelmundo
OK 1G means 1 Gravity, or in other words when the car is on all four wheels on the ground. You can measure camber and ride height, for example, with either a no gravity load (0G) such as when you have your car up on Hudy blocks and the shocks are uncompressed, or you can measure camber and ride height when all the shocks are compressed (1G) when the car sits on the grounds on all four wheels.
As for Toe, the mm states, if using a straightedge, if you line the straightedge on the rear wheel, the mm tells it how far in in mm it will hit the other wheel (I know it;s hard to explain but that's the best way I explain it). If that's too hard for you to understand, then just set your toe in for the rear at 2 1/2 to 3 degrees. That seems to be a good setting most people run.
Rebound/Stop is, if using a Hudy Droop Gauge and Hudy Blocks for example, the number of mm below the chassis bottom and the suspension arm. I have mine set to 1 mm in the front and 6 mm in the rear.
adelmundo is offline   Reply With Quote
Old 11-12-2001, 05:57 PM   #506
Manticore's Avatar
well, i dont think all those mm and 0/1 G do make any sense to RC car setup. I think Kyosho doesnt want their customer to use the sheet at all
Old 11-12-2001, 05:58 PM   #507
Manticore's Avatar
the setup board marking should be in mm while the setup tools (similar to hudy) should be in degree !
Old 11-12-2001, 07:31 PM   #508
AMGRacer's Avatar
Manticore do you have a good setup for foam tires on a medium fairly fast track?
I am trying to use the Kyosho setup as much as I can and it is OK, but I feel it could be better......
Thanks!!
Old 11-12-2001, 07:53 PM   #509
Manticore's Avatar
Thanks!!
I still havent the chance to run foam, I run rubber tire all the way as yet. if you want to run foam on V1R you need to get the longer rear wheel axle to accommodate wider rear form wheels.
Old 11-12-2001, 08:07 PM   #510
AMGRacer's Avatar
Ohhhhhh OK. What setup do you use for your rubber? I also am thinking of running a rubber setup soon.....
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
