Old 03-31-2002, 10:52 PM   #2011
Originally posted by HEYALIGNMENTGUY
Originally posted by Manticore
post your setup!!
OK
FRONT
caster 6 deg +
camber 2 deg -
toe in 0
shocks stock oil and stock black spring
sway bar Blade type angled about 30 deg
REAR
camber 2 deg -
toe in 3 deg +
shocks stock oil
I do change spring and sway bar depending if track is preped.
yesterday track was DUSTY so no swaybar and silver springs
ZAC Project foams 40s in front 26mm......35s in rear 32mm
ride height is 4mm
one way spool up front and neg diff in back with 10,000+500 oil mix.
I am looking to get better stearing in the infield seems to push when I get into a technical section......seems like I am a moving chicane
Maybe it's because you're using my front 1-way outdrive. lol
Sydewynder is offline   Reply With Quote
Old 03-31-2002, 11:00 PM   #2012
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
Well if it isnt Mr. shiat disturber
How was breakfast ?? Looks like next Sat will be the day to get to the track again............OK
HEYALIGNMENTGUY is offline   Reply With Quote
Old 03-31-2002, 11:04 PM   #2013
What are you talking about? It's STICK. Shiat STICK. Not disturber. lol
What breakfast? You inviting me over for breakfast? Can Manticore come over too?
I'm going to the track all this week.
Old 03-31-2002, 11:11 PM   #2014
AMGRacer's Avatar
Originally posted by AMGRacer
I am after some track info. Often we talk about small, medium and large tracks I am after what length straight the track has and what engine pipe combo is being used on that track.
My track has a 130' long straight and the CX12 and MT12 engines seem to be the best with a shorter torque pipe. Using standard gearing on the V1R the CX12 winds out nice and the MT12 has some legs left. The RS12 is over geared even at 16/20 for this track.
Anyone else got some similar info??
I run on a simular track, I am using cvr with a x12 pipe, works well for me.........I personally should have gotten the mt12 I could have used the extra legs
Is your track permanent ? do they change the configuration every other week, like they do mine keeps us honest
Hmmmm CVRs also seem good at my track. The new OS TR seems to work well also.
Our track is permanent so we only go forwards and backwards.
AMGRacer is offline   Reply With Quote
Old 03-31-2002, 11:11 PM   #2015
Line 1:
Line 2: no, you said you where going to a pancake breakfast on Easter Sun. and yes he can
Line 3: Bastard you always know how to kick a working fool in the nuts
Old 04-01-2002, 09:13 AM   #2016
Manticore's Avatar
R/C Tech Charter Subscriber
use 30% nitro !! simple, fast and direct trickk !!
Manticore is offline   Reply With Quote
Old 04-01-2002, 09:15 AM   #2017
Manticore's Avatar
Here is my set up which works great at a medium track with tight infield
Front
Gold spring, 70wt
8' caster; 1.5 toe out; 2' camber
softest sway bar position
42 shore tire
Rear
Gold spring, 55wt
2' toe in, 3' camber
black sway bar
I am using front one way with rear solid axle.
setup also works great on rear diff but you need higher diff oil such as 10000 or above.
I will try your set up but I need to get to the hobby shop to pick up some diff and shock fluids, I will keep you informed of whats happening
If I use this set up, will I be a member of team hardkore
Great, tell me how do you find the setup.
by the way, the rear camber link is : bulkhead/lower; hub/upper.
Old 04-01-2002, 09:19 AM   #2018
Manticore's Avatar
a sydewynder outdrive !!!!!!!!!!!!!!!!!! everybody keeps their hand off from it !!!
Old 04-01-2002, 09:21 AM   #2019
Manticore's Avatar
I would love to have a breakfast meeting at the track with you guys !! send me your magic carpet please !!!!!!!!!!!
Old 04-01-2002, 04:00 PM   #2020
AMGRacer's Avatar
LOL we do not play by HK rules!!! The 30% certainly seems to add a lot of torque to the engines which makes them alot faster!
Old 04-01-2002, 06:25 PM   #2021
Manticore's Avatar
HK rule = no rule !! we run by restriction of scale !!
Old 04-01-2002, 09:42 PM   #2022
sounds like our rules
why so Many rules in the Land Down Under I say start your own Class
Old 04-01-2002, 09:47 PM   #2023
Manticore's Avatar
tried the setup yet?? keep me posted !
Old 04-01-2002, 09:56 PM   #2024
Sorry ,Nope not yet, going to track this weekend
I have not been to the hobby shop to get diff fluid & fuel
been a little busy with running buisness and verry large house remodel
R/C is my escape as well as theropy from the real world
but you will be the second one to know if set up works well for my driving style
Old 04-01-2002, 10:29 PM   #2025
AMGRacer's Avatar
Actually our track is quite free, but all our championship events and state events are run to IFMAR rules. I am too lazy to change car setup between rule sets so I just run IFMAR rules on my cars most of the time......
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
