Old 03-29-2002, 04:57 AM   #1996
dtm
dtm's Avatar
Send a message via ICQ to dtm
He gets an A++ for being brave enough to buy an Impulse in the face of all these V1Rs and MTX2!!!!!!
dtm is offline   Reply With Quote
Old 03-29-2002, 08:58 AM   #1997
adelmundo's Avatar
Send a message via ICQ to adelmundo Send a message via AIM to adelmundo
Hey I want to be certified too! I have owned an Impulse and an MTX-2. Now all I have is V-One R's in TC! Besides I need permission to be in "Team Hardkore" Northern California division! I think my V-ONE R's are hardcore enough! At the last race I didn't even break a part on the track! I only broke a part on the bench when I overtightened my wheel nut and broke the axle on my car (original axle from when I bought the car). In fact I rarely break parts. That just goes to attest to the strength of the V-ONE R.
All in all the car is sturdy as hell. Most of the time I don't finish races due to tire and wheel problems (ie wheel rim breaking, wheel nut coming loose and wheel flying off) and not from major parts breakage!
adelmundo is offline   Reply With Quote
Old 03-29-2002, 09:05 AM   #1998
Manticore's Avatar
R/C Tech Charter Subscriber
in fact every V1R is hardcore!! but, watch out those reflex. watch out the broken pieces from the reflex bumper !! that will hurt your hardcore V1R !!
Manticore is offline   Reply With Quote
Old 03-29-2002, 06:52 PM   #1999
Send a message via ICQ to ozzie boy Send a message via AIM to ozzie boy Send a message via Yahoo to ozzie boy
i was goin to get a v1r till i found a sweet deal on a 2nd hand ob4 that has about all the options on it for 400 a.u
hey and also this is the 2000 post in this thread
ozzie boy is offline   Reply With Quote
Old 03-29-2002, 08:26 PM   #2000
AMGRacer's Avatar
You are aware that the OB4 is not even in the same ballpark in terms of quality to the V1RR? They are a nice car and spare parts are cheap tho.
AMGRacer is offline   Reply With Quote
Old 03-30-2002, 03:05 AM   #2001
Send a message via AIM to ZER01
Thumbs up
Onroad Electric and Nitro "State Championships" May 4th @ Small Cars Unlimited.
ZER01 is offline   Reply With Quote
Old 03-30-2002, 11:29 PM   #2002
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
I was at the track today and I noticed that the car seems to push a little in the infield I did tweak the front sway bar seemed to help but still some push in a tight section,
suggestions would be appreciated
HEYALIGNMENTGUY is offline   Reply With Quote
Old 03-30-2002, 11:53 PM   #2003
Manticore's Avatar
post your setup!!
Old 03-31-2002, 05:14 PM   #2004
yeah i know that but it seems to be the car to be with down here!
and most of the driver in the club drive ob4's i think
Old 03-31-2002, 07:17 PM   #2005
Manticore's Avatar
apple to orange !
Old 03-31-2002, 08:04 PM   #2006
Originally posted by Manticore
post your setup!!
OK
FRONT
caster 6 deg +
camber 2 deg -
toe in 0
shocks stock oil and stock black spring
sway bar Blade type angled about 30 deg
REAR
camber 2 deg -
toe in 3 deg +
shocks stock oil
I do change spring and sway bar depending if track is preped.
yesterday track was DUSTY so no swaybar and silver springs
ZAC Project foams 40s in front 26mm......35s in rear 32mm
ride height is 4mm
one way spool up front and neg diff in back with 10,000+500 oil mix.
I am looking to get better stearing in the infield seems to push when I get into a technical section......seems like I am a moving chicane
Old 03-31-2002, 10:26 PM   #2007
Manticore's Avatar
post your setup!!
OK
FRONT
caster 6 deg +
camber 2 deg -
toe in 0
REAR
camber 2 deg -
toe in 3 deg +
shocks stock oil
ride height is 4mm
Here is my set up which works great at a medium track with tight infield
Front
Gold spring, 70wt
8' caster; 1.5 toe out; 2' camber
softest sway bar position
42 shore tire
Rear
Gold spring, 55wt
2' toe in, 3' camber
black sway bar
I am using front one way with rear solid axle.
setup also works great on rear diff but you need higher diff oil such as 10000 or above.
Old 03-31-2002, 10:42 PM   #2008
AMGRacer's Avatar
I am after some track info. Often we talk about small, medium and large tracks I am after what length straight the track has and what engine pipe combo is being used on that track.
My track has a 130' long straight and the CX12 and MT12 engines seem to be the best with a shorter torque pipe. Using standard gearing on the V1R the CX12 winds out nice and the MT12 has some legs left. The RS12 is over geared even at 16/20 for this track.
Anyone else got some similar info??
Old 03-31-2002, 10:42 PM   #2009
Front
Gold spring, 70wt
42 shore tire
Rear
Gold spring, 55wt
black sway bar
I will try your set up but I need to get to the hobby shop to pick up some diff and shock fluids, I will keep you informed of whats happening
If I use this set up, will I be a member of team hardkore
Old 03-31-2002, 10:51 PM   #2010
I run on a simular track, I am using cvr with a x12 pipe, works well for me.........I personally should have gotten the mt12 I could have used the extra legs
Is your track permanent ? do they change the configuration every other week, like they do mine keeps us honest
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
