Old 10-08-2002, 03:25 PM   #4591
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
Originally posted by autotr8er
Driving skills? Whatever man. Willing to put your money where your mouth is??
Hey look! you need to open your eyes! I did not say Driving Skills, I said Driving Habbit!
Next time please open your eyes before you start bashing on other respectable ppl around this forum!
Ah10 is offline   Reply With Quote
Old 10-08-2002, 03:26 PM   #4592
asd
Send a message via ICQ to asd
good choice on the rbx-12
(P.S., the STS RS12 is like a beast in mah v one rr, it has alot of low end punch and gobs of top end, but i wonder how long till i need a rebuild... )
asd is offline   Reply With Quote
Old 10-08-2002, 07:37 PM   #4593
AMGRacer's Avatar
I run the negative diff on my car all the time, for around 12 months now. I alternate between a front one-way and a front gear diff depending on the track. I usually run 10K oil in the negative diff and run with foam tires on an asphalt track.
Is it better than a standard gear diff, yes.
Is it better than a TCD, dunno never run one.
Is it heavier, sure.
Do I notice it, well not really. My car has just as much if not more punch than all the other guys on the track and better top end. It is for sure more heavy but it does not seem to be holding me back yet.
It is a common misconception about the negative diff that it only locks up when the right wheel spins. This is in fact incorrect. The diff has a centrufugal clutch in it which has no spring attached so any time the diff is rotating forwards these shoes are touching the diff case. As the torque forces on the diff increase (ie. under hard acceleration) it forces the shoes outwards harder against the diff. The same happens when the diff is spinng very quickly. So under hard acceleration and at high speeds the shoes are forced against the diff case hard and prevent the right wheel from spinning as quickly as it would like and adds to the general stiffness of the diff in a similar fashion as adding stiffer oil will.
Can I feel this when driving? Sure can. The car goes into a corner off power very nicely because of the light 10K oil I use then when I gas it hard (and the shoes bite to the case) the diff gets a whole bunch more resistance into it and the car then gets a tendency for mild oversteer (depending on your setup) which makes your tail end corner more quickly and more stable. The basic effect is a more stable tail end under power.
Is the effect mild? Sure is you have to be a good driver and have a well set up car to feel it. The negative diff NEVER locks up the diff like a solid will.
AMGRacer is offline   Reply With Quote
Old 10-08-2002, 08:51 PM   #4594
Pirvan's Avatar
Default Diff Leaking
Hi guys,
How often do you guys rebuild your diffs? Is it common for the diffs to be leaking all over the place. I rebuild mine sometime back and found that the screws holding the diff together (in the rear) not to be screwing in as well as it should be....would there be any solution to that? I gasket seal it but i still found it to be leaking today....both front and back...and that is worrying me.
Thanks for any replies in advance!
Regards
Jeff
Pirvan is offline   Reply With Quote
Old 10-08-2002, 09:01 PM   #4595
Manticore's Avatar
Default Re: Diff Leaking
Originally posted by Pirvan
Hi guys,
Regards
Jeff
ditch the stock 2.6mm self tapping screws and replace them with same length 3mm machine thread screws.
Manticore is offline   Reply With Quote
Old 10-08-2002, 09:02 PM   #4596
Pirvan's Avatar
Default Thanks Manticore
Okie dokes!!...Will try that and see how it goes. So how often should i rebuild it?
Regards,
Jeff
Old 10-08-2002, 09:06 PM   #4597
Manticore's Avatar
Default Re: Thanks Manticore
Regards,
Jeff
it is best to examine the diff once in a while to make sure internal gear mesh good enough to hold the gears up to each others as the metal bevel gears do wear after runs.
Old 10-08-2002, 10:09 PM   #4598
anyone got any foam tire suggestions for the V1rr? Any suggestions as far as type of tires depending on surface or type of track would be great. I'm just planning to drive my V1rr outside my house on the pavement at first, so I guess the stock foams will be fine for that, but I'm not sure what to get for spares. I know the permanent tracks around my house are asphalt, pretty large, and sweeping, i.e. long straights and not so tight turns.
calimassive is offline   Reply With Quote
Old 10-08-2002, 10:50 PM   #4599
kevink2's Avatar
Just see what's available, and what other people are running at the track once you get there (especially the Kyosho or Reflex fast guys, if any). I think most of us prefer like 42 in the front and 40 in the rear, or 40/37's with 26mm width and 30mm width respectively. The stock tires are okay, but they're 35 all around, which can be a little hard to drive for some. For me, Fast tires, Ellegi, and UFRA (all made by GRP)are readily available and fit well. Currently I'm looking for dish type wheels, maybe TRC's (trinity, blah!), to see if the wheels won't warp as easily. 30mm Jaco Nitro Shoes fronts don't fit. Dang, looks like that wheel is beefier
Patella: here's some pics in the following posts of the Integy chassis (and some other stuff):
kevink2 is offline   Reply With Quote
Old 10-08-2002, 10:51 PM   #4600
kevink2's Avatar
anudda:
Old 10-08-2002, 10:52 PM   #4601
kevink2's Avatar
won moah:
Old 10-08-2002, 10:54 PM   #4602
Manticore's Avatar
this is 3 racing chassis
Old 10-08-2002, 10:54 PM   #4603
kevink2's Avatar
anudda won: da rear towa brah!
Old 10-08-2002, 10:55 PM   #4604
kevink2's Avatar
da kine front plate, local style:
Old 10-08-2002, 10:56 PM   #4605
kevink2's Avatar
Ahh thank you Manticore for enlightening us... that's what I was wondering. It's pretty nice, except the motor mount screws still hang down too much.
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
