Old 06-12-2007, 01:20 AM   #1
Default question about on-road tires
How to choose type of foam tires?
should I get hard or soft tires, and what would be the best one for the rear and front to play in dirty asphalt?
Rayvan is offline   Reply With Quote
Old 06-12-2007, 03:29 AM   #2
quietstorm76's Avatar
softer will give you more grip on the dirty surface. go harder on the front tire.
quietstorm76 is offline   Reply With Quote
Old 06-12-2007, 07:05 AM   #3
SlamMan's Avatar
Since rear tires tend to wear faster I would go with a harder tire in the rear. Try something like 40 front, and 42 rear.
SlamMan is offline   Reply With Quote
Old 06-12-2007, 10:08 AM   #4
I run on a dirty parking lot. I use either 38 front and rear or 38 front and 40 rear depending on temperature.
Johnny9s is offline   Reply With Quote
Old 06-13-2007, 01:10 AM   #5
I realized that many tires have different color code. what would be the softest one ?
Old 06-13-2007, 03:26 AM   #6
Corse-R's Avatar
Color coding (green, aqua, silver, orange, etc...) for foams denotes electric foams and the main problem is all manufacturers don't use the same scales and colors to denote the firmness of the foam, much better to use the shore ratings because are common and is easier to compare between manufacturers then.
If you're thinking on driving in dirty asphalt, you could go much better with rubber tyres rather than foams, foams and dust don't play very well between them.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 06-13-2007, 03:59 AM   #7
thamjk's Avatar
Sometimes rubber tyre works well in dirty asphalt. The only problem with rubber is hot weather. Once the rubber get too hot and it won't be able to hold the car expecially current nitro car in the market.
Serpent 710
Nova MAX
3PK
thamjk is offline   Reply With Quote
Road Rage or Road Hawg Type Steert Tires for MT mjm R/C Items: Wanted to Buy 1 08-05-2006 12:07 AM
New to On-Road (tc4 question) CellBoy77 Electric On-Road 4 10-12-2005 02:32 PM
Off road and On road tires for sale, with pics. Chico R/C Items: For Sale/Trade 8 04-24-2005 02:02 PM
I have a nub off-road question =MisFitz= NuKe Electric Off-Road 8 07-08-2004 09:54 PM
Question on gearing options - On road vs Off road Ducati-Rider Nitro On-Road 1 05-04-2004 01:54 PM
