Old 11-04-2002, 01:35 AM   #4981
kevink2's Avatar
Originally posted by patelladragger
gorgeous paint scheme kev.
Just one question - what the heck is TEKIN doing adorning a beautiful nitro? That sacrilege man you might as well put a JP logo on a 1/12 scale.
What you got an esc in there to operate a hand brake or somethin'?
That was kind of an old school personal ode to TEKIN! I still use their chargers, they rock! I thought it was kind of funny...
kevink2 is offline   Reply With Quote
Old 11-04-2002, 06:00 AM   #4982
how many of you are considering going over to the Mugen camp after the MTX-3 comes out? be honest.
calimassive is offline   Reply With Quote
Old 11-04-2002, 06:25 AM   #4983
Hey Patella, did you have to make any mods to get the K factory low CG gas tank to fit? Furthermore, im wondering if I can use the Kawahara carbon upper deck and the K factory fuel tank in conjunction. Will they fit together?
OK, I was looking at the Kawahara carbon radio plate online and it doesnt look like it will except the K factory gas tank, so either I keep the stock plate and drill a hole in it, like it says on the K factory website, or i get the K factory carbon deck. I'm trying to avoid K factory stuff as much as possible, oh well . Anyone got the K factory upper deck, and if so, how is it? I'm a sucker for low cg . The stock tank seems too high to me, its bugging me. I have to do something about it.
Old 11-04-2002, 08:41 AM   #4984
patelladragger's Avatar
Send a message via AIM to patelladragger
cali I'm using the kfactory deck on the car that i have the lcg tank in. Haven't had any problems with it other than you have to use a different belt tensioner. However, the deck aluminum support/brace/tensioner combo dealie that is kfactory (I took all these parts off a reflex), weighs no more than the plastic support and stock belt tensioner. Some engine/pipe combos though if you add the lcg engine mounts are a tight fit if you have the kfactory brace on though.
But now that I think about it, I don't remember any kfactory parts that really sucked off that reflex except for the universals and the 4mm chassis was heavy as a brick. They definitely aren't any worse than 3 racing IMHO.
If I were you I would find something else to stress about cause I have yet to be able to discern ANY difference with the lcg tank on. Maybe I'm just not good enough to tell?
mtx-3, I will try it, but i'm not giving up my kyosho unless it's a huge improvement.
patelladragger is offline   Reply With Quote
Old 11-04-2002, 01:48 PM   #4985
squizzytaylor's Avatar
Default calimassive
re the MTX-3.
I reckon this is all a bit, ford vs gm vs dodge.
If the car offered some miraculous performance/handling traits then it might be worth considering, however even if it did how many of us are seriously good and consistent enough to utilise that. It seems that every time something new comes out there are those (usually me) who just have to have it! but not this time,
Ive only just finished building my v-one-rr and Ive got to tame that first
but as they say "never say never"
The quality of cars is so high and close now that no one company can offer a product that stands out significantly from the others but there are companies that offer products of significantly poorer quality than others.
gt
squizzytaylor is offline   Reply With Quote
Old 11-04-2002, 04:08 PM   #4986
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
Originally posted by HEYALIGNMENTGUY
Your not looking hard enough
Besides if you get the RR, You are gonna put foams on it and throw the BROKAMO away
Ok, which foams to put on then?!
BTW, the MT12 on my Yok will go in the V1R and guess what will be in my Brokamo? Time to bust out with the Richey RTU baby!
Dan is offline   Reply With Quote
Old 11-04-2002, 05:36 PM   #4987
DCR1TWO's Avatar
The Integy Carbon radio plate will also work with the K Factory tank. You will just need to use thicker o-rings to keep the tank from flopping around. It's pretty nice and it's only around $30.
DCR1TWO is offline   Reply With Quote
Old 11-04-2002, 07:43 PM   #4988
Patella, you are probably right that i am being overly paranoid about this low cg tank thing. LOL, ;-)
DCR12, thanks for the suggestion, and thanks so much for the pic too, that really helped, i feel so much better now, cause then i dont have to get the K factory belt tensioner/stiffener, whatever it is. I wanted to avoid having to do that.
Squizzy I agree. I was having some anxiety over my decision to get a V1rr, not that its a bad car, quite the contrary, but because the MTX-3 was coming out shortly after. I think im slowly getting over it.
Old 11-04-2002, 08:03 PM   #4989
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
You go right ahead and bust out the Richey RTU, I also have one, if you don't remember
But don't cry when your YOK hits the concrete wall at DELTA and snap goes those plastic uprights and upper control arms
Remember its the driver not the car SON
HEYALIGNMENTGUY is offline   Reply With Quote
Old 11-04-2002, 08:05 PM   #4990
If you do jump on the Mugan exspress,let me know I be willing to buy your RR roling chassis
If not go out and have fun with it
Old 11-04-2002, 09:08 PM   #4991
Patella: You have PM
Old 11-04-2002, 09:19 PM   #4992
got it! Mo powa comin your way!
Old 11-04-2002, 09:36 PM   #4993
Default negative diff questions
what weight oil are you guyz using in your negative diff?
Also - is the diff supposed to come with all the parts that are in the diagram? Mine only had one outdrive and no gears - is this normal?
Finally - are there any tricks to adjusting it?
Old 11-04-2002, 09:41 PM   #4994
how do i post an image that's on my comp or add an attachment?
Old 11-04-2002, 10:19 PM   #4995
DCR1TWO's Avatar
No Prob. I think, the only thing you will have to worry about with the Low CG tank is getting it to fit with the stock receiver box. You might have to cut the box a little to get it to fit with the new tank.
To be perfectly honest, I can't tell the difference either, but it looks pretty sweet.
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
