Old 07-25-2002, 01:07 AM   #3151
hurhur's Avatar
Originally posted by dtm
Oh! They made it an "offical" conversion now!!!!! I guess someone had to make some money from it!
Manticore- Have you got your name on one of those JP 5 ports yet???
dtm, your name on one of those JPs? any idea how much are they?
still contemplating btw a JP or a Mspeed.
i feel the need for speed....do u?
hurhur is offline   Reply With Quote
Old 07-25-2002, 03:36 AM   #3152
dtm
dtm's Avatar
Send a message via ICQ to dtm
Originally posted by compaq888
wow i read some of the stuff here, I going to go with the v one r, cause the v one rr comes with a centex clutch which i never tuned before and a one way, I don't like one ways cause my track has sharp turns, what are the first mods i should get, I heard the front cvd's are a must, after i get the cvd's what should i get after?
errr....an engine!!??
dtm is offline   Reply With Quote
Old 07-25-2002, 03:38 AM   #3153
dtm
dtm's Avatar
I'm running EP now...remember!! Have no interest in these messy noisy engines (not for the next few months anyway!)
The JP 5 port is around HK$21xx mark (ish!)
Old 07-25-2002, 03:43 AM   #3154
dtm
dtm's Avatar
No seriously....you don't "really" need CVDs..... just run the car stock first and see....there are a lot of "nice to look at" options around which does very little to the performance.....ie. chassis, engine mount, alloy pullies, steel handles!! etc...
Actually for the RR, the first thing I would buy is a long steel handle....save you scratching the hell out of your cooling head on the engine!!
Old 07-25-2002, 03:46 AM   #3155
hurhur's Avatar
that is provided he goes Lola. If its sedan, the steel handle serves no useful purpose then. Hmmm....maybe as a secondary heatsink
Old 07-25-2002, 03:48 AM   #3156
hurhur's Avatar
$21xx!!!
Oh my dear!
Old 07-25-2002, 03:52 AM   #3157
compaq888's Avatar
Send a message via AIM to compaq888
I know, i'll be getting the RB x12, i'm not a newbie, i was talking about the hop ups on the car itself.
compaq888 is offline   Reply With Quote
Old 07-25-2002, 04:03 AM   #3158
VenomWorldOrder's Avatar
the rr is worth the extra bucks.
you can still drive a one way on a small track, it might even make you a little quicker as it will force you to enter smooth. (ie taking better lines)
just set the castor way back so you can throw it into the corners just take every corner a little wider than normal.
i recon cvd's are worth the cash. they don't pop out like dogbones. so if you have a hard hit to the front tires you won't have to retire from the race from a poped out dogbone.
VenomWorldOrder is offline   Reply With Quote
Old 07-25-2002, 04:17 AM   #3159
compaq888's Avatar
my track is big and has a lot of sharp corners so i'll think i'll stick to the v one r, plus it's like $100 less
Old 07-25-2002, 05:10 AM   #3160
what about the centax? it makes a HUGE difference.
Old 07-25-2002, 06:05 AM   #3161
compaq888's Avatar
I know it does, but it won't make such a big difference when I will have an rb x12 and the other guys run ntc3 and some mugen mtx2, if i'll need it i'll buy it, i need to get the hang of this car first i might get it as soon as 2 weeks. I might start racing in January, i got to practice first.
Old 07-25-2002, 06:54 AM   #3162
dtm
dtm's Avatar
The centax will make a big difference! The options will add up if you upgrade from the R..... in the long run the RR is actually cheaper. Front one-way has no problems with tight turns, in fact if you run on a large track with sharp hairpins, then a front one-way with solid rear "axle" will be almost unbeatable! You would just scarifice a bit of tire wear!
Solid rear axles only have problem when it comes to a series of tight turns. Sometimes it is worth scarificing those turns for the rest of the track.
Old 07-25-2002, 07:19 AM   #3163
compaq888's Avatar
I dunno i'll have to think about that, cause i heard you press the brake and the car spins out cause of the one way, and i never worked a centrex clutch
Old 07-25-2002, 07:53 AM   #3164
dtm
dtm's Avatar
You can have a 'light' level of brake with a rear diff. With a solid axle you can actually use quite heavy braking. Anyway, what do you want to brake for??? never have much cause to use it with a front one-way...you get plenty of turn in!!
Old 07-25-2002, 08:00 AM   #3165
compaq888's Avatar
i don't know there is the part of $125 more for the kit!
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
