Old 10-13-2002, 02:05 AM   #4696
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Originally posted by AMGRacer
So.................................
You think 35/30 is way off???
AMG, I used to run these years ago. The pinks are similar to 37s GRP and the fronts are like a 42s GRP. 35/30 is way too off. Im sure the Proline Greens are closer to a 30. Purple/Pink Prolines were like the the tyres to 'have' about 4 years ago at most carpark tracks.
Michael_T is offline   Reply With Quote
Old 10-13-2002, 02:35 AM   #4697
AMGRacer's Avatar
OK cool. Got my ass handed to me by a damn NTC3 on Saturday (not that bad really but still only 2nd ) Trying to work out what setup difference was........
Anybody know if the stock NTC3 runs stiffer springs than the stock Kyosho springs?
AMGRacer is offline   Reply With Quote
Old 10-13-2002, 02:45 AM   #4698
Pirvan's Avatar
Default no way!
Oh come on AMG!...you were that close before the boards got in the way ...so dun be so hard on yourself..!!>...that was a pretty good race. From what i heard from Andrew...you were getting whipped during the heats!...so 2nd wasnt' bad.
Jeff
Pirvan is offline   Reply With Quote
Old 10-13-2002, 03:03 AM   #4699
AMGRacer's Avatar
Default Re: no way!
Jeff
Hehehe I got hacked REAL good in the first heat (bent pipe ) and then somebody spun in front of me in the straight and I plowed into them!! Then in the 2nd and third heats I made BAD tire choices. So a 2nd in the final was OK I guess
Old 10-13-2002, 05:58 AM   #4700
newbie question perhaps...... i was looking at Ellegi tires online and they seemed to be mounted on Serpent rims, will they fit on Kyoshos and Mugens?
calimassive is offline   Reply With Quote
Old 10-13-2002, 06:35 AM   #4701
Michael_T's Avatar
Yes
Old 10-13-2002, 07:57 PM   #4702
asd
Send a message via ICQ to asd
what foams are everyone running and on what type of traction track do u run them on?
asd is offline   Reply With Quote
Old 10-13-2002, 09:32 PM   #4703
Taylor-Racing's Avatar
Awww, c'mon asd, that's too difficult to answer specifically.
For what "I" might call a medium traction track , assuming GRP rubber, start with 42 fronts and 37 rear.
However, you will have been astute enough to have brought some harder and softer ones with you, 'cos the traction will commonly change as the day progresses.
Taylor-Racing is offline   Reply With Quote
Old 10-14-2002, 06:41 AM   #4704
Send a message via AIM to tone
Default 15 19 gearing
I got my 15 19 gears from HK. But if your runing the 24t pully its only good for BIG tracks. tone
tone is offline   Reply With Quote
Old 10-14-2002, 08:08 AM   #4705
patelladragger's Avatar
Send a message via AIM to patelladragger
tone where did you get your 15/19, like what store? I don't trust just any store in Hong Kong. Anyone know if the superten gearing will work on the v1r? they have a 14 tooth first gear I'd like to try.
patelladragger is offline   Reply With Quote
Old 10-16-2002, 08:07 AM   #4706
Default newbie question
I'm trying to take apart an engine for the first time. Can anyone give me any tips on how to get the rod off crank so I can get the piston/sleeve out? I'm scared to pull on anything too hard. thx
Old 10-16-2002, 09:10 AM   #4707
RC
patelladragger:
Get the sleeve out first by rotating the crank and the sleeve should pop up. If it's tight, use a plastic or soft material stick of some sort to pop it out.
Once the sleeve is out you can pull off the rod.
RC is offline   Reply With Quote
Old 10-16-2002, 10:27 AM   #4708
ok - thanks RC. At least now I know what's needed. But my sleeve isn't coming out at all - I tried getting it up with several things and then figured maybe I'm supposed to unhook the rod first. Hmmmm....
Old 10-16-2002, 10:32 AM   #4709
RC
If you're carefull, you could stick it in the oven for about 5-7 minutes at 350' and the expansion should free up the sleeve.
Add salt to taste.
Old 10-16-2002, 10:35 AM   #4710
nice - will try that tonight. Thanks!!!
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
