Old 04-19-2002, 07:46 PM   #2206
fIShCaKe's Avatar
Send a message via MSN to fIShCaKe Send a message via Skype™ to fIShCaKe
Hey, what are the grades of Silicon Oils you guys use for the front differential, rear differential and shocks?
fIShCaKe is offline   Reply With Quote
Old 04-19-2002, 08:01 PM   #2207
patelladragger's Avatar
Send a message via AIM to patelladragger
I bet you can fit a big block in there as long as you're willing to take a dremel to the chassis and you don't use the al. brace w/ the belt tensionser.
I have an extra chassis so I may try it. The reason I want to put a big block in isn't for speed - it's for gas mileage. We have a nitro endurance race coming up and I figure I can keep up with everyone running a big block lean and still only use 1/2 throttle - I should be able to get much more time per tank than others running small blocks. We shall see. I was going to sell the voner but for some reason the market has fallen out and no one wants to pay fair price for anything other than Nitro tc3's and HPI's!
patelladragger is offline   Reply With Quote
Old 04-19-2002, 10:43 PM   #2208
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
Front diff no oil I am useing a one way
Rear diff 10,000 wht
shocks 80wht
HEYALIGNMENTGUY is offline   Reply With Quote
Old 04-20-2002, 03:23 AM   #2209
hooked_on's Avatar
Thumbs down V-One R Pullstart!
Doesn't anybody like my V-One R Pullstart?
hooked_on is offline   Reply With Quote
Old 04-20-2002, 07:18 AM   #2210
fIShCaKe's Avatar
HEYALIGNMENTGUY: Does your car oversteers or understeers?
Old 04-20-2002, 08:57 AM   #2211
It used to understeer, changed some settings, shock springs and oil and re set the front toe now its pretty neutral
Are you useing rubber or foams?
Old 04-20-2002, 10:43 AM   #2212
fIShCaKe's Avatar
Hahaha! Oh well, Guess I'll have to use a a thinner silicon oil for my rear differential man! I am using rubber tires, is there any problem? Hey, what about the shock springs? Did you change them?
Old 04-20-2002, 07:16 PM   #2213
No no problem
yup I changed shock springs GOLD baby Gold
I am running FOAMS and a lola body so my set up probably is not right for you,
Might I suggest a softer shock and spring setting and leave the rear diff to stock setting.....also try about 3 deg rear toe in you might be surprised
Old 04-20-2002, 11:59 PM   #2214
fIShCaKe's Avatar
Alright! Thanks a lot man! I'll go try and tell you the effects...
Old 04-21-2002, 01:18 AM   #2215
hooked_on's Avatar
Default I Wonder If I Said New V-One R due in May Would People Talk To Me?
Hmmm....
Fine people just ignore me.... this looks like an exclusive forum for only the privillaged?
But i bet if i said that "A NEW KYOSHO V-ONE R IS DUE TO BE RELEASED IN MAY!" people would talk to me
Old 04-21-2002, 03:00 AM   #2216
VenomWorldOrder's Avatar
Default Re: I Wonder If I Said New V-One R due in May Would People Talk To Me?
Originally posted by hooked_on
Hmmm....
so what is this new v1r you are talking about? is it a v1rr totally hopped up?
man my stock v1r with gold swaybars front works fine..... ok so maybe it isn't stock k factory 4mm chassis, k factory tray mounts, carbon top deck, rear y brace, kyosho cvd's, kawaharra 1st gear holder, kawaharra wide hex hubs, i think that;s it??
VenomWorldOrder is offline   Reply With Quote
Old 04-21-2002, 03:12 AM   #2217
hooked_on's Avatar
Default Re: Re: I Wonder If I Said New V-One R due in May Would People Talk To Me?
No not in the form of a V-One RR.... This is a revised edition of the V-One R. All tean drivers have the car now and is due for world wide release in May.
Old 04-21-2002, 04:59 AM   #2218
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: Re: Re: I Wonder If I Said New V-One R due in May Would People Talk To Me?
hi hook_on,
Howyadoing?
Manticore is offline   Reply With Quote
Old 04-21-2002, 05:03 AM   #2219
hooked_on's Avatar
Good man....
Thanks for the warm welcome....
Old 04-21-2002, 07:19 AM   #2220
fIShCaKe's Avatar
Are you sure?! What are the differences between the Revised Version and the normal V on R?
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
