Kyosho VoneR Thread
#3826
Originally posted by Sydewynder
Well 500 yen is about 3.70USD or about 28HKD retail. Hmmm someone wanted to sell HAG that for 12USD.
US$12 is overkilled !!!!
#3827
Do you see the "All Rights Reserved" in the picture AMG? Do you know what that means?
10 minutes to cut 1 1/2 tires? I think I've seen HAG do it in like 2 minutes. Man you must work for the government.
#3828
Originally posted by rjl
I use Active tyres, similar rubber to Zac but much stiffer rim.
Agreed, Active's have a much stiffer rim. It's likely the rim stiffness also contributes to the stability these wheels exhibit.
The other side of the coin is that it is possible to break them. We've broken a couple, but a bit of CA glue sees them back in service, just fine.
It's all a compromise. Overall, I'm happier to glue the few breaks than try and fix a wonky one - that seldom works for me.
#3829
Originally posted by AMGRacer
Yeah I make two passes for each cut and shut of the grinder after each to measure. Then I smooth the tire surface with a flat sandpaper block. Lastly I put the rounds back onto the tire edges. Yes I am anal.
#3830
Originally posted by Manticore
no no conversion rate here for yen is like 1000yen = 65 HK$ which is considered as good rate !! i.e. it is about 33HK$
#3831
Alright where are you guys getting Active foams? Are they Action foams?
#3832
The name is "Active"
I get 'em at New Wave Hobbies here in Melbourne, Oz.
They are about the same price as the Zac's.
#3833
#3834
That's what you meant, isn't it?
#3835
I think it means that rcmodel.com.hk declare copyright on a photo of a Kyosho logo that the don't have a copyright to.
#3836
#3837
I am actually a Lawyer (well I have a law degree) so I know what it means I can kinda remember my intellectual property law lectures, at least the ones I was not drunk in
#3838
Well and all along I thought you were a webmaster for ?Meakin??
#3839
Yeah I also have an IT degree as well I build the website in a few hours Sometimes I race RC Cars as well.
#3840
You need to update the points and race results. You might be last by now.
