Old 06-03-2002, 10:37 PM   #2866
Data's Avatar
Originally posted by Manticore
Let me BEAM BEAM my Lo Chan !!
Commander Data's Log, Stardate 200206.03
Trade route of Ekosian foam tire had been badly disrupted by the Ferengis. Supply of Ekosian foam tire is very low in the LA sector. Star Fleet Command estimated the situation would become critical in about six Stardays. Need to establish temporary trade route through the HK quadrant until the normal trade route is restored.
End of Log
Data is offline   Reply With Quote
Old 06-03-2002, 10:51 PM   #2867
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
I know this is not the place but the new smilies ROCK
HEYALIGNMENTGUY is offline   Reply With Quote
Old 06-03-2002, 10:51 PM   #2868
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
End of Log
What in the world are you talking about?? anyway welcome on board
Ah10 is offline   Reply With Quote
Old 06-03-2002, 11:12 PM   #2869
Data's Avatar
I only have one set of front tire left, don't know what to use for the rear this weekend. The tires I ordered from HK won't be here until next week. Can I borrow some of yours ?
Old 06-04-2002, 12:06 PM   #2870
THeGame's Avatar
Send a message via AIM to THeGame
What's the part number for the front shock tower on the VoneR.
Trying to get it from towerHobbies.......... The one with 3 mounting holes.
-TG
THeGame is offline   Reply With Quote
Old 06-04-2002, 07:52 PM   #2871
Kenneth Tan's Avatar
Anyone tried to use an RB 5 Port with a Kyosho RE manifold and black pipe? Did it explode? Did it work well?
Kenneth Tan is offline   Reply With Quote
Old 06-04-2002, 11:19 PM   #2872
Data's Avatar
-TG
That would be VZ011
the kid
Old 06-05-2002, 02:05 AM   #2873
hooked_on's Avatar
Originally posted by ozzie boy
hey
i got a few qusetions about the v1r
soon i might be selling my ob4 and gettin a v1r
and i wanna keep racing in the pull start class at my club
is there anyway to get a pull start in one? i saw a fella that did it but i cant find the page where he did it
and also what parts seem to break easyest?
thanks
ChriS
Ozzie Boy:
Did you find my posts regarding the pullstart version of the v-one r... The only parts you need to get is some custom shafts that extend the side belt out that extra width of the pull start. I have tried both Alloy (T6) and Mild Steal shafts, the only problem with the mild steal is the extra weight over the standard shafts, but their is other areas you can remove this weight from.... E-mail if you have any further queries.
Manitcore: I have stopped running the pullstart car and gone back to the stock setup as i couldn't get enough speed out of my pullstart engine
My modified Os Cv has been clocked at 65km/hr and i still believe there is room for improvement!
hooked_on is offline   Reply With Quote
Old 06-05-2002, 10:11 AM   #2874
nova racer's Avatar
will the kawahara neg diff fit in the front? I was thinkiing that would turn in like a 1way then you would have full braking also
nova racer is offline   Reply With Quote
Old 06-05-2002, 03:59 PM   #2875
AMGRacer's Avatar
It should fit fine, however I have not actually tried. It would not turn in quite as well as a one-way, but better than a diff full of 50K I think a few people have tried the Kyosho LSD on each end with quite good results.
AMGRacer is offline   Reply With Quote
Old 06-06-2002, 05:00 PM   #2876
Angry Frustrated
I have finally finished building my V1RR GT!
However, i can't seem to get the OS TR (P) started. When i push down on the starter box, the flywheel spins with the pinions etc, but the piston inside doesn't seem to move up and down. I grabbed the allen driver and spun the screw in the end of the pilot shaft, and the piston seemed stuck, and that seems why the starter box couldn't turn it over, cause it just don't have enough grunt. But mind you, the batteries in the box are fully charged, and i think the problem is with the motor setup.
1 thing i didn't do though when building the kit though, in (Step 18) was to ensure there was a space between the flywheel and the motor, when being slid on the pilot shaft. Would this be causing the problem?
Also, when screwing the flywheel nut on the pilot shaft, does this need to have loctite applied? Reason i am asking is because when i took back off the pinions and the like (i.e. reverse step 19), and when i spin the flywheel, the flywheel nut seems to unwind and the whole lot winds off.
Any thoughts would be greatly appreciated guys
Glenn is offline   Reply With Quote
Old 06-06-2002, 05:29 PM   #2877
AMGRacer's Avatar
Well it sounds like you have built the clutch wrong. The centax clutches are kinda tricky to get right first time.
The flywheel must not rub the case for a start. Also the flywheel retaining nut must be very tight and loctited.
If the piston is stuck then just lossen the glow plug a turn and start it, then tighten the glow plug when it starts.
Old 06-07-2002, 03:39 PM   #2878
RAP66's Avatar
My buddy ran his clutch with the factory settings, ran just fine... in fact he did tiighten the clutch a bit more to keep it from grabbing too early.
go back and redo your clutch, best to start from step 1.
Rich
Rich Pedro
[email protected]
www.rcracing.com
RAP66 is offline   Reply With Quote
Old 06-07-2002, 07:40 PM   #2879
Manticore's Avatar
Default Re: Frustrated
1/. check shim between flywheel and engine casing. The manual said you need shim to make sure flywheel wont catch on casing when you tighten the clutch nut.
2/. make sure you shim correctly between the clutch nut and the inner clutch bell bearing. your clutch bell should be able to spin freely (shim until it is just able to spin freely) when you position your engine so that the clutch bell pointing upward. the trust bearing end play plays important adjustment role for engagement point also, you need around 0.3 to 0.5 play between the outter clutch bearing and the trust bearing.
3/. the stock clutch spring is a bit soft with nowaday hi performance engine. It is just fine with OS engine but you need a stiffer clutch spring for novarossi engine. you may use serpent centax clutch spring to increase clutch spring preload.
Manticore is offline   Reply With Quote
Old 06-09-2002, 06:35 PM   #2880
kyle's Avatar
hi all
is there any thing i should look out 4 when buying a second hand v1rr
tnx
kyle is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
