Old 05-16-2002, 02:02 AM   #2791
hurhur's Avatar
Originally posted by AMGRacer
This is a must!!! The V1R has the side belt and I have not had a pipe yet which has not protruded wider than the wheels. One tap and it folds back
or u can get the MRX3 muffler holder....this thing is strong i tell you. need to do small modifications to make the pipe sit nicer though....but shouldnt be a problem.
hurhur is offline   Reply With Quote
Old 05-16-2002, 03:37 AM   #2792
AMGRacer's Avatar
I was meaning the stinger folds back. I use the fantom muffler holder which is OK.
I think the KFactory mid bearing holder is better, it is the only actual KFactory part which is OK.
AMGRacer is offline   Reply With Quote
Old 05-16-2002, 09:01 AM   #2793
Manticore's Avatar
R/C Tech Charter Subscriber
I have the K factory rear solid axle. It is the lightest solid axle available on the market.
Manticore is offline   Reply With Quote
Old 05-16-2002, 09:20 AM   #2794
dtm
dtm's Avatar
Send a message via ICQ to dtm
But it's just one of your 'collectors' item.....you didn't tell them that you have THREE other solid axles!!!!!
dtm is offline   Reply With Quote
Old 05-16-2002, 09:33 AM   #2795
patelladragger's Avatar
Send a message via AIM to patelladragger
what's wrong with the kfactory chassis? The only one I've seen that "looked" any better in quality was the sqaure.
Also, how much are you cutting off the stinger? Or better yet, about how much stinger do you leave measured from the base of the pipe?
patelladragger is offline   Reply With Quote
Old 05-16-2002, 10:08 AM   #2796
dtm
dtm's Avatar
I normally leave around 12-17mm but I cut at an angle (in line with the side of the car) so it's a little difficult to be exact! Just make sure wheels hit wall before stinger!!!!!
K Factory is OK...but their 4mm chassis is very heavy. Quality is middle of the road...local made chassis are about the same. Kawa chassis is very 'nicely' made!!!
Old 05-16-2002, 10:08 AM   #2797
Manticore's Avatar
I let my friend runs the k factory solid axle. It seems his quality check is good !!
Old 05-16-2002, 10:19 AM   #2798
dtm
dtm's Avatar
haha...now you have a 'test driver' for all your options??!!!!! When will you have a spare Xray for me to test???!!!
Old 05-16-2002, 10:23 AM   #2799
Manticore's Avatar
sorry, only one xray here !
Old 05-16-2002, 10:24 AM   #2800
dtm
dtm's Avatar
Don't worry...I can do a 'good' test of that!!!!!
Old 05-16-2002, 10:30 AM   #2801
Manticore's Avatar
you need to be qualified !!
Old 05-16-2002, 12:55 PM   #2802
Thanks for the info, my dremel has a date tonight with about 4 stingers that need neutering
K Factory 4mm chassis is noticeably heavier, no question. I've got the kawahara in my voner now though, I really can't see where it's made as well as the kfactory. But I guess as long as their light and strong we're splitting hairs anyway.
Old 05-16-2002, 04:03 PM   #2803
AMGRacer's Avatar
Hmmm, I do not use solid rear so I will have to trust you on this!! I find the the K Factory stuff is only average quality alloys, Kawahara is clearly better made. Also most K Factory parts are not required in that they are just alloy replacements for the original part. Kawahara mostly goes the further step.
Mayby it is because I do not like the Reflex
Old 05-16-2002, 10:25 PM   #2804
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
I AM
HEYALIGNMENTGUY is offline   Reply With Quote
Old 05-16-2002, 10:53 PM   #2805
dtm
dtm's Avatar
It's all to do with the finishing...the base metal is all the same 7075T6!!!!!
Be careful with the stinger...it does change the characteristics of the pipe 'slightly'....a little more low end.......but it is very slight!!!
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
