Old 10-21-2002, 09:53 AM   #4786
patelladragger's Avatar
Send a message via AIM to patelladragger
I think AMG is right about NTC3 initial resistance lower.
I ran the pixie in the RR this weekend after losing another dogbone in the v1r (only have that spacer thingy for the one-way in the RR, thought I could get them close enough in the r. Word to the wise, do NOT attempt to run dogbones with a one-way without the spacer inserts, there is no combination of jerry rigged o-rings or track width that will keep them in.)
Anywayz after the qualifiers we were tuning the engines and I drag-raced a MT12 powered ntc3 with the pixie. Now from a standing start he would holeshot me to death every time. At least 4-5 car lengths. But on the racetrack this guy is actually a better driver than me. Off the corner, even low speed ones, the pixie would eat his lunch, would run the NTC3 down like it was a traxxas or something.
Now alot of factors are in there, i'm using a centax, he isn't, my jtech is fat on the bottom, etc. But I'm sure of 2 things - 1)The j-tech pixie is an awesome motor. 2)once rolling the ntc3 drivetrain advantage isn't overwhelming.
patelladragger is offline   Reply With Quote
Old 10-21-2002, 10:08 AM   #4787
dtm
dtm's Avatar
Send a message via ICQ to dtm
Originally posted by Manticore
EP cant give me the excitment of full speed passing between two cars on the straight with just 1cm apart.
Then why buy the GT7? by the time you run it the GT8 will be out!
dtm is offline   Reply With Quote
Old 10-21-2002, 10:21 AM   #4788
Manticore's Avatar
R/C Tech Charter Subscriber
I am considering to run EP again but I hate the troublesome of preparing rubber tires.
Manticore is offline   Reply With Quote
Old 10-21-2002, 10:53 AM   #4789
Default congrats to jimmyD!!1
it looks like Jimmy Deprez has made the A at the paris memorial in vegas!! I hope he runs well. Here is the A main for sedan.
1 - Barry Baker
2 - Ralph Burch
3 - Marty Barnes
4 - Steve Perez
5 - Josh Cyrul
6 - Richard Saxton
7 - Brian Bodine
8 - Jimmy Deprez
Old 10-21-2002, 10:57 AM   #4790
whoops finals JimmyD must've had a mishap. Here are the finals
1/8 scale finals
I think barry and josh are running the FANTOM!!
1 barry baker 118 laps 40.13
2 josh cyrul 117 labs 40.05
3 marty barnes 117 laps 40.07
4 pepe velez 105 laps 40.04
5 sal defazio
6 kevin wiese
7 brian bodine
8 tim long
9 rody roem
10 ralbh burch
sedan finals
1 ralph burch 109 laps 40.19
2 barry baker 108 laps 40.11
3 marty barnes 104 laps 40.03
4 josh cyrul 102 laps 40.11
5 brian bodine 104 laps 40.17
6 tim long 100 laps 40.01
7 steve perez 86 laps 38.09
8 richard saxton 77 laps 31.41
9 jimmy deprez 51 laps 22.44
10 jeff guest 31 laps 12.28
Old 10-21-2002, 03:10 PM   #4791
asd
Send a message via ICQ to asd
Originally posted by kevink2
It's not a bad place to start setup wise. Regarding your HUDY setup you'll need to remove your rear mount, or try taking a hack saw to your HUDY. How come you bought the HUDY, the Integy one is much cheaper.?
well, i got the hudy because of a few resons:
1. everyone i talked to said to get the hudy over the integy due to "quality"
2. my lhs didnt have the integy set up system there..
and yes teh integy is much cheper thant eh hudy. the hudy is 170(canadian) while the integy is 105(candaian). o well, at least i dont have to eyeball everything now
asd is offline   Reply With Quote
Old 10-21-2002, 06:13 PM   #4792
DCR1TWO's Avatar
1/8 scale finals
5 sal defazio
6 kevin wiese
7 brian bodine
8 tim long
9 rody roem
10 ralbh burch
sedan finals
Yeah they were. I just saw a picture of Barry's Car. That's pretty interesting, I didn't even know he raced 1/8th scale.
DCR1TWO is offline   Reply With Quote
Old 10-21-2002, 10:06 PM   #4793
Default Re: 4 stroke super ten
Originally posted by kaozzlord
i know this is offtopic but i need some help,i bought a superten with a 4stroke enine but the engine instructions are in japanese,how do you break in these engines ,what type of fuel do you use and anybody has a good starting set up for this car
any help will be very much appreciatted thanks
You should use 2 stroke fuel. OS recommends at least 18% oil but I wouldn't worry about that. Any quality brand 20 % nitro 2 stroke fuel is fine.
Break-in per OS instructions:
  • Open needle valve 2.5-3 turns out (counterclockwise) from closed.
  • Turn the idle stop screw till the rotor opening is about 1.5mm.
  • Run 4-5 tanks at this needle setting.
  • Close the needle valve 1 to 3 clicks evry 2-3 tanks till highest straight line speed is obtained.
  • If the needle is closed too much the car will slow down. Immediately open the neddle valve 2-3 clicks.
  • When you fine the needlw valve setting that gives you the highest straight line speed, open the needle valve 2-3 clicks.
  • Run the car 3 more tanks at this setting.
Sydewynder is offline   Reply With Quote
Old 10-21-2002, 10:17 PM   #4794
Barry Baker should be running VoneR also.....
ME-student is offline   Reply With Quote
Old 10-21-2002, 11:09 PM   #4795
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
Don't ya think they all should be running V one R's
HEYALIGNMENTGUY is offline   Reply With Quote
Old 10-21-2002, 11:34 PM   #4796
nope... if everyone was running VoneR.. then drivers are the only determinant in a race.. its not going to do VoneR any good!
Old 10-21-2002, 11:45 PM   #4797
kevink2's Avatar
You'll be happy with the HUDY.
kevink2 is offline   Reply With Quote
Old 10-22-2002, 03:19 AM   #4798
AMGRacer's Avatar
I am glad somebody agrees with me here. All the magazines say how quick the NTC3 is on top end, but I just have not seen it yet.
In fact my V1RR is just as quick out of the hole than the NTC3 guys I race. But I do have a centax and they dont.
AMGRacer is offline   Reply With Quote
Old 10-22-2002, 05:24 AM   #4799
Taylor-Racing's Avatar
Agreed. In fact, if the theory of the free drive train were true, it would show up everywhere, and certainly at the top end. My observation is that the TC3 does seem to have "something" going corner to corner in a tight section, and so does the MTX-3 for some reason. It's very difficult to separate driver and car without a big sample to look at.
Drag races are similar - we run a V-one-R & JP. My driver (12 old son) and I have a standing joke for the start of the main. I ask him how many cars does he intend to pass before the first corner. He always says "four" - and he manages to pull this off about 80% of the time. He's just young and seems to have good reflexes.
Taylor-Racing is offline   Reply With Quote
Old 10-22-2002, 05:44 AM   #4800
AMGRacer's Avatar
You have seen a MTX3???
I find the NTC3 definately can carry good corner speed, has great rear traction and has a better setup than the V1R from the box.
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
