Old 10-08-2002, 10:09 AM   #4546
autotr8er's Avatar
Originally posted by RC
Can anyone comment on their experience for the rear diff when using a front one-way?
Useful in fast tracks with wide lanes and sweeping turns. Small tracks. 50X100. tracks require slower turns.
In particular has anyone tried or can describe the properties of:
- Kyosho Active Diff Set
*Supposed to be adjustable with a set screw.
Acts like normal differential. Advantage, you can tune the front end to your style of driving and track conditions without changing diff fluids. (still trying to find my preferred style) Note: Do not adjust this until you get the chassis set up first. Useful in the rear as well but I have a negative diff in the rear of mine.
3. Kawahara "Negative" Diff.
*Nice idea but not effective enough, by the time the inside wheel spins enough to engage the shoes, someone just passed you. And although you can further adjust with oil, you're now back to tear down and change fluids.
Get on the gas faster. You can do that with the negative diff. What lines are you driving. You can't determine what exactly is going on unless you are driving identical cars, engines, tires, etc. Only difference would be that the other car is equipped with a standard diff and same shock fluid.
My experiences with the Negative Diff....Incredible Traction. I recommend it. It's the best $80 I've ever spent. I don't know how you come up with your logic, RC but Um... in a wheelspin situation, you are still putting power down to at least one tire for a second, the clutch shoes on the diff engage only if one of the tires break traction. If you have both going then there is no need for the clutch to engage.
There is one small disadvantage, weight. But a couple of ounces on a 1hp motor is negligible. Accelerate sooner coming into a long straight. The only thing slowing you down at that point is aerodynamics on the body and the top speed of the motor. Does anyone race on a track with a straight longer than 150 ft?
Decide for yourselves, If there wasn't a distinct advantage, Kawahara wouldn't produce it. People wouldn't be buying it either. If you look at the machining, it is top notch and very intensive. A lot of thought went into this little device. It's not for everybody, everyone has a particular driving style.
autotr8er is offline   Reply With Quote
Old 10-08-2002, 10:20 AM   #4547
Manticore's Avatar
R/C Tech Charter Subscriber
forget all about diff ! only use rear solid axle on foam and front oneway !
Manticore is offline   Reply With Quote
Old 10-08-2002, 10:23 AM   #4548
autotr8er's Avatar
Good for you Manticore! But, how big is your track? Is it asphalt? Are you running foams? Do you even read the posts? I'm talking about medium to small tracks. Mainly concrete.
Old 10-08-2002, 10:25 AM   #4549
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Just bought a V one r Used, can someone post a good starting setup for a medium traction asphalt track ,not flowing, technical. Running rubber tires.
Thanks.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 10-08-2002, 10:27 AM   #4550
Manticore's Avatar
we run the rear solid axle and front oneway on a small and tight technical track.
I have gone thru 4000+ post on this thread since last August. have you?
Old 10-08-2002, 10:37 AM   #4551
RC
autotr8er:
I was refering to inside wheel spin and the "Negative" diff's lack of mid corner striking power, that is the ability to rapidy change line and accelerate in the middle of a turn (used as a counter move if someone is puttin' a move on you).
With the negative diff, when you change line and punch it, the inside wheel spins before it locks (by design just like a clutch). That little bit of wheel spin (I've found it to be too much) can cost you position in the corner.
It would be better if the clutch engagement was adjustable, but it's not (quikly, or easily).
"Negative" diff; worst $80 I've spent.
If someone thinks the attributes of this diff suits their driving style, email me and I'll sell it to you.
Thanks for the tip on th Active diff up front though.
Anyone tried the TCD gear set?
RC is offline   Reply With Quote
Old 10-08-2002, 10:41 AM   #4552
Ah10's Avatar
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
The Track that Manticore runs is very very technical and tight, I know he is using front oneway and solid axle at the back with foam tires but his car is like planted on the surface, I have a bunch of video clips to support it!
I think it is just your set up or your driving habbit is not suitable to the track you are running that's all!
Ah10 is offline   Reply With Quote
Old 10-08-2002, 10:45 AM   #4553
RAP66's Avatar
DUDE... Manti been around the block more than a FEW TIMES... HE so OLD here he FARTS DUST.
HAHAHAHA
do yourself a favor and read the WHOLE Thread ROOKIE!
LOL!
Rich Pedro
[email protected]
www.rcracing.com
RAP66 is offline   Reply With Quote
Old 10-08-2002, 10:47 AM   #4554
Manticore's Avatar
HAHAHAHA
LOL!
i dont even have a chance to see how I "fart" dust !
Old 10-08-2002, 10:53 AM   #4555
Manticore's Avatar
autotr8er:
I tried the TCD gear set and I cannot feel any difference with a regular diff. The gear set is made of very hard but brittle metal. if you dont frequently renew the TCD fuild your gears will be broken easily.
Old 10-08-2002, 10:57 AM   #4556
Jack's Avatar
i think if your car is setup right..
running oneway and soild will not be any problem in small track ..
Manti's track is pretty techincal and tight i.. not big and huge...
I run a soild axle and frnt onway in my car in a track that is like half of manti track...
Jack is offline   Reply With Quote
Old 10-08-2002, 11:05 AM   #4557
Ah10's Avatar
HAHAHAHA
LOL!
LMAO, if he does that then it will take make like a month to do that! ka ka
Old 10-08-2002, 11:06 AM   #4558
patelladragger's Avatar
Send a message via AIM to patelladragger
manticore can you post your complete setup for solid rear / front one-way? Mine is fast but I have to pay so much attention to keep the rear from coming around.
patelladragger is offline   Reply With Quote
Old 10-08-2002, 11:07 AM   #4559
autotr8er's Avatar
Patella Dragger
Just to inform you and others that are mislead by magazine articles. The term coined by magazines, "rotational mass" is talking about a physics principle called "moment of intertia." Every spinning object has one and varies dependent upon its geometry. I could prove it mathematically but It'd be confusing to all but those that understand physics. The two differentials use the same components inside of them (gears and oil) which makes up the bulk of the mass of the diffs. The differences in the material weight is almost negligible. So the only other weight addition is the clutch mechanism and the weight of the housing. You are looking at a 15% difference in weight, yes. If you are running a 1hp motor the difference in acceleration is so small, you won't notice it. The difference in the amount of power required to turn the negative diff at the same angular acceleration is less that 2%!!!! So, take out the TR, put in a turbo TR and terrorize your local club track.
Old 10-08-2002, 11:11 AM   #4560
autotr8er's Avatar
I'm new to the thread, yes, but I have a double major in Mechanical and electrical engineering. I've worked for Ford, Goodyear and Now in the semiconductor industry. 10 years as an engineer. 8 in the automotive industry. I didn't see you 4000 posts. Looks like you are certainly busy here. I meant no disrespect, really. I just can't stand the little punks in here that always have a smart remark without insight to back up their claims.
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
