Old 09-25-2002, 12:45 PM   #4216
patelladragger's Avatar
Send a message via AIM to patelladragger
Default Centax Thrust Bearing?
What are you guys using to lube the thrust bearing in your Centax? I've tried motor oil, moly lube for motorcycle chains, high-heat bearing oil - nothing seems to last longer than one run.
help?
patelladragger is offline   Reply With Quote
Old 09-25-2002, 01:47 PM   #4217
where can u get rody modified RB engines? are they avalilable to the general public? Is there a site i can visit?
calimassive is offline   Reply With Quote
Old 09-25-2002, 01:51 PM   #4218
VONEREFLEXR's Avatar
Has anyone used the solid rear axle for the v-one r if so did you have any problems with the lenght of the dogbones being too short, there is no way to space them with o-rings because the rear axle is hollow.
Please Help!!
VONEREFLEXR is offline   Reply With Quote
Old 09-25-2002, 02:01 PM   #4219
RC
VONEREFLEXR:
To space the axles you can use the foam cylinders from the front bumper (the ones that you push out when it's new to install) for inside the axle and o-rings for the wheel shafts.
RC is offline   Reply With Quote
Old 09-25-2002, 02:03 PM   #4220
Data's Avatar
Please Help!!
you must be using the Kyosho solid axial, i had the same problem when i was using it. i end up filling the the hollow shaft with RTV and it worked pretty good.
Data is offline   Reply With Quote
Old 09-25-2002, 02:24 PM   #4221
asd
Send a message via ICQ to asd
hey guys, whats this talk i see on forums about a special 24tooth pulley conversion that supposedly makes ur car go alot faster?
asd is offline   Reply With Quote
Old 09-25-2002, 04:45 PM   #4222
kevink2's Avatar
Default Re: Centax Thrust Bearing?
help?
I'm just using Associated black grease. It still gets flung off after two runs, but that's not unusual. It's a high maintenance area in most cars, anyway.
kevink2 is offline   Reply With Quote
Old 09-25-2002, 05:52 PM   #4223
kevinK2
Nice meeting you at SoCal last weekend. How did you do in the RD Logics race?
Sydewynder is offline   Reply With Quote
Old 09-25-2002, 05:56 PM   #4224
Patelladragger
I use Ronnie's green grease for the Centax. I elieve Racer's Edge makes a Hyspin lube for.... high spin.
Old 09-25-2002, 06:01 PM   #4225
asd
anyone?
Old 09-25-2002, 06:40 PM   #4226
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by Sydewynder
Patelladragger
that's "racer's choice" instead !! you are old enough to forget the name I believe !
Manticore is offline   Reply With Quote
Old 09-25-2002, 06:49 PM   #4227
hey can you get that Ronnie's stuff anyplace other than ashford? I can't seem to find anywhere that I can order it quick.
asd- the 24 tooth conversion changes the final ratio of the car and sets it up for more top speed. Seems to me you would lose a lot of punch, but I dunno, i've never done it. You change the 19s to 24s and use yokomo belt.
Old 09-25-2002, 07:34 PM   #4228
asd
ok, thxs patella, i guess i wont use it since my track is pretty tight and twisty, thxs
guys, when i set my epa to full on steering, i hear cracking noises when the the steering servo moves right and left, is this straining the servo and do i need to tone down the epa on my steering servo?
thxs
Old 09-25-2002, 08:03 PM   #4229
yeah man turn down the epa so that the servo only attemps to rotate as far as the linkage will allow. You're right you're just straining your servo, draining your batts, and weakening the parts on your car if you don't.
Old 09-25-2002, 08:14 PM   #4230
asd
ok, thxs, u sure its the steering rite, cause i dont think there are any linkages on steering,?
cause its like a crackling sound
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
