Old 10-19-2002, 07:59 PM   #4771
asd
Send a message via ICQ to asd
hi everyone, i went to my lhs today and bought a hudy set up system(man, so expensive for a few pieces of plastic!, lol)
anyways, i was jus wondering if anyone wanted to share an effective set up for a medium traction concrete parking lot, i'll be using 26mm foams all round. i'll be using 42shore in the front and 37in the rear,
my current set up is as follows:
front end~~~
camber: -2degrees
toe in/out: 0degrees
caster: stock caster
schock mounting positions: stock mounting positions
schock weight: stock silicone
rear end~~~
camber: -3degrees
toe in: 2degrees
shock mouting positions: stock mounting positions
schock wieght: stock silicone
thxs in advance
oh yes, one more thing, when i install the set uo system on my v one rr the rear floating body mount gets in the way, the long black plastic that goes across the width of the car, each time i make an adjustment i hace to take off my rear body mount, and ieas on how to rid this problem?
asd is offline   Reply With Quote
Old 10-20-2002, 05:25 AM   #4772
VenomWorldOrder's Avatar
follow this link and go to the trinity set up page. this dude is a hobby shop owner in oz who has been racing for yonks. try his set up and see what you think. i run 80wt front 60wt rear as oposed to the oil he suggests though. i found it works better for me.
there is also srpent set up sheets from another real quick dude. losi etc
i haven't copyed all of it verbatim, this track we race at is a little eclectic when it comes to grip... due to road works going on nearby and blowing crap all over the track
http://members.ozemail.com.au/~cusmod/Carsetup.htm
VenomWorldOrder is offline   Reply With Quote
Old 10-20-2002, 09:16 AM   #4773
asd
thxs, i'll sdee how that set-up does today
Old 10-20-2002, 11:15 PM   #4774
InitialD's Avatar
Originally posted by Manticore
yes, solid axle+front oneway.
I didnt use any brake at all.
Hey manticore, I have a driving style question. I 've heard that some people use drag brakes with a one way front setup. How did you get around the corners without braking?
Also from the video clip, I see that in the middle of a corner, you throttle. Is that how it is suppose to work?
Old 10-20-2002, 11:45 PM   #4775
hurhur's Avatar
With a front one way and solid rear setup, u need to throttle to power your car through a turn. Just roll your car into the turn without braking, apply a smooth throttle to see your car through the turn. Judge the point at which you need to slow down before going into the turn without excessive speeds. Thats my driving style for the above setup and it is subjective to different drivers.
hurhur is offline   Reply With Quote
Old 10-20-2002, 11:48 PM   #4776
kevink2's Avatar
front end~~~
camber: -2degrees
rear end~~~
camber: -3degrees
toe in: 2degrees
thxs in advance
It's not a bad place to start setup wise. Regarding your HUDY setup you'll need to remove your rear mount, or try taking a hack saw to your HUDY. How come you bought the HUDY, the Integy one is much cheaper.?
kevink2 is offline   Reply With Quote
Old 10-20-2002, 11:50 PM   #4777
kevink2's Avatar
Manticore:
Does the Active Diff take diff fluid or does is it run dry? The instructions make no mention of fluid/grease.
Old 10-21-2002, 12:15 AM   #4778
dtm
dtm's Avatar
Send a message via ICQ to dtm
Have you been sending dirty videos around the world again Manticore??!!!!!!
dtm is offline   Reply With Quote
Old 10-21-2002, 01:13 AM   #4779
Manticore's Avatar
R/C Tech Charter Subscriber
only use brake when the car understeer !
from the video, I didnt use any brake at all! the dynamic drag (solid axle) between left and right wheel slow down your car when you turn into a corner.
Hurhur has just described the driving style for the combo.
I wonder why many people said solid axle and front one way is for wide open track !
Manticore is offline   Reply With Quote
Old 10-21-2002, 01:15 AM   #4780
Manticore's Avatar
Originally posted by Novarossi
Guess who the fast guy in this movie clip is?
http://members.optusnet.com.au/rc
file - moon.avi
dtm: yes, manticore did it under the moon !
Old 10-21-2002, 01:58 AM   #4781
Manticore's Avatar
Originally posted by kevink2
Manticore:
suggest you to put metal protection agent which is kind of soft paste type as you can ajust the stiffness of the active diff.
Old 10-21-2002, 07:55 AM   #4782
dtm
dtm's Avatar
haha.....aren't you bored of running the only fast car on the track yet???? When are you coming over to EP!!!!!??????
Old 10-21-2002, 08:54 AM   #4783
kevink2's Avatar
Sounds good, will do, thanks!
Old 10-21-2002, 08:58 AM   #4784
Manticore's Avatar
EP cant give me the excitment of full speed passing between two cars on the straight with just 1cm apart.
Old 10-21-2002, 09:07 AM   #4785
PeterCheung's Avatar
Send a message via ICQ to PeterCheung
PeterCheung is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
