Old 10-07-2002, 06:27 PM   #4531
patelladragger's Avatar
Send a message via AIM to patelladragger
Default Re: Which pipe?
Originally posted by RClover
Hi all,
I am about to upgrade to a in-line/one-piece pipe for my RB X12 3 port Turbo...which one to get?
Any comments on Novarossi In-line, RBX12 In-line, RBX15 In-line...
Any of you guys tried out the X12 Turbo Two-Piece pipe yet? According to RB, it has lots of Low End torque and produce High End Speed as well...seems like an all rounder pipe...
Any In-line pipe out there that match or even better than this RBX12 Turbo Two-Piece?
Too sad RB didnt make a One-piece for X12 Turbo...
Since you mentioned X15 I'm assuming you're not needing to be ROAR legal.
See if you can get your hands on a Nova mega ART 2686 inline .15 turbo pipe. It's long and the manifold opening is for a .15 big block so you'll have to use two exhaust gaskets- but believe me - this thing rocks!!!
patelladragger is offline   Reply With Quote
Old 10-07-2002, 09:37 PM   #4532
What foam tyres are good for the V1rr? Any particular brand and/or specific tyres?
calimassive is offline   Reply With Quote
Old 10-07-2002, 11:09 PM   #4533
autotr8er's Avatar
Originally posted by rjl
I know the Kyosho Unis are pricey but they are very tough and outlast all the others I have tried.
Do not use front bones in the rear they will bind and interfere with suspension travel.
Sorry if I seemed a bit snakey but I have at least one a week.
" It just broke." or "It just fell out"
And it's bloody raining.
No worries. I've tried to contact Kyosho about it, but Great Planes is the sole distributor and contact. I don't speak Japanese, so direct is impossible. They should offer the kit with the universals.
I think one reason you constantly see those comments is the Kyosho's are rarely found in the race scene here in the US. They are the car to beat in Europe and Japan. This is the only source of information.
autotr8er is offline   Reply With Quote
Old 10-07-2002, 11:14 PM   #4534
autotr8er's Avatar
Originally posted by deeno_x
Guys..i think the hopup dat rconsale is from eaglemodel.. Http://www.eaglemodel.com .. Its more cheaper than the resale version on the rconsale..I have complete price range in usd....
The hop ups that you see are made by three racing in Hong Kong. Also, I didn't find them at eaglemodel.
Old 10-07-2002, 11:32 PM   #4535
RC
Can anyone comment on their experience for the rear diff when using a front one-way?
In particular has anyone tried or can describe the properties of:
- Kyosho TCD Gear Set
*The Japanese Kyosho site says this is actualy a limited slip differential.
- Kyosho Active Diff Set
*Supposed to be adjustable with a set screw.
The options I have tried are:
1. Stock diff - tuned w/various weight oil
*Pain in the butt to change the fluid
2. Solid rear
*Fast but twitchy
3. Kawahara "Negative" Diff.
*Nice idea but not effective enough, by the time the inside wheel spins enough to engage the shoes, someone just passed you. And although you can further adjust with oil, you're now back to tear down and change fluids.
RC is offline   Reply With Quote
Old 10-07-2002, 11:45 PM   #4536
dtm
dtm's Avatar
Send a message via ICQ to dtm
Originally posted by asd
i got another newb question, lol
if i get a set-up system(integy or hudy), do i need the flat set-up board, and the board decal or just the set-up fixture, thxs
A flat table works just as well!
dtm is offline   Reply With Quote
Old 10-07-2002, 11:48 PM   #4537
Manticore's Avatar
R/C Tech Charter Subscriber
i think you are referring to a glass top !
Manticore is offline   Reply With Quote
Old 10-08-2002, 01:35 AM   #4538
kevink2's Avatar
Originally posted by patelladragger
AMG!!!
Kevin on the integy they might sell more than one chassis like they do with universals. I bought the one that was 7075 and it didn't come with engine mounts or screws so it may not be the same one you have. Take a pic of yours and I can tell you. The one I have was a few tenths heavier than the stock so I haven't installed it.
Okay, I'll try!
kevink2 is offline   Reply With Quote
Old 10-08-2002, 05:07 AM   #4539
what are the advantages of after market chassis's? i.e. Kawaharra racing chassis. Do they improve the car significantly, handling, strength?
Old 10-08-2002, 06:53 AM   #4540
dtm
dtm's Avatar
or Grounded Marble!
Old 10-08-2002, 07:24 AM   #4541
RClover's Avatar
Default Re: Re: Which pipe?
Art No 2686 is a Two-Piece pipe...
Any one notice the In-line pipe from Nova Mega as pictured in the Serpent 705? That thing looks promising...very close to RBX15 Turbo pipe...what do you think?
RClover is offline   Reply With Quote
Old 10-08-2002, 07:36 AM   #4542
2. Solid rear
*Fast but twitchy
I've got the TCD diff but haven't used it in competition so no comment.
The solid axle is fast out of the corner but is very tricky into the corner and makes for a driving style that is very hard on tires. Also solid axle , front one-way makes it harder to get around traffic on smaller tracks unless you're very good because you're not really carrying that much more speed mid-corner. On a sweeping track without many fast hairpins this is definitely the ticket. Actually for an extremely skilled driver with super smooth inputs I'd say this is the ticket for any track based what all I've tried so far - it's fast.
Front one-way with 7000 rear diff is very, very consistent, with awesome corner speed all around - no drama on fast entry into tight corners. I run this with 2.5 to 3mm tire split in v1r with 27 tooth pulley and that car handles beautifully on all types of tracks. I don't think i've rebuilt that diff but once in 8 months. I don't see many people running it set this way but given the way the car handles I really don't want them too anyway
Negative Diff I've stayed away from because of the weight of the setup - don't want to be adding that much rotating mass - would probably negate whatever speed benefits you would get and I don't think it's giving any handling advantage over choosing diff or solid.
One thing that I would like to try is solid rear coupled with solid front. The yokomo guys have hit on a good setup with it and I'm curious how it would work in a v1r(r).
hope this helps - my .02.
Old 10-08-2002, 07:44 AM   #4543
Default Re: Re: Re: Which pipe?
it's not a two-piece pipe I got it on my car right now. I'll take a picture when I can.
Old 10-08-2002, 07:50 AM   #4544
I wouldn't say str8 off that they improve the car's handling - they change the car's handling. The kawahara flexes much less than stock and so to get the attitude of the car the same as I had it with stock chassis I had to make some pretty significant setup changes. When I put on the kawa I needed stiffer springs and sway bars (R not RR). I wasn't really after any handling improvement I was trying to shave weight.
Old 10-08-2002, 09:19 AM   #4545
Manticore's Avatar
or Grounded Marble!
when are you going to bring your grounded marble table to the track?
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
