Old 08-15-2002, 12:22 AM   #3451
rjl
rjl's Avatar
The Kawahara diff has an alloy case, on the right hand outdrive there is a pair of clutch shoes which add resistance to the diff the faster you go. Theoretically it acts as a solid rear end at higher speed. The problem with this diff is the steel out drive wears the diff housing very quickly.
rjl is offline   Reply With Quote
Old 08-15-2002, 01:02 AM   #3452
compaq888's Avatar
Send a message via AIM to compaq888
thanks for the info, so is anybody gonna post some pics?
compaq888 is offline   Reply With Quote
Old 08-15-2002, 06:44 AM   #3453
VONEREFLEXR's Avatar
Question?
As my car accelerates, it pulls to the left. Could this be caused by the front oneway?
VONEREFLEXR is offline   Reply With Quote
Old 08-15-2002, 06:48 AM   #3454
dtm
dtm's Avatar
Send a message via ICQ to dtm
Originally posted by RClover
i am so in love with your bodyshell...this one!
Thank U!!!!
dtm is offline   Reply With Quote
Old 08-15-2002, 06:49 AM   #3455
patelladragger's Avatar
Send a message via AIM to patelladragger
Originally posted by VONEREFLEXR
Question?
na - one way has nothing to do with that. Your suspension is probably set with tweak in it. Get an MIP tweak station or a set of postal scales and make sure your car is balanced
patelladragger is offline   Reply With Quote
Old 08-15-2002, 06:53 AM   #3456
dtm
dtm's Avatar
Question?
Possibly...but also check for dead bearings in the hubs.
Old 08-15-2002, 06:54 AM   #3457
dtm
dtm's Avatar
With age the one way bearings can start to slip (due to wear)....if one goes before the other (which is normal) the car can pull to one side.
Tweak is also another thing you should check!
Old 08-15-2002, 06:56 AM   #3458
dtm
dtm's Avatar
ok - compaq & asd. I dunno, I understand you guys are new and excited, I was there once. But you guys are starting to irritate and you're reducing this thread to rubbish. Why don't you two trade instant messenger ID's and chat? I mean I'm sure everyone here is more than willing to help new guys learn the ropes, but you guys are pushing it.
I would have to agree!!!!
Old 08-15-2002, 07:01 AM   #3459
dtm
dtm's Avatar
Originally posted by Manticore
Front
toe out: 1 to 1.5'
....................................You might need to sit more droop front and rear if the parking lot is pumpy.
No straight shaft?????
Old 08-15-2002, 07:02 AM   #3460
Thanks for bringing that point DTM. Now that I think about it I remember reading where people talked about one bearing failing before the other due to more hits, crashes on one side of the car. I'll remember to check there too if I ever have this problem. Thanks for the info and sorry for the mis-information vonereflexr!
Old 08-15-2002, 07:04 AM   #3461
This is a brand new kit that i am running, with the front oneway and the active diff in the rear, maybe that will have something to do with it,
Old 08-15-2002, 07:35 AM   #3462
Manticore's Avatar
R/C Tech Charter Subscriber
check your dog bones and see if they sit freely. a blinding dog bone/outdrive may cause this problem. also check if you have equal front droop. unequal front droop will cause this problem too.
Manticore is offline   Reply With Quote
Old 08-15-2002, 08:45 AM   #3463
compaq888's Avatar
i dunno guys, the car pulling to the side can be an easy problem to solve, my car used to pull to the side, so i lifted and saw that one of the wheels was slower than the others, this sometime can be solved by... (of course the car has to be turned off) it can be solved by picking ou the car and pressing down on the belt that sits on the diff and then while you are pressing down rotate the wheel on the oppesate side of the wheel that spins slower, that some times takes care of the problem and the wheels spin evenly at the same rate, i think there is a term for this , but i don't know it, maybe manticore can enlighten us
Old 08-15-2002, 08:56 AM   #3464
It's not really that simple, it acts like a rear drive car with a lot of horespower, when it accelerates it loads up the diff and its like one side backspins.
Old 08-15-2002, 09:02 AM   #3465
compaq888's Avatar
did you pick up the car and see if all the wheels are spinning at the same rate????, if one wheel doesn't spin at the same rate as the other 3 try to do what i said in the above post it might help
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
