Old 02-20-2002, 10:03 AM   #1291
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
Originally posted by dtm
In terms of car specs the VoneRR and MTX2 Pro spec are both very comparable! Really depends on the spares availability as to which car you should buy!
Totally agree! didnt matter which car, VoneR, MTX-2, NTC3 or impluse but the most important thing is REPLACEMENT PARTS.
It wont be a good car if you can take it on the track due to lack of replacement parts!
Ah10 is offline   Reply With Quote
Old 02-20-2002, 02:52 PM   #1292
psycho's Avatar
Sydewynder
Are you racing electric at Castle this weekend? We'll be racing F1!
psycho is offline   Reply With Quote
Old 02-20-2002, 10:57 PM   #1293
Originally posted by psycho
Sydewynder
Nah waiting on the F201.
Sydewynder is offline   Reply With Quote
Old 02-20-2002, 11:22 PM   #1294
carpet_killa's Avatar
Default ? FOR US MTX2 OWNERS
do you all use the mugen shocks that come in the kit or use some other kits shocks ? the reason i am askin is cause of the 2 different size springs on the mtx2 , if so what is the best thing to do? also what important need to get hop up parts should i get.thanks
carpet_killa is offline   Reply With Quote
Old 02-20-2002, 11:35 PM   #1295
Default Re: ? FOR US MTX2 OWNERS
Using the Mugen shocks. The long ones in the back. The short ones in the front.
Needed hop ups? For me, I'd say side belt tensioner, front universals and centax clutch..
Old 02-21-2002, 04:48 AM   #1296
stefan's Avatar
Send a message via AIM to stefan
one of the best shock designs in the business in my book.
self-bleeding, what more could you want?
stefan is offline   Reply With Quote
Old 02-21-2002, 05:40 AM   #1297
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
I wonder how different the MRX-3 shocks are - they look different on the outside, I wonder if they are any better?
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 02-21-2002, 06:42 AM   #1298
Stefan - I agree totally!
wilsonproperties1.com
Isaac is offline   Reply With Quote
Old 02-21-2002, 10:10 AM   #1299
Send a message via AIM to VinDollar Send a message via Yahoo to VinDollar
Default Pulley sizes
What are the stock pulley sizes for the mid block and 2 speed shaft. i know the on that goes to the front belt is a 18 tooth. Whats the others???
VinDollar is offline   Reply With Quote
Old 02-21-2002, 02:17 PM   #1300
Default ? on 2 speed clutch
i got a ? do you all use the stock 2 speed clutch on the mtx2 or did you buy the kawahara 2 speed?
Old 02-23-2002, 07:48 AM   #1301
Default ? on 2 speed clutch/NEGATIVE DIFF ?
Carpet killa:
I switch to a kawahara 2 speed because i hear on this board and from some friends that the stock 2 speed is inconsistant when used with a modified engine. I ordered a Richey mt-12 9 port eagle so i though just to upgrade just in case. The stock was fine with my non-turbo mt-12 though.
TO ALL THAT HAS THE KAWAHARA NEGATIVE DIFF:
I just purchase this diff and wanted to know what diff rate to use in it. I'm a little confused to what it should be or should i run what is recomended stock for the car. I have the front one way also.
Old 02-23-2002, 11:47 AM   #1302
Ah10's Avatar
Default Re: ? on 2 speed clutch/NEGATIVE DIFF ?
Originally posted by VinDollar
Carpet killa:
I am running my Negative Diff myself and I have it since last june. Now here is how I did to my diff.
1. please dont use the white nylon bushing for the bevel gear shaft, it is too thick and make the gear meshing too tight. Use the one from stock, the thin shinny color washer. it will give you much better gear meshing.
2. I am using Racer's Choice Hyspin Lube as diff oil. I found out using regular sillicon base diff oil will be very hard on those small diff gears(I am not the only one saying this so that means I am not bullshitting.) If you are going to use such lube as I mentioned, first you want to lightly coat all the bevel gear with the lube(not too much just enough) then close the housing back. be carefull when you close it and torque it down with the proper way, 1, 3, 2, 4 sequence, since the diff housing is Aluminum, it will warped, so handle it with care . Then after may be like 5 tanks or so open the diff up again, you should see all the lube will kind of lightly covered all the gears and the rest got spin to the side of the housing then add alittle bit more of those lube and close it up, Bam you have a perfect Negative Diff.
After the relube, I havent opened up my diff since and it was like 6 months ago and it still feel the same as it was back then!
Oh the diff action should be very very smooth without anything binding, It's kind of feel like using regular 5k weight oil (or may be less). And this is what you want because once it spins up fast enough it will become a solid axle so you want your diff to be as smooth and loose as possible to gain advantages of the Negative Diff!
Hope this help!
Old 02-23-2002, 05:41 PM   #1303
Thanks for the info... I'm going to get this in tonight and i wanted it to be perfect. Where do u get this hyspin lube from???
Old 02-23-2002, 06:45 PM   #1304
Ah10's Avatar
A friend of my got it for my in Hong Kong! Check with Tower Hobby they carry Racer Choice stuff but I am not sure if they have the same lube I have been using!
By the way the lube that I am using is Racer's Choice Hyspin Lube #7016.
Old 02-23-2002, 11:17 PM   #1305
I search the net and couldn't find anywhere that sells the hyspin lube. Some site claim that it is discountinued.. Do u know of something that is equivelent??? Thanks.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
