Old 07-08-2002, 07:52 PM   #3016
icon's Avatar
Send a message via AIM to icon
The V One RR shocks have different rod ends for the shock shaft and also they are mounted via a long grub screw and then a ball is screwed onto it.
The RR's rear suspension geometry is completely diffferent from the R. It has a more laid down shock position by using a new shock tower. Because of this new design the bulkhead brace for the rear is also different.
As for the dogbone and axle, you dont need to change over to the shorter units if you dont plan to run 30mm foams. the RR dogbones are shorter w/ longer axle to accomodate for 30mm foams but still maintaining a 200mm width.
icon is offline   Reply With Quote
Old 07-08-2002, 09:13 PM   #3017
Default Solid rear axle
What is the advantage of using solid rear axles like the Kawahara unit? I saw pix from the Sedan Nats and a few factory drivers are using it.
elnitro is offline   Reply With Quote
Old 07-08-2002, 10:12 PM   #3018
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
Originally posted by Manticore
I am here I am here, What's up man?
Nothing much here, Just have not seen you around this thread in a wile, was missing some of that wisdom you spread
HEYALIGNMENTGUY is offline   Reply With Quote
Old 07-08-2002, 10:38 PM   #3019
Manticore's Avatar
R/C Tech Charter Subscriber
Here is another wisdom I want to share !
Manticore is offline   Reply With Quote
Old 07-08-2002, 10:49 PM   #3020
Hey Nice wisdom, must be yours
How about some gearing knowledge I would like to get some more punch when I launch the car, mostly in 1st gear
1 should I change my spur to a larger gear, If so what part# is it
2 get a centax clutch
wisdom always appreciated
Old 07-08-2002, 10:50 PM   #3021
Jack's Avatar
anth. what part are need if i want to use sedan body on my RR???
Jack is offline   Reply With Quote
Old 07-08-2002, 10:52 PM   #3022
Manticore's Avatar
centax clutch is always a good choice to improve performance. I use mugen clutch for my V1RR.
there is not much choice for V1RR spur gear. standard is 44/48. Options are 1st gear 47 and 49 and 2nd gear is 45.
Dunno about the part number
Old 07-08-2002, 10:53 PM   #3023
Jack's Avatar
HAM
i think u will get more punch if u change to the centax....
it so much diff frm the stock clutch...
Old 07-08-2002, 10:58 PM   #3024
Old 07-08-2002, 10:58 PM   #3025
Jack's Avatar
part num for kyosho centax is VZ090...
Old 07-08-2002, 11:01 PM   #3026
Originally posted by Jack
HAM
Can I call you Samuri
Old 07-08-2002, 11:02 PM   #3027
I have been thinking of trying the Kawahara one
Old 07-08-2002, 11:07 PM   #3028
Manticore's Avatar
check with ah10, he is running with the kawahara ss clutch. I have both kawahara clutch for V1RR and MTX2 but I am too lazy to put them on.
Old 07-08-2002, 11:23 PM   #3029
hurhur's Avatar
hurhur is offline   Reply With Quote
Old 07-08-2002, 11:25 PM   #3030
Jack's Avatar
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
