Kyosho VoneR Thread
#4336
how do u tap it out?
#4337
Originally posted by chippy
Well said AMG
The only hop ups I am running are the Kawahara low engine mounts and smaller fly wheel and side belt tensioner.
Seems to me these changes gave the car a lower roll centre and kept the car flatter in the corners under power...
Well said AMG
did you have any issues of carb clearance using the kawahara mounts? I had to file the deck some to get mine to clear for the collari, now with the pixie it seems i'll have to use the engine mount spacers, but that to me defeats the purpose of having lcg mounts. Just wondering if you had a creative way around it.
Also, in my quest for a lightweight v1r, i've found HUGE weight savings is in the battery. An 1100 mah pack weighs more than a 700mah, which weighs more than a custom pack. I've got the kfactory deck (weighed both fully loaded with all electronics and tubing) with reflex handle and micro battery pack weighing in 5 oz less than stock deck with 1100 mah hump pack.
5 oz may not sound like a lot, but considering i've been scrapin for .2 oz here, .3 oz there, that's A LOT!
Bad news though, pixie for some reason weighs 1.2 oz more than novarossi engine
#4338
pattella
I did not have any prob with the carb on rs12 s5
Just had to grind the chasie as the clutch was hitting...
#4339
does anyone have any web sites on how to modify a rear ex engine? (s1)
#4340
1. It will strike the upper deck and it needs to be ground away a bit. If you actually look at the Kawahara top deck they are already pre-clearanced for you.
2. Most likely the centax clutch will rub on the chassis plate and you will need to relieve it some.
3. Sometimes the brake disk will hit the back of the carb. Just angle it a bit.
Why do you need spacers with the Pixy?
#4341
I have a friend up here who can mod your engines very well, and I can give you some ideas of where to start if you like. Ask kickass about the engine mods if you like he has seen them.
#4342
#4343
Originally posted by asd
ahhhhhhhhhhhhhhhh!
i stripped 2 of the threads on my crankcase, where the screws that hold the heatsink on!
what do i do? there is a masive airleak if i only use 3 of the 4 screws, help!
ahhhhhhhhhhhhhhhh!
#4344
i just want to learn about the actual modifications. i don't just want to send it away and get it done. what about that motorman dude? you recon his tips are reliable?
#4345
how do i retap the hole?
#4346
Anyone got tips on maintaining/relubing one-ways??
Also, why did Kyosho change the Ackerman on the RR?? No wonder I didn't have as much low speed steering steering!
#4347
nope, sorry,
anyhow, any of you ever tried the sts .12 rear exhaust motors?
heres a link www.stsrc.com.tw
#4348
#4349
What do you mean about the Ackerman?? I did not notice that it was different to the R version. What part is different??
#4350
ASD go and get a new crank case and be more careful. There is very little space to re-tap oversize in the OS case. The STS motor is very good, I have had very good results with this engine.
