Old 09-07-2002, 07:47 PM   #3916
DCR1TWO's Avatar
Originally posted by dtm
Don't do it...the Kawa wide bumper is good for looks...not very good for impacts...breaks up too easy. Stick with the RR wide bumper..........
Thanks for the info. I'll probably get the Kyosho one.
DCR1TWO is offline   Reply With Quote
Old 09-07-2002, 10:44 PM   #3917
asd
Send a message via ICQ to asd
did any of u guys get 2 "flanged bearings" in ur kit?
i did, but it doesn't say anywhere in the manual that i need them
plz reply
asd is offline   Reply With Quote
Old 09-08-2002, 12:29 AM   #3918
Data's Avatar
plz reply
belt tensioner
Data is offline   Reply With Quote
Old 09-08-2002, 01:05 AM   #3919
asd
ok, thxs
Old 09-08-2002, 06:16 AM   #3920
rjl
rjl's Avatar
Asd the flanged bearings are for the side belt tentioner, refer to your instructions. I've probably built 100 or more cars now and still follow them, they are very important, the instructions that is, if your vonerrrrrrr is built as per the instructions it will work very well, if your car is built the way you think it should be built it will not work. I have a little hobby shop in OZ and none of my costomers have cars that don't work, get help!!!!! We could probable solve your problems very quickly if we could see what you have done.
When I assemble a kit I use digital verniers, when the instructions indicate an aproximate measurement my car starts within .03mm of that aproximate measurement.
I can't help myself, today I had a really good race with some of Oz's best tallent, I set the fastest lap of the day.
rjl is offline   Reply With Quote
Old 09-08-2002, 09:49 AM   #3921
asd
very cool, i fixed ALL my problems(at least the ones i caused, lol)
and i'm taking her out again today to see how she runs, ohhh, gy the way, should the cap screw that has the thrust bearing and bell guide washer be loose?
cause it saays that in the manual, but i'm afrasid it willl vibrate out, what should i do?
Old 09-08-2002, 12:52 PM   #3922
kevink2's Avatar
Don't know how your friends drive but I had no problems with my bit of bent wire on the MTX2.......it may not look pretty but it does the job good!!
Lots more stress on the drive train on a 1/8 car. They aren't breaking in crashes but under acceleration. Kawahara has an answer, but not easy to find. I guess we're getting off topic..
kevink2 is offline   Reply With Quote
Old 09-08-2002, 04:09 PM   #3923
asd
hey everyone, i used threadlock to hold the cap screw into place, the one that holds the thrust bearing, because it kept vibrating loose
anyhow, guess what!
i finished breaking in my engine at around 1:00p.m.
and then at around 2:30p.m. went for a race at a club, man, does this biatch go fast or what!, i qualified 3rd! and finished 2nd! the guy in first place had an accident in the 20 minute A main which brought 2nd place to first, and me from 3rd to second, i felt very comfotabe with the stock setup, i had no crashes or any problems, and i was using a stick acoms techniplus 2 channel am radio!lol
anyhow, i fell that the v one rr is quite a bit heavier than most other cars, how can i solve this problem and what is the most vital hop-up u guys recommend for performance?
again, thxs in advance
Old 09-08-2002, 09:21 PM   #3924
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
anyhow, guess what!
Zac Head
HEYALIGNMENTGUY is offline   Reply With Quote
Old 09-09-2002, 01:14 AM   #3925
DCR1TWO's Avatar
How are you guys setting your ride heights with foam tires to account for tire wear during the main. I usually set my ride height between 4-5mm, but I don't want to be dragging the chassis by the end of the main.
Old 09-09-2002, 04:07 AM   #3926
rjl
rjl's Avatar
I try to finish with 3-4mm, during a long final I may need to start at 6.5mm rear 5-6mm front.
Old 09-09-2002, 06:09 AM   #3927
Send a message via Skype™ to JordanC
I thought that's about where you finish the final hey rjl..... Nothing like 4WDing over the bumps at Dandy....
JordanC is offline   Reply With Quote
Old 09-09-2002, 06:18 AM   #3928
asd
thxs heyalignimentguy
Old 09-09-2002, 06:23 AM   #3929
patelladragger's Avatar
Send a message via AIM to patelladragger
anyone tried the kyosho adjustable rear diff? Does it work well?
patelladragger is offline   Reply With Quote
Old 09-09-2002, 06:48 AM   #3930
Taylor-Racing's Avatar
You need to make some judgment during the heats as to the expected tyre wear.
For the half hour final yesterday, we started at F/R 5.mm/5.5mm and finished at F/R 4mm/4.5mm.
A bit of a miscalculation on my part - had expected to lose more than 1mm
Taylor-Racing is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
