Old 10-31-2001, 05:56 PM   #361
cornerspeed's Avatar
Hey Steve of speedtechrc- Its Don. I am having a hard time finding the limited slip diffs. made by Kyosho and Kawahara anywhere in socal. My local hobby stores can't find either. I noticed you carry Kawahara, but nothing for the V-one-R. You may be my only hope. Also, clamping wheel hubs.
Thanks,
Don
cornerspeed is offline   Reply With Quote
Old 10-31-2001, 08:10 PM   #362
adelmundo's Avatar
Send a message via ICQ to adelmundo Send a message via AIM to adelmundo
Thanks,
Don
You can try Tower Hobbies (aka Great Planes Model Distributors aka only authorized US Kyosho Distributor). On their website it shows that it is in stock. The link to the site is:
http://www2.towerhobbies.com/cgi-bin...m?Q=1&I=LXAVW8
I have the Kyosho LSD and it really helps performance wise!
adelmundo is offline   Reply With Quote
Old 10-31-2001, 10:58 PM   #363
Dragon's Avatar
Send a message via ICQ to Dragon
hey guys, im thinking of getting a V1R, but do u think i should wait for the V1RR ??
.....are the so called "extra" stuff worth the wait?
Dragon is offline   Reply With Quote
Old 10-31-2001, 11:13 PM   #364
AMGRacer's Avatar
The "problem" with the RR model is that it is made for a very specific "niche" of 1/10 racing. The large rear body mount and the small mounts on the front wide wing make running Lola style bodies a must. If you want to run touring car bodies (or NEED to because of track rules) you will need to buy the standard mounts.
Similarly the front one way is tricky to drive and some tracks may require you to purchase a front gear diff.
So if you want to convert it back to "traditional" 1/10 touring spec you may need to purchase some of the standard V One parts.
After saying this the centax clutch, "handshake" front swaybar, rear swaybar and transponder mount are worth far more than the small price difference. It is up to you what sort of racing class you are going to run in.
AMGRacer is offline   Reply With Quote
Old 10-31-2001, 11:22 PM   #365
Dragon's Avatar
Oh i see....u have cleared the clouds for me....thanks man...now i know which to get..... ....cant wait.....
anyway, being a newbie and all, do u mind telling me what on earth is a centax clutch, and swaybar is?..Thanks.
Old 10-31-2001, 11:49 PM   #366
AMGRacer's Avatar
Wow this car is going to be a handful for a newbie
Anyhow swaybars are devices which make the car roll less. They are useful for tuning your suspension to certain surfaces. You can remove them if the surface is very rough.
A centax clutch is a special type of clutch which is tunable. You can adjust the engagement point of the clutch without taking the clutch off the engine. It also engages much more smoothly and strongly. The downside is that the thrust bearing needs to be regularly maintained.
Old 11-01-2001, 12:06 AM   #367
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Sway bars should be last option/hop-up for fine tuning a car.
The Mugen MRX centax will work on both your V-One-R + MTX Amg.
Another major advantage with this type of centax is that it allows you to run much higher gearing for long tracks (Mugen clutch runs up to a 18/22 pinion combo). The performance of the clutch is alot more consistent + reliable.
Bad news is the price here, $260 for the complete kit
(Note : that you need to use different engine mounts to make the Mugen centax fit onto the V-One-R)
Michael_T is offline   Reply With Quote
Old 11-01-2001, 12:14 AM   #368
Manticore's Avatar
R/C Tech Charter Subscriber
correction, right now i use the kyosho engine mount for the mugen centax on my V1R but need to work on the main chassis engine mount holes. elong the holes with a small file to maximize gear mesh.
Manticore is offline   Reply With Quote
Old 11-01-2001, 01:32 AM   #369
AMGRacer's Avatar
The Fantom centax (which fits the V One R I haev been told) is only $154 I wonder if it will fit the Mugen??
Old 11-01-2001, 02:03 AM   #370
Michael_T's Avatar
The Mugen Centax is acclaimed to be the best in the business. I noticed quite a few Kyosho drivers (including many Aussies) using the Mugen clutch on there Fantoms during the World Champs last month - something to think about
Old 11-01-2001, 02:07 AM   #371
Regional Moderator
I am using the Serpent Centax clutch, but it needs to be modified to fit the V1R.
White cat is offline   Reply With Quote
Old 11-01-2001, 02:12 AM   #372
AMGRacer's Avatar
Now that I did not know. John from RMS can do me a syntec (thats the Mugen one right?) for $200. I will look into the Mugen clutch........
I am not that worried about a centax yet anyhow, I just want to get some good laps under my belt.......
Old 11-01-2001, 02:24 AM   #373
Michael_T's Avatar
The name 'Centax' is actually associated (and invented I think) by Serpent.
The correct 'Political' term for the Mugen Clutch is 'Axial'
If u do decide to run at Brendale (especially if they run the full track) it would be good investment, but as u mentioned, this hop-up can come later on when you master the car and require extra punch/speed.
Old 11-01-2001, 02:26 AM   #374
adelmundo's Avatar
I notice that the Mugen MTX-2 also has a Centax Clutch. Will that fit into the V-One R without modifications? Will the Fantom clutch also fit into the V-One R without modification?
Old 11-01-2001, 02:30 AM   #375
Michael_T's Avatar
The MRX-3 + MTX-2 clutch are exactly the same unit. I have owned both. Only difference is that the spring that comes stock with the MRX-3 clutch is stiffer then the one that comes with the Pro. Everything else is exactly the same.
Im sure Moon said that he needed to run different engine mounts (RPM/GPM or something) to get it to fit on his Kyosho.
Oh and BTW, the Mugen MTX-2 Pro comes standard with the Centax clutch, the standard MTX-2 uses a standard 3 piece clutch.
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
