Old 04-13-2002, 11:13 PM   #2131
boner's Avatar
it require 2 pieces of plastic that come with your v1r kit.
Look at the manual for your front sway bar, it have a illustration how to install it and the parts you need from original plastic tree from v1r.
boner is offline   Reply With Quote
Old 04-13-2002, 11:20 PM   #2132
THeGame's Avatar
Send a message via AIM to THeGame
Thanks boner.....
But i got the car used... You dont have a part # or anything or what parts tree it came on ???
THeGame is offline   Reply With Quote
Old 04-14-2002, 12:38 AM   #2133
Mauler's Avatar
Send a message via ICQ to Mauler
Originally posted by THeGame
Question for all Vr1 owners.... i Just got the swarbar kit from Kyosho for the front of the car.. The only problem is i cant find anything to mount it to my updeck.. What are you guys using for swaybar mounts ?
thanks all...
-Tg
Change to the blade sway bar on the RR... much easier to adjust! Cheap too!
Mauler is offline   Reply With Quote
Old 04-14-2002, 12:38 AM   #2134
THeGame's Avatar
Mauler- you know the part # for the swaybay blade ? i guess that needs mounts to ??? You dont knwo that part number for the mounts for the other swaybar?? What is that setup your running on your car ?? Thanks
Old 04-14-2002, 12:43 AM   #2135
THeGame's Avatar
vanntz - what springs and shock oil are you runnin?
-Tg
Old 04-14-2002, 12:43 AM   #2136
Mauler's Avatar
Originally posted by nova racer
Well today was the first day i got to run the thing on the track and it is a lot easyer to drive than the racer2. But it pushes a lot and i wore a brand new set of sorex28's down to the belt in two heats from what the guys at the track said is that for our tight tracks you need a lot heaver diff lube. for instance one guy the fastest uses 30,000 in the front and 50,000 in the rear and he was hoooooooooked up with his mtx2. when i got home i change mine to that and it was sweet but i still need more inital turn in. I will try out more stuff tomorrow. On a brighter note the OS tr 12 ran great it's right there with mt12's that litter the track.
We run on a very tight track and i need a lot of diff in put. So post your diff settings it would help a lot.
Thanks in advance!
Try running 10-20000 up front and 5000 or 3000 in the rear... this will give you a very good turn in... of course, all these at the expense of more gear wear...
If you are running on a high grip track, try a front one way and a loose rear, this would make you do a hair pin in a split second! Handles very much like an electric, without brakes of course!
Old 04-14-2002, 02:24 AM   #2137
Mauler's Avatar
VZ082 and VZ083 for the front wide bumper and the rear floating mount and front roll bar holder... the sway bar comes separately...
Old 04-14-2002, 02:26 AM   #2138
Mauler's Avatar
-Tg
Red all round and stock shock oils... If you want, you can go for heavier oils in front...
Old 04-14-2002, 03:12 PM   #2139
THeGame's Avatar
Mauler- where can i get the parts from?? towerhibbies ? Cause i tried looking up thoes part# and coundnt find them...
Whats the part number for the front roll bar holder ?
Who makes the blade swaybar ?? what's that part Number for that to VZ082 and VZ083 ?
-Tg
Old 04-14-2002, 08:28 PM   #2140
Mauler's Avatar
-Tg
They are parts for the RR...
Old 04-14-2002, 09:25 PM   #2141
THeGame's Avatar
I thought all kyosho part # start with KYO ?? I cant find thoes part numbers any where...
Were do you guys get your parts from???
-Tg
Old 04-14-2002, 11:13 PM   #2142
I thought the RR was weak... I guess someone got spanked pretty bad... I remember someone back in Jan saying the RR was weak and stuff.. hmm.. hmm.
Yeah.. OVAL ROCKS..... I can hit a pole in a parking lot with only 2 light poles standing.. I am SOoooooo OOOo hoooook.
OvalSucksAtBart is offline   Reply With Quote
Old 04-15-2002, 01:12 AM   #2143
Mauler's Avatar
You must be driving a Neo I guessed... Cos that's the only car I could think of when that's "stronger" than the RR!
One more thing, the RR runs ovals well! It runs other geometries circuits such as triangles, squares, pentagons, hexagons and others pretty well too!
Man! I pity that your car can only run around in OVALs!!
Old 04-15-2002, 01:16 AM   #2144
Mauler's Avatar
-Tg
Nope, not all starts with KYOxxxx... the newer parts are VZxxxx.
If the RR parts are not available in your area, try running the stock setup without the roll bars...
Old 04-15-2002, 01:18 AM   #2145
Mauler's Avatar
No offence!
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
