Old 07-02-2004, 08:01 PM   #256
Z24
Default Pro Bar Mounted to lower arm settings
Another question. What about the Pro Bar. How do I set them?
What changes does it make when I make the turnbukles longer or shorter with the R12 suspension. And I think making adjustment for the front it's not the same with the rear. Cuz i'm not sure if they work the opposite for better performance suspension. Thanks for any kind of help.
Z24 is offline   Reply With Quote
Old 07-02-2004, 08:05 PM   #257
PW
PW's Avatar
Send a message via AIM to PW
Thats awesome MO....Make sure you call me on my cell if you have any questions
Z24.....I use a 1 tooth split with no worries, but on certian tracks I have used a 2 tooth split with success. Using a 2 tooth split is very risky though because of the gear mesh, but it can be done.
On most average nitro tracks I use a 19/24 pinion with the stock spurs, but I have used 19/25 on really big tracks. If it's a small track I use 18/23 with stock spurs....I always use the stock spurs
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 07-02-2004, 08:10 PM   #258
PW
PW's Avatar
Z24....Changing the length of the turnbuckle won't really affect the bar much, but moving the ball mount on the bar or the ball on the arm will.
Softer bar = Ball further out on wire or ball on arm making turnbuckle more straight up & down.
Stiffer bar = opposite of softer bar....hehehe
Paul Wynn
Old 07-02-2004, 08:41 PM   #259
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Originally posted by Z24
Happy father's day Marcos, kind of late but secure HEHEHEHE
congratulations!!!
thanks!!
Old 07-02-2004, 08:41 PM   #260
Z24
Talking
OH Gosh, thanks for the gears settings I was braking my head off, if could made those gears splits or not eheheh.
And OK, understood, stock spur gears.
ummmmmmm... i'm kind of lost right here, but let's see If I get this straight.. you're saying the only changes can I make, is the rear pro bar to lower arm. Cuz each lower arm has two holes right...?
And for the front Pro Bar to lower arm, can't really make nothing with it, cuz for the mods that was made right...? It's kind of confused, but I think I get it.
Ok, I wrote all this settings on a paper, I'll keep you inform what happens tomorrow. Thanks Paul.
And btw Paul, there's going to be a 2nd Latin Cup, speculating for december on this year.
OK thanks.
Old 07-02-2004, 08:46 PM   #261
Super Moderator
Marcos.J's Avatar
Default Re: Gear Ratios
Hi people,
I have some questions about the Gear Ratios for the R12. I'm gonna make some tests tomorrow again with the R12. And I wanna make the Car to gain a little bit of more top speed on the straight away. Cuz i figure out, that it already made the Top Speed but just at the middle of the straight away. But I don't want to sacrifice the Acceleration regarding with the manual. OK, in other words i'm using stock gears for the tranny, Pinons and Spur Gears. And now I changed the pinon gear 20/61 for first gear and 24/57 for second gear. Gear ratio 5.80 1st and 4.51 2nd
Is there a way to make the first gear a higher ratio? So i can get more faster acceleration? If there no other way, I'll just leave it like that then.
Thanks!!
take off one tooth of the first gear pinion that should give you more acceleration
Old 07-02-2004, 09:19 PM   #262
Trader Rating: 244 (99%+)
Heres a couple of pics!
Fred Perkins is offline   Reply With Quote
Old 07-02-2004, 09:19 PM   #263
Old 07-02-2004, 09:20 PM   #264
Old 07-02-2004, 09:23 PM   #265
Z24
Talking
OK thanks.
Old 07-02-2004, 09:25 PM   #266
Super Moderator
Marcos.J's Avatar
very nice!!i will be getting a new team kit soon!!
Old 07-02-2004, 09:26 PM   #267
Z24
whoooopps, sh#$ happens.
RC Old Man, nice pics
Old 07-03-2004, 08:01 PM   #268
Duh!?
Old 07-03-2004, 09:56 PM   #269
mo
mo's Avatar
My R12 team is all built and almost ready to run. Here is a pic.
RC Old Man, I don't know if the clutch is different on the regular kit but my RB V12, SG shafted motor bolted in just fine.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 07-03-2004, 10:12 PM   #270
Super Moderator
Marcos.J's Avatar
sweet ,cant wait to get mine!!!
schumacher fusion qcrvr R/C Items: For Sale/Trade 6 05-12-2004 07:30 PM
$200.00 for my SCHUMACHER FUSION R12 etips76 R/C Items: For Sale/Trade 0 10-23-2003 06:15 AM
Getting a new 1/10 which should i get a hpi rs4 3 or a schumacher fusion mohamed_own Nitro On-Road 9 10-19-2003 09:28 PM
looking for schumacher fusion.21 erand8976 R/C Items: Wanted to Buy 0 10-15-2003 10:30 PM
Schumacher Fusion Fusion Australian Racing 19 02-02-2003 07:06 PM
