Old 09-25-2002, 08:34 PM   #4231
AMGRacer's Avatar
It depends ASD. When is the crackling noise when the steering is at its fullest extension left and right or when it is moving normally?
AMGRacer is offline   Reply With Quote
Old 09-25-2002, 08:42 PM   #4232
patelladragger's Avatar
Send a message via AIM to patelladragger
Default LOOK WHAT THE POSTMAN DRAGGED IN
patelladragger is offline   Reply With Quote
Old 09-25-2002, 08:42 PM   #4233
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by asd
ok, thxs, u sure its the steering rite, cause i dont think there are any linkages on steering,?
cause its like a crackling sound
the noise is normal when the servo is on loading.
Manticore is offline   Reply With Quote
Old 09-25-2002, 09:20 PM   #4234
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
Originally posted by patelladragger
hey can you get that Ronnie's stuff anyplace other than ashford? I can't seem to find anywhere that I can order it quick.
asd- the 24 tooth conversion changes the final ratio of the car and sets it up for more top speed. Seems to me you would lose a lot of punch, but I dunno, i've never done it. You change the 19s to 24s and use yokomo belt.
I got my Ronnie grease from Horizon Hobbies
HEYALIGNMENTGUY is offline   Reply With Quote
Old 09-25-2002, 09:22 PM   #4235
Originally posted by Manticore
kakaka, send me an engine !!
who is kakaka, and do you wan't me to send you an engine?
Old 09-25-2002, 09:35 PM   #4236
COOL! I put an order in and they ship priority. They also had clutch shims for a good price too. I've heard about this ronnie grease before - so at 4 bucks I figure its worth a try. Thanks...
Old 09-25-2002, 09:40 PM   #4237
you are welcom.........so hows the search for a 1/8th
Old 09-25-2002, 10:03 PM   #4238
Patelladragger:
Does the pilot shaft on you Pixi move like .5-1mm when you push pull on it?
elnitro is offline   Reply With Quote
Old 09-25-2002, 10:08 PM   #4239
AMGRacer's Avatar
Originally posted by elnitro
Patelladragger:
Almost all engines do this when there is no flywheel attached. It is the clearance of the crank pin and the backplate you can feel. Once you put a flywheel on and crank it down there should be no or very minimal play.
Old 09-25-2002, 11:51 PM   #4240
dtm
dtm's Avatar
Send a message via ICQ to dtm
Originally posted by VONEREFLEXR
Has anyone used the solid rear axle for the v-one r if so did you have any problems with the lenght of the dogbones being too short, there is no way to space them with o-rings because the rear axle is hollow.
Please Help!!
Silicon fuel tube!
dtm is offline   Reply With Quote
Old 09-26-2002, 12:15 AM   #4241
kakaka is Manticore laughing at you.
kakaka = kekeke = hahaha = ahahaha = muhahaha
Comprende senor?
Sydewynder is offline   Reply With Quote
Old 09-26-2002, 01:01 AM   #4242
Manticore's Avatar
Comprende senor?
kakaka sydewynder !!!
Old 09-26-2002, 01:48 AM   #4243
RClover's Avatar
Default Engine is difficult to start...
Hi Guys,
I am running a X12 3 port Turbo. The engine is difficult to start after running on the track like one tank.
Should i open up the high speed needle more or the low speed needle more?
Is it normal for an engine to behave like this after each hot run on the track? As the heat from the heatsink move towards the carb causing the carb too hot to start ... ?
thanks
RClover is offline   Reply With Quote
Old 09-26-2002, 02:18 AM   #4244
Manticore's Avatar
Default Re: Engine is difficult to start...
Originally posted by RClover
Hi Guys,
thanks
your low end is too lean. set it a bit to the rich side.
Old 09-26-2002, 03:28 AM   #4245
i should be getting my V1rr in the mail any day now. It's my first nitro touring sedan. Anyhow, i think i have my mind set on an RB-X12 engine, but im not sure what pipe and header to get. I heard the Paris ring pipe is good. Any other suggestions?
calimassive is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
