Old 06-05-2007, 12:41 AM   #1
Trader Rating: 14 (100%+)
Default Rounding tire corners after truing
Any secret tools other than sandpaper and files?
Any suggestions as to the grit of paper or coarseness of the file?
thunderbt3 is offline   Reply With Quote
Old 06-05-2007, 01:04 AM   #2
ShrekNZ's Avatar
I've seen some rantings about this before maybe on the electric thread.
Simply I use an el cheepo file probably about a bastard cut on one end and a rasp (wood file) on the other which is really good for ripping down the sides of chunked tyres and then finish with a file.
I'm sure lots of others have other opinions I know the 12th guys use it as a tuning aid on the fronts.
ShrekNZ is offline   Reply With Quote
Old 06-05-2007, 02:04 AM   #3
Dynamite's Avatar
Send a message via MSN to Dynamite
i got the hudy rasp stick thing, its the shiznick
just dont use to much pressure or you might wear off 5 or so mm lol
www.racingfactory.org
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
Old 06-05-2007, 07:33 PM   #4
Woodlands Racer's Avatar
Default Tool for rounding tire corners
I have to give credit to someone else for this one - On another thread on RCTECH, I found a tool that works very well and is not very expensive. Go to Lowe's or Home Depot and look in the flooring tile tool area for a TILE FILE. There are two sizes, way to big and just right. The latter is small and just right to manuaver around the tire truer and sells for about $8.00 USD if my memory is good.
Good luck,
RDB
Woodlands Racer is offline   Reply With Quote
Old 06-05-2007, 08:06 PM   #5
Good luck,
RDB
went to the website and didn't find it. do you have any pictures?
bosfan is offline   Reply With Quote
Old 06-06-2007, 07:11 AM   #6
Dreddlox's Avatar
I use a flat file I got from HomeDepot, but if I can't locate it I use the handle from my Hex wrenches. That works fine too.
Dreddlox is offline   Reply With Quote
Old 06-06-2007, 07:45 AM   #7
spork01's Avatar
If you can get one use a permagrit
spork01 is offline   Reply With Quote
Old 06-06-2007, 05:40 PM   #8
Default Tile File @ Lowe's
Here is the link to the file I mentioned. As you will see on the description it is a carbide file. It does a great job.
http://www.lowes.com/lowes/lkn?actio...7616-1255-2716
Old 06-06-2007, 06:17 PM   #9
Bob Malphurs's Avatar
The best tire truing sticks are made by Mike Saputo...Mico Racing Enterprises!
He makes two grades, fine and coarse carbide.
Shop @ 314-869-3232 (message only)
Fax @ 314-869-8769
Bob Malphurs is offline   Reply With Quote
Rounding the edge of foam tire after cutting? straightaway Nitro On-Road 23 01-24-2007 07:09 PM
TC4 Tire Truing Question jeffbhhs Electric On-Road 2 01-10-2007 12:32 PM
Tire truing MK_Arbiter Electric On-Road 14 10-23-2006 01:55 PM
rounding edges of tire Sal Amato Electric On-Road 5 01-24-2006 06:04 PM
Questions on Tire Truing and the Eagle Racing Tire Truer nitro_tacklebox Electric On-Road 5 04-21-2005 03:39 PM
