Old 06-04-2007, 12:24 AM   #1
stevenc's Avatar
Default Kyosho diff clay
Gday everyone just wondering anyone got any feedback on the Kyosho Diff Clay.
Cant find to much info on it but do you pack it solid in the diff or do you just put varying amounts in to get the desired amount of lock I suppose.
stevenc is offline   Reply With Quote
Old 06-04-2007, 01:46 AM   #2
Trader Rating: 28 (100%+)
hope this helps!
http://rcforum.co.kr/phpBB2/viewtopic.php?t=1616
Ashley Cobb is offline   Reply With Quote
Old 06-04-2007, 02:47 AM   #3
stevenc's Avatar
thanks ashley, i wonder if it does work good or if its snake oil potion I am trying to get some give it a go anyway, might be pleasantly surprised. I seen some talk about it but no real feedback on it though. My silicon oil seems to leak to easy imo, I am to lazy to keep checking diffs after every meet. Blew another front locked diff friday night so trying to find something better.
Old 06-05-2007, 12:30 AM   #4
I use serpent cleaning gum in the front diff of my RRR, it gives a really stiff diff. I heard about the Serpent team drivers using this trick in the old 705 some years ago. The Kyosho diff clay sounds like a similar solution.
pitbits is offline   Reply With Quote
Old 06-05-2007, 03:09 AM   #5
redsand's Avatar
Send a message via Yahoo to redsand
Will peanut butter work ?
redsand is offline   Reply With Quote
Old 06-05-2007, 04:53 AM   #6
stevenc's Avatar
nah wouldnt last long enough I would eat it first before I put in there anyway this clay must be popular cant get a hold of it the few places left in this world that sell kyosho gear are out of stock, will just have to get some grease for now.
Old 06-05-2007, 05:13 AM   #7
sosidge's Avatar
What is the part number for the diff clay please?
Old 06-06-2007, 11:24 PM   #8
Steve, I wonder if the mugen steel solid diff thing (the same as the kyosho plastic one you keep stripping) would fit in the kyosho diff housing?
http://rc-mushroom.com/product_info....oducts_id=9673
Old 06-06-2007, 11:44 PM   #9
Ed Anderson's Avatar
Trader Rating: 26 (100%+)
If that one won't this one should.
http://rc-mushroom.com/product_info....oducts_id=3806
Ed Anderson is offline   Reply With Quote
Old 06-06-2007, 11:52 PM   #10
Rapid Roy's Avatar
Yokomo makes a hard grease that doesn't weep out like the oils. They still list them on there US web site. We used to use this stuff back in the day when the TC diffs wern't sealed.
CS-DGH Gear Diff Grease, Hard 3.00
CS-DGM Gear Diff Grease, Medium 3.00
http://www.yokomousa.com/newproducts...rtslist1_1.htm
Rapid Roy is offline   Reply With Quote
Old 06-07-2007, 02:02 AM   #11
Sow&Steady's Avatar
I heard that the non-crunchy one works best.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 06-07-2007, 02:14 AM   #12
rmdhawaii's Avatar
You are being quite humorous today slow. You must be in a good mood about something.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 06-07-2007, 06:03 AM   #13
stevenc's Avatar
thanks ashley , though it doesnt look like it will work ..plus mate its a mugen part i cant put a mugen part in my kyosho that would be like having sex with a playboy playmate and using a condom..you just wouldnt do it would you . I think I found out why it was stripping the block though. I am a dickhead have you pulled one of those front diffs apart on the 05t. Well I realised it was stripping the right side all the time and noticed the washer/shim under the pin was concaved and started to wear out diff cover plate. You know there is an oring under the shim that seals the outdrive..well for some reason I have left this oring out, and there is no support there for the shim so with all the forces of my excellent kickarse driving skills created to much freeplay and so the pin was not engaging all the way in the block making it strip it....I will double check the diff I have in there now before next meeting and then see how it goes.
Hopefully see you at brendale friday week. You going to be ready with yoru MTX4.
Old 06-07-2007, 06:08 AM   #14
stevenc's Avatar
Thanks Roy I am going to head to the LHS tomorrow for the offchance they may have something similar , I might have found out why my front locked diff has been failing but I still want some grease for the rear at least.
Old 06-07-2007, 06:09 AM   #15
stevenc's Avatar
I was thinking super crunchy might be not a bad option when gears get worn a little.
FS: Kyosho Diff Fluid Lot ridgewaybodies R/C Items: For Sale/Trade 2 06-04-2007 09:55 AM
kyosho 777 STR diff shimming TENCHO Electric Off-Road 2 10-30-2006 09:16 AM
KYOSHO TCD DIFF GEARS ***************************** mach51 R/C Items: For Sale/Trade 7 10-16-2006 07:13 AM
Diff Problem On The Kyosho Mp 777 RBCHOCO Electric Off-Road 4 12-10-2004 09:58 AM
F/S NIP! Kyosho Front Diff V-One RR Evo Formula1fan R/C Items: For Sale/Trade 1 11-09-2004 12:53 PM
