Old 09-19-2002, 03:14 PM   #4081
On the Integy website there's the 19.99 swing shafts/universal shafts and the 29.99 universal shafts. Other than the 19.99 ones being chrome what is the difference? Patelladragger, I think you were the one that recommended the 29.99 ones. How they working out for you? Moreover, I think i've decided on getting a VoneRR, though im sure the front one way is gonna throw me for a loop driving wise. Oh well, I'll deal. Anyways, I was a bit worried about this rear dogbone problem. It worries me a bit that Kyosho made such a basic mistake in design. I'm of the opinion that a performance car should function flawlessly with just stock parts and that hop ups should only be nessacary to increase performance rather than for solving fundamental design problems with the car. Oh well, if these Integy universal shafts solve the problem i guess ill live. I've made up my mind already anyways that im getting the V1rr. Patella you there???
calimassive is offline   Reply With Quote
Old 09-19-2002, 04:39 PM   #4082
patelladragger's Avatar
Send a message via AIM to patelladragger
rjl posted the deal on the rear dogbones a while ago. you don't need to use anything but the stock bones if you build the rear-end right. I bought my V1RR used, and I didn't completely rebuild pieces that I didn't think needed rebuilding when I got it. I like to run 32mm+ when I'm not having to be legal so I would have put wide on anyway.
The 19.99 part I believe is the three racing universal and it's smooth but weak. It will bend pretty easy. I don't know who makes the 29.99 one but they're awesome.
patelladragger is offline   Reply With Quote
Old 09-19-2002, 05:55 PM   #4083
rjl
rjl's Avatar
Sorry if my abreveation caused any offence. It was not meant to be pollitical. I was refering to tyres not ppl.
Anyway try using the same shore rating front and rear but be mindful that fronts and rears are different compounds.
rjl is offline   Reply With Quote
Old 09-19-2002, 07:27 PM   #4084
RClover's Avatar
Default Rear Spring
Has anyone tried the Rear Yellow Spring made from Five Stars?
Is this the softest spring?
RClover is offline   Reply With Quote
Old 09-19-2002, 07:29 PM   #4085
asd
Send a message via ICQ to asd
on saturday i will (pretty much for sure) be buying a set of Take OFF 64MAX 47mm titanium trnbuckles unless anyone has anything to say about it
asd is offline   Reply With Quote
Old 09-19-2002, 08:09 PM   #4086
asd
hey, i was just tweaking with mah set up for mah 4th race on sunday and i noticed that the rear dogbones are very loose, should i put an o ring in each of the rear diff joints?
Old 09-19-2002, 10:55 PM   #4087
Bounty Hunter's Avatar
Default In need of some assistance
I am in need of some assistance. I am building my new V One RR and on Step 2 the front one-way seems to be missing the Onway collars. I have looked through Bags 1, 2, and 3 and have had no luck on finding them. Has anyone else had these collars missing from the kit????
Bounty Hunter is offline   Reply With Quote
Old 09-19-2002, 11:11 PM   #4088
rjl
rjl's Avatar
Default Re: In need of some assistance
The collars are on the parts tree with the battery bracket. See page 6 part No. 176.
Old 09-20-2002, 04:00 AM   #4089
Default DUh....
Well maybe I just need more practice on reading instructions. Thanks for the pointer, I found them right where you said they would be. Next time Ill remember to smack myself upside the head first before I spout off again.
Old 09-20-2002, 07:08 PM   #4090
asd
anyone got a setup for the v one rr, i'm using os 12 tr, airtronics mx-3, everything else is stock, ohh, rubber stock tyres as well,
Old 09-20-2002, 07:36 PM   #4091
RAP66's Avatar
Believe it or not the stock setting works very well... I did increase the oil to 70wt on all 4 shocks, then tweek the sway bars to dial in the car. Rubber Tires I like using Yokomo MED or Firm Sprints with the Ride C-30 insert.
Rich Pedro
[email protected]
www.rcracing.com
RAP66 is offline   Reply With Quote
Old 09-20-2002, 07:47 PM   #4092
asd
k, i got a questiuon, when put mah car on the ground the front seems a lot higher thna the rear, i even tried moving the spring adjuster to 10mm and even then it only raises less than1mm over the front, it seems like the front is always moving higher!!
Old 09-20-2002, 09:18 PM   #4093
can anyone post a pic of there kyosho V1rr? I can find only 2 pics on the web of a V1rr. thanks...
Old 09-20-2002, 09:39 PM   #4094
asd
i would if i knew how do download pics off my digi cam, lol
sorry
Old 09-21-2002, 12:35 AM   #4095
chippy's Avatar
here you go
chippy is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
