Old 02-26-2002, 10:50 PM   #1336
hurhur's Avatar
how does the compound of inserts affect the handling of a car using rubbers?
hurhur is offline   Reply With Quote
Old 02-28-2002, 09:16 PM   #1337
carpet_killa's Avatar
Default ? on the mtx-2 pro spec kits
i have a mtx-2 pro spec kit and i am woundering . the pipe that came in my kit is a (REX) pipe. is this pipe the same thing as a novarossi pipe or did i jut get a throw in the kit junk pipe? did you other guy's that have a pro spec get the same thing or what did you get. thanks ! cause i know i have seen rex name on some carbs before, so i am just woundering !
carpet_killa is offline   Reply With Quote
Old 02-28-2002, 09:40 PM   #1338
Send a message via AIM to VinDollar Send a message via Yahoo to VinDollar
The Rex pipe comes with the pro spec. The Rex pipe is a good pipe and i think it's the same as the 51602. Rex, novarossi, and the rb pipes are all the same.. They all made by novarossi.
VinDollar is offline   Reply With Quote
Old 02-28-2002, 09:45 PM   #1339
Default RE:
ok, i am just woundering cause i was thinking that there is a novarossi pipe on the car on ever mtx2 kit and see REX pipe in my kit ,and i am like . what is this! so thats cool i understand now . rex makes more than just carbs and such.
Old 03-01-2002, 06:37 PM   #1340
To Sydewynder:
Thanks for the great tips on the kawahara 2 speed. 3 1/2 turns out on the clutch is dead on. I just rebuilt my car with all possible kawahara hop ups. I had the itch, and went all the way.
To ah10:
Thanks for the great tips on the negative diff. I have a question about the diff though. How do u know if the clutch in the unit is engaging?? What type of characteristic should the car exihbit. I just ran it for a minute. There's no track time in my immediate future since weather sucks here aside from a couple of 60 degree days recently.
Old 03-01-2002, 10:32 PM   #1341
You're welcome VinDollar. Glad it worked out for you.
Sydewynder is offline   Reply With Quote
Old 03-01-2002, 11:44 PM   #1342
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
Originally posted by VinDollar
To ah10:
You are very welcome! now if you set up your neg diff correctly then the diff action should be really really smooth and loose kind of like putting 5k weight or less in there, usually with such light weight oil in rear diff and then when you punch the car out of corner it will probably spun around due to excessive power to only one side on the rear tire. Now if you punch your car out of corner and it shoot straight then that means the clutch engage becomes solid axle. Also on the straight away it is much more stable.
Ah10 is offline   Reply With Quote
Old 03-02-2002, 02:28 PM   #1343
RAP66's Avatar
Default MUgen Spring Rates
HAs anyone gone through and figured out what the Mugen Spring rates are??
I have Associated Yellows (30#) and they are supposed to be similar to the kit silvers.
If anyone knows the equivelant rates (in pounds) please post.
Rich
Rich Pedro
[email protected]
www.rcracing.com
RAP66 is offline   Reply With Quote
Old 03-02-2002, 02:50 PM   #1344
Default mtx2 springs
also why is there 2 different lengths in springs for the mtx-2 ? can you not use the same length in front and back.?
Old 03-02-2002, 06:55 PM   #1345
ernestf's Avatar
Send a message via ICQ to ernestf
Default Re: mtx2 springs
due to the shock length, u should use short spring in front and long spring in rear. i run mtx2 with foam, i use short spring all around.
ernestf is offline   Reply With Quote
Old 03-02-2002, 07:41 PM   #1346
What is the color code for shocks?
~ Brandon
LiLRCLoUiE is offline   Reply With Quote
Old 03-02-2002, 07:52 PM   #1347
ernestf's Avatar
~ Brandon
from soft to hard (for front - short spring)
purple-blue - gray - white
from soft to hard (for rear - long spring)
purple-blue - gray - white - pink - red
Old 03-02-2002, 07:58 PM   #1348
What is the best combo, for good speed on like a little but rocky not much?
~Brandon
Old 03-02-2002, 08:11 PM   #1349
ernestf's Avatar
i dont really know, i am not a fast guy tho.
i use front one-way + rear diff (5,000wt)
shock oil 600wt plus blue spring (short) all around.
rear 2 degree toe-in, front 1 degree toe-out.
this is setting for foam tires.
Old 03-02-2002, 08:13 PM   #1350
Do you use a lola body like in your pic?
~Brandon
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
