Old 04-23-2002, 09:54 AM   #2266
hurhur's Avatar
Originally posted by dtm
same same.........
when you brake, your car will swerve to one side with your one way solid rear combo?
hurhur is offline   Reply With Quote
Old 04-23-2002, 09:59 AM   #2267
Manticore's Avatar
R/C Tech Charter Subscriber
Nope
Manticore is offline   Reply With Quote
Old 04-23-2002, 10:33 AM   #2268
dtm
dtm's Avatar
Send a message via ICQ to dtm
Only if you are heavy braking from a slow speed to full stop!!!
dtm is offline   Reply With Quote
Old 04-23-2002, 07:53 PM   #2269
patelladragger's Avatar
Send a message via AIM to patelladragger
from my experience with one-way in voner if you brake hard and your chassis is not perfectly balanced you will slide to one side. If you do not dial your brakes down you will slide. With foam tires and a light rear diff instead of solid rear I don't see where you need to use the brakes with a one-way except when you come into the pits!
patelladragger is offline   Reply With Quote
Old 04-23-2002, 09:54 PM   #2270
hooked_on's Avatar
Fishcake: The class is alot of fun man.... What makes it even better is that the A final goes for 20 minutes and trying to get the Os Cv-x to last a whole 20 minutes is a real challenge specially with the air getting cooler as the night goes on. But the racing in this class is awsome..... thats why i converted my V-One R to a pullstart. I orginally ran a V-one S out there and my best result was a second in the A final (with just the single speed). I haven't ran the converted v-one r as yet but am having alot of success with it at other clubs. When i get some extra $$$ i am going to try and get some weight out of it cause it is like 1900grams at this stage....
hooked_on is offline   Reply With Quote
Old 04-24-2002, 03:54 AM   #2271
fIShCaKe's Avatar
Send a message via MSN to fIShCaKe Send a message via Skype™ to fIShCaKe
hooked_on: Woah, that sounds cool!
Hey, by the way, I think there is only a mere difference in the speed when you apply brakes on cars equipped with the front one way, as the front ways will continue to roll while the wheels at the back are jammed up.
fIShCaKe is offline   Reply With Quote
Old 04-24-2002, 05:09 AM   #2272
hooked_on's Avatar
Default New Car!
Has anyone else heard anything about the new car around the traps.... i am interested to see what other people are hearing?
Old 04-24-2002, 05:40 AM   #2273
Mauler's Avatar
Send a message via ICQ to Mauler
That's exactly the 2wd effect! The braking if this is very tricky!
Mauler is offline   Reply With Quote
Old 04-24-2002, 07:28 AM   #2274
dtm
dtm's Avatar
With front one way.......
Put a solid axle in the back!!!!! you will find that the car tracks straight even with heavy braking and only slide when you are about to come to a stop!!
With rear diff, brakes can still be useful if your car pushes (or you are too heavy on the gas going into the bend)..... just reduce the brake a bit.....
.............this is with foam tires of course!!!!!!
Old 04-24-2002, 09:17 AM   #2275
fIShCaKe's Avatar
What new car are you talking about? The revised edition?
Old 04-24-2002, 10:33 AM   #2276
Manticore's Avatar
Originally posted by Manticore
Yeah I find it difficult to believe too ! I have the kawahara disc on my MTX2 for 4 weeks track time and ran thru around 50 to 60 tanks and the adaptor holes starts to oval. Now replaced it with the stock old and trusty disc on it. The stock old has been with my MTX2 for one years and it is in great shape.
I will post the picture of the worn out kawahara disc later on.
I need to check if my friend put sand paper as drive belt or not !
Here
Old 04-25-2002, 01:04 AM   #2277
hooked_on's Avatar
Fishcake:
Yes the revised edition!
http:\\www.stormpages.com\tep
Old 04-25-2002, 01:59 AM   #2278
fIShCaKe's Avatar
ohhh, okay, but I thought It's basically the same? It's only a guess..
Old 04-25-2002, 03:57 AM   #2279
hooked_on's Avatar
Check my past posts for info on the revised car... All I was asking was if anybody else somewhere else in the World had heard anything?
Old 04-25-2002, 05:54 PM   #2280
V1RR Building Questions
Rear Gear Diff
1. the housing for the gears, part 27 i think. I got 2 included in the kit. Any reason, and did anyone else?
2. How much silicone oil (hard) do you recommend pouring in the rear gear diff housing? Fill her up, or just a few drops?
Rear Bulkhead Question
With the glueing of the brake pads, what product works best? They refer to rubber glue, and i have been told earlier that shoe goo works, but i just thought of asking you pros to make sure.
Many thanks in advance...
NB: got the OSTR(P)!!!
Glenn is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
