Old 09-07-2002, 09:03 AM   #3901
asd
Send a message via ICQ to asd
how do i adjust the clutch?
asd is offline   Reply With Quote
Old 09-07-2002, 09:22 AM   #3902
DCR1TWO's Avatar
Loosen or tighten the clutch nut spring. Read your Manual.
DCR1TWO is offline   Reply With Quote
Old 09-07-2002, 09:26 AM   #3903
asd
the clutch bell wont come off!
grrr
Old 09-07-2002, 10:05 AM   #3904
RClover's Avatar
Default Need extra force...
grrr
u need extra strenght to force the clutch bell out. E.g. Use a screwdriver to do it. Must be gentle and prise the the clutch bell at different spots. Rotate the flywheel and slowly. Else u will damage the flywheel and clutch bell. I suggest u use a cloth to cover the tip of your screwdriver...to avoid the damage...
RClover is offline   Reply With Quote
Old 09-07-2002, 10:29 AM   #3905
asd
thxs guys, but i think i found the problem
the one way baering is backwards!
how do i take out the onw way bearing?
Old 09-07-2002, 10:30 AM   #3906
RClover's Avatar
Default Problems...
clutch problems, help!
hey guys, i have a v one rr and an os 12 tr, when i get my engine fired up everything seems fine but it goes REALLY SLOW!
and, should the 2 speed and clutch stay still when i move the car forward and backwards with my hands?
diagnosis?
plz, i need help
thxs in advance
peace out
the reason i need to know is because i'm having my first race today with the v onerr
plz, i beg of u, reply!
I had the same problem before. Dont worry...
Take out the engine first from the chassis. Check the Clutch Bell on the Engine is spinning freely. If the clutch bell doesnt spin freely, you need to disassemble the engine clutch and build it again according to the manual.
Then you need to disassemble the 2-speed system. Take out both the Spur gears and 2 speed clutch. Assemble them again.
NOTE that when u re-install the 2-speed clutch on the 2 speed shaft. u need to push the clutch right in the end towards the rear bulkhead, and make sure you tighten the screw on the FLAT section of the 2-speed shaft. U may apply a some 'Tread Locker', just a little will do to make sure the clutch stay in that position.
Then Assemble the Spurs and again make sure both the spurs are inserted towards the inside (push them right to the end with left hand pushing the 2-speed shaft on the left at the pulley. This is to make sure there is NO GAP between the 2-speed clutch and the both the spur gears....
Then, install the rest according to the manual. BUT make sure there is no gap in between the clutch and spur gears. U can cross check when shaking the 2-speed shaft if it moves. The shaft should NOT move and it stays in perfect position.
Now, put in the engine and try roll the car forward and backwards, both spurs and pinions should move and not binding.
NOTE that when the car rolls backwards, the Spurs should spin freely.
When roll forwards, the spurs will move and turn the clutch bell.
Hope this help...
Old 09-07-2002, 10:36 AM   #3907
RClover's Avatar
Default Oh no...
The one-way bearing should not be taken out. It is fixed on the 1st spur housing permanently. Kyosho fixed it just to avoid we assemble the wrong direction...!!!
Check the manual....
Old 09-07-2002, 10:55 AM   #3908
asd
thanks a ton
Old 09-07-2002, 10:59 AM   #3909
asd
hey rc lover...
u said
"NOTE that when the car rolls backwards, the Spurs should spin freely.
Hope this help..."
when I move the car forward, teh spurs spin freely, when I roll teh car backwards teh spurs move and turn the clutchbell
Old 09-07-2002, 11:01 AM   #3910
patelladragger's Avatar
Send a message via AIM to patelladragger
Cool
good work RC lover - you have more patience than most
patelladragger is offline   Reply With Quote
Old 09-07-2002, 11:13 AM   #3911
asd
haha
very funny, so what if i'm a complete idiot with no brain
lmao
Old 09-07-2002, 11:57 AM   #3912
DCR1TWO's Avatar
Does anyone know a source for Kawahara products? I've been trying to find the wide bumper for the V-one R. I tried speedtech with no luck.
Old 09-07-2002, 01:06 PM   #3913
dtm
dtm's Avatar
Send a message via ICQ to dtm
Don't do it...the Kawa wide bumper is good for looks...not very good for impacts...breaks up too easy. Stick with the RR wide bumper..........
dtm is offline   Reply With Quote
Old 09-07-2002, 03:17 PM   #3914
rjl
rjl's Avatar
ASD go back to the manual and make sure everything is set accordingly. If you still have problems take your car to your local Hobby shop or track and ask for help.
rjl is offline   Reply With Quote
Old 09-07-2002, 06:30 PM   #3915
asd
hey guys, i had mah first race with the v one rr
let me tell u, this car kicks ass!
but.........at about 2 mins(maybe less) into the first qualifier, one of the "3D weights came out and i had to remove the enitre clutch and 2 speed tranny, then in the first main, the clutch shoes came out again!!!
anyhow, i think i might just get a normal clutch, would the clutch on the original V One R work?, would i need to get a new flywheel?
thxs in advance
peace out
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
