Old 05-28-2003, 01:52 PM   #61
Trader Rating: 244 (99%+)
I have run into that problem but havent had a chance to test out a new setup to help cure that yet.
Fred Perkins is offline   Reply With Quote
Old 05-30-2003, 04:47 PM   #62
Send a message via ICQ to Cartman
they seem to be a bit fragile! some uk drivers have already given up on them and gone to other makes!
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 06-02-2003, 09:32 AM   #63
turbodog's Avatar
Yea "Team Mugen", they're breaking track records! lol
turbodog is offline   Reply With Quote
Old 06-02-2003, 09:40 AM   #64
Who are???
Old 06-03-2003, 06:58 AM   #65
defMondo's Avatar
I just put this baby together and seems quite impressive, still needs a bit of work and to be run in.
Enjoy,
Tony
defMondo is offline   Reply With Quote
Old 06-03-2003, 03:16 PM   #66
Default My claim to fame!!
as one of the first scumacher drivers of the sst98 i came up with the orings in the rear track linkages!!! take em out and see what differance they make, not on the track though!!
Old 06-03-2003, 05:44 PM   #67
modellor's Avatar
I would hazard a guess that if you take them out you would end up with serious play in the cups.
Am I close Cartman???
modellor is offline   Reply With Quote
Old 06-03-2003, 07:31 PM   #68
defMondo's Avatar
You may get serious play in the cups after some time, when they are new they are very tight.
I use them on my TA03 years ago, to get rid of the slop in the steering.
Tony
Old 06-03-2003, 08:17 PM   #69
Registered User
OB42TC3's Avatar
What is the overall drive ratio on this car? I need to know if a second gear ratio of 4.4:1 is possible. If not what is the highest it can go?
OB42TC3 is offline   Reply With Quote
Old 06-03-2003, 09:02 PM   #70
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
what seems to ba bit fragile?..
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 06-04-2003, 08:25 AM   #71
defMondo's Avatar
According to the manual (page 34) you can go as high as 4.33 : 1.
4.41:1 is obtained with a 58 spur and 25 pinion.
Does this help?
Tony
Old 06-04-2003, 11:08 AM   #72
Registered User
OB42TC3's Avatar
Yes that helps. I am scouting other cars now, and one of the things I need to consider is being able to gear for a 270 foot straight. The RS4 3 and MTX2 and even the reflex (I think) are out because of gearing. That leaves the MTX3, LD3?, R12, GT4 and 705. How is the durability of the R12? The one part that concerns me is the lower pivot balls in the arms; and also the composite Axles. Anyone care to admit slamming some boards and breaking some parts?
Old 06-04-2003, 06:33 PM   #73
defMondo's Avatar
270Feet, damn thats a big straight.
I think they will be as durable as the next car, all the suspension and most of the drive train is straight from the Fussion with the 3 speed and 21 engine in it and I have seen one of those running around a velodrome and being clocked at over 100Km/h (small velodrome not much time to wind up) down the straight, I also witnessed some monumental crashes with it and it survived.
I'm still in the process of running mine in so it's all observation at the moment. I'll let you know in a couple of weeks when I have my first race meeting with it.
Tony
Old 06-04-2003, 11:36 PM   #74
InitialD's Avatar
If you rulled out the Reflex NT, how could you include the MTX-3? It has about the same final drive ratios as the Reflex NT and the V1RR.
Cars which you should look into for high speed (low final drive ratios) should be the GT-4 (4.4 I think), NTC3 (4.44) and the 705 (4.4).
BTW, the information about the Schumacher is interesting, which makes it the newest candidate for high speed tracks. Never knew that it had a low final drive ratio.
Old 06-05-2003, 12:15 AM   #75
modellor's Avatar
Your correct with the GT4. It has identical gearing and internal ratios as the 705.
schumacher fusion qcrvr R/C Items: For Sale/Trade 6 05-12-2004 07:30 PM
$200.00 for my SCHUMACHER FUSION R12 etips76 R/C Items: For Sale/Trade 0 10-23-2003 06:15 AM
Getting a new 1/10 which should i get a hpi rs4 3 or a schumacher fusion mohamed_own Nitro On-Road 9 10-19-2003 09:28 PM
looking for schumacher fusion.21 erand8976 R/C Items: Wanted to Buy 0 10-15-2003 10:30 PM
Schumacher Fusion Fusion Australian Racing 19 02-02-2003 07:06 PM
