Old 09-28-2002, 06:41 AM   #4321
asd
Send a message via ICQ to asd
which alu. hubs do i get?the wide ones or narrow ones?why?
asd is offline   Reply With Quote
Old 09-28-2002, 01:04 PM   #4322
dtm
dtm's Avatar
Send a message via ICQ to dtm
Originally posted by calimassive
set properly? what do you mean set properly? Everyone seems to have a different way of setting up their car. ...........
rjl is talking about setting your hubs at the correct distance so your dogbones don't fall out!!
dtm is offline   Reply With Quote
Old 09-28-2002, 03:54 PM   #4323
rjl
rjl's Avatar
It will depend on the rims u use and the rear wheel axle, on the RR use standard width. I use Active tyres and the rear rims have 2mm offset, with these rims I use the vz13 wheel shaft and standard width hexes.
rjl is offline   Reply With Quote
Old 09-28-2002, 05:03 PM   #4324
Moderator
Did KYOSHO compete at the worlds? I havn't heard anything about them or there results.
JCTC3 is offline   Reply With Quote
Old 09-28-2002, 06:18 PM   #4325
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
Nope, No factory support, maybe a few privateers
HEYALIGNMENTGUY is offline   Reply With Quote
Old 09-28-2002, 06:53 PM   #4326
hey DTM, this is my first car, i guess you didnt know that. Annnyywayys, I heard there's a tendency for the rear dogbones to loosen up even when set up properly, I'd like to preempt that problem; that's what i was refferring to.
calimassive is offline   Reply With Quote
Old 09-28-2002, 08:54 PM   #4327
AMGRacer's Avatar
Hopups, always wanting hopups
Anyhow here is my opinions on these subjects:
- KFactory stuff, generally avoid.
- Universals, I never had a problem with dogbones or losing them to be honest. If you keep you car the right width and use o rings in the diffs you should never lose them I never have........... Also universals are WAY more expensive than a whole bag of dogbones.
- Chassis plates, get this as a LAST hopup the stock one lasted me 9 months and is still dead straight.
- Get the alloy hex adapters for the wheels as I hate the stock ones getting stuck in the wheels.
My advice for hopups is simple, dont get any. Drive the stock car and see how it goes. Then come back and ask for specific advice if you find a problem. Eg. patella seems to have had a dogbone issue so he got universals to solve it. I never have had dogbone issues but I have had other issues which patella probably has not had so I got different hopups. Dont just buy hopups to solve issues you may never have. If you have too much cash then get what you want
AMGRacer is offline   Reply With Quote
Old 09-28-2002, 09:46 PM   #4328
chippy's Avatar
Well said AMG
The only hop ups Iam running are the Kawahara low engine mounts and smaller fly wheel and side belt tensioner.
Seems to me these changes gave the car a lower roll centre and kept the car flatter in the corners under power...
chippy is offline   Reply With Quote
Old 09-28-2002, 09:59 PM   #4329
dtm
dtm's Avatar
I was just clarifying what rjl had said since you appear to have mis-interpreted..........
PS- if the rear dogbones are falling out....then it was not set up right in the first place!
Old 09-28-2002, 10:43 PM   #4330
asd
ahhhhhhhhhhhhhhhh!
i stripped 2 of the threads on my crankcase, where the screws that hold the heatsink on!
what do i do? there is a masive airleak if i only use 3 of the 4 screws, help!
Old 09-28-2002, 11:18 PM   #4331
dtm
dtm's Avatar
You're out of luck.......junk the engine and buy a NR, at least it is more difficult to strip 3mm thread compared to 2.6mm!
Alternatively you could try and cut 3mm thread into the OS.........
Old 09-28-2002, 11:20 PM   #4332
asd
could i jjust use a longer screw with the same diameter?
Old 09-28-2002, 11:23 PM   #4333
dtm
dtm's Avatar
You could try...as a short term measure....but that screw may only be holding on by a couple of mm of thread engagement, since you have a blind hole there.....so eventually it would give up.
Old 09-28-2002, 11:25 PM   #4334
asd
ok, but a new engine will be another 300 dollars canadian down trhe drain, lol
any other suggestions?
Old 09-28-2002, 11:29 PM   #4335
dtm
dtm's Avatar
Tapping it out to 3mm would be a good alternative!
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
