Old 03-07-2002, 04:14 PM   #1381
Send a message via AIM to VinDollar Send a message via Yahoo to VinDollar
Default online instructions
Here's a copy of the manual in PDF format
http://www.jasonjenkins.com/mtx2/dow...structions.pdf
VinDollar is offline   Reply With Quote
Old 03-07-2002, 07:40 PM   #1382
carpet_killa's Avatar
? on kawahara pullies
i am wanting to change thepullies out on my mtx-2 pro spec ,but there are different sizes and i am tring to figure out what pullies are on my stock. 18t , 19t, 24t. ect. does any body know or can explain to me what pullies to get. thanks
carpet_killa is offline   Reply With Quote
Old 03-07-2002, 09:03 PM   #1383
Default Re: ? on kawahara pullies
All three sizes are on the car stock. The the two on the mid block shaft are 18t and 24, and the one on the 2 speed shaft is a 19
Old 03-08-2002, 01:14 AM   #1384
Manbik's Avatar
Mugen announces a new tool line called ProSpec. Check my site or theirs for details.
-Jason
Manbik is offline   Reply With Quote
Old 03-08-2002, 02:46 AM   #1385
Originally posted by VinDollar
Thanks Sydewynder
I will check those situation out. I was begining to get a little fustrated with this car but what can i expect with some many changes at once. Is it possible to have a tweakin the chassis when it's new? How would that take place?
I need to clarify something. When I said chassis tweak, it doesn't always mean the chassis is bent. Sometimes it does but left and right shocks on one end of the car that are not built exactly the same or the weight in one corner of the car that is heavier/lighter and you can get "chassis tweak". You can see this when you do the lift test or use a tweak station. Sorry for the confusion. Your chassis could be perfectly straight but still show some chassis tweak.
To answer your question, yes you can. If the chassis is stamped the tweak or slight bend can be put in during the stamping process.
Sydewynder is offline   Reply With Quote
Old 03-08-2002, 10:40 PM   #1386
Default Mugen Oils and Greases
Do you use Mugen oil on your Air Filters? I have no other brands to compare to but it doesn't seem overly 'sticky'? The part # is B0302. And does anyone know what the empty bottle is for?!
How often are you supposed to re oil, or just with new filters? Thanks!
SHARP is offline   Reply With Quote
Old 03-10-2002, 06:27 AM   #1387
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Default Re: Mugen Oils and Greases
Since no one has answered....
Air filter oil is supposed to be 'sticky'. I use Air Filter oil made for Motor cross bikes, that stuff is sticky.
Don't apply too much grease (unless u run on a dirty track). Im pretty sure the empty bottle is to dip the airfilter into - ie soak it. I re-oil mine everytime I clean the filter.
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 03-10-2002, 06:30 AM   #1388
Michael_T's Avatar
Since you guys are on the the topic of upgraded chassis, here is another by hardcore (bloody expensive!!!)
Old 03-10-2002, 09:30 PM   #1389
Default Bodies
What body do you guys run. Just curious what bodies everyone likes on the mtx-2 and why? What characteristic from the body you run gives you that tq advantage??
Old 03-10-2002, 10:58 PM   #1390
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
Default Re: Bodies
I am currently using HPI Mercedes CLK GTR body, I used the following bodies before and I like the CLK GTR the most because it gives me really really good overall downforce, especially the front end. Initial turn in respond is fast.
BMW M3GT this one is pretty good but front end respond is not as good as CLK GTR.
CLK DTM this one has good front end respond compare with M3GT but still not as good as GTR.
S-Class, P.O.S. body but it looks good.
If I had to rank them then it would be 1. CLK GTR, 2. M3GT, 3. CLK DTM.
Ah10 is offline   Reply With Quote
Old 03-11-2002, 02:04 AM   #1391
FREAKAH's Avatar
Currently I use the HPI Mercedes CLK GTR................BUT my favorite body by far is the HPI Honda Prelude. IMHO it's better than the Merc CLK GTR in all aspects especially in the steering department.
Another good one is the HPI Merc CLK DTM 2000. Neutral handling and "DTM Racer" good looks.
FREAKAH is offline   Reply With Quote
Old 03-11-2002, 02:41 AM   #1392
RAP66's Avatar
I like the Stratus... I personally have not been able to tell the differences between the makes (proline, hpi... ) For me it has good steering and neutral handling feel...
I want to try a different body, soon... has anybody had good results with the skyline??
Rich
Rich Pedro
[email protected]
www.rcracing.com
RAP66 is offline   Reply With Quote
Old 03-11-2002, 03:21 AM   #1393
Default Re: Re: Mugen Oils and Greases
Thanks NR A filter would not fit into the empty bottle though so I am still stumped!
Old 03-11-2002, 03:33 AM   #1394
Manticore's Avatar
Default Re: Re: Re: Mugen Oils and Greases
treat this empty bottle as buy one get one free !!
you dont need to soak the foam with filter fuild, just apply the filter oil onto the foam and make sure you will not over do it. remove excessive oil with tissue and make sure no excessive filter oil running around.
Manticore is offline   Reply With Quote
Old 03-11-2002, 05:29 AM   #1395
Default Re: Re: Re: Re: Mugen Oils and Greases
Thanks Manticore. I have no problem with applying the oil I just didn't know for what was the second bottle!
Free Plastic Bottle!
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
