Old 02-10-2002, 09:27 PM   #1246
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Don't you guys like this pipe :
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 02-11-2002, 10:35 AM   #1247
psycho's Avatar
I run the X15 turbo inline. It's awesome on the MT12 engine.
psycho is offline   Reply With Quote
Old 02-11-2002, 11:50 AM   #1248
Hey guys just wanted to say thanks for alot of the suggestions about stiffining the rear of the mtx. I ran my first race yesterday at crsytal park, and even though i was in the C main, I did come in 4th, which I don't think is too bad considering it was my first race. Again thanks alot guys.
AH10
Don't know if you made it Sun, but if you did I was the only one running a BMW body, while the rest of the field had stratus body.
Prometheous is offline   Reply With Quote
Old 02-11-2002, 12:13 PM   #1249
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
AH10
Sorry man, I didnt go on Sunday, instead we went on Saturday! hey you got PM
Ah10 is offline   Reply With Quote
Old 02-11-2002, 09:39 PM   #1250
I would like to know if the Kawahara two speed clutch is worth the money over the stock type clutch? What are the benefits of this type of clutch? Also, I remember somebody had a web site showing exactly how to setup a centax clutch, does anybody know the link to this site?
Thanks,
crowmaxx is offline   Reply With Quote
Old 02-11-2002, 10:20 PM   #1251
dtm
dtm's Avatar
Send a message via ICQ to dtm
The shoe type 2 speed clutch will provide a smoother gear change over the finger type. You may find that the car 'jerks' when the finger type changes speed, this will be gone with the shoe type clutch. It's your call as to whether the extra money is worth it to get rid of this feature of the finger type clutch!
dtm is offline   Reply With Quote
Old 02-11-2002, 10:33 PM   #1252
carpet_killa's Avatar
Default how to build the centax clutch?
i am woundering is there a fine detailed explanation of building the mtx2 centax clutch in the pro spec kit ., and some kit building tips for me? thanks alot guys.chris
carpet_killa is offline   Reply With Quote
Old 02-11-2002, 11:59 PM   #1253
dtm
dtm's Avatar
If you ignore the bit about the flywheel weights (which are different on the Mugen clutch), the instructions for the HPI Proceed Centax is fairly clear. It will bring you within the ballpark setting.
http://www.hpiracing.com/graphics/in...c/proc-clu.jpg
Old 02-12-2002, 03:47 PM   #1254
[QUOTE]Originally posted by crowmaxx
[B]I would like to know if the Kawahara two speed clutch is worth the money over the stock type clutch? What are the benefits of this type of clutch? Also, I remember somebody had a web site showing exactly how to setup a centax clutch, does anybody know the link to this site?
crowmaxx: I run the Kawahara 2 spd clutch in both Mugen
Lolas that I race...in my case I was satisfied with the stock
finger type 2spd clutch until I switched over from stock MT-12
and RB X12 engines to Richey modified engines. Then the
shifting became inconsistent because his engines rev very
quickly. My recommendation is that if you are not having
any problems with the stock MTX-2 2 spd finger type shifter,
then stick with it and don't waste your money...they are
extremely sturdy and reliable. On the otherhand, the
Kawahara clutch type 2 speed shifter solved my problems
and is of excellent quality.
Mike Queller of Speedline Racing fame: www.speedline-rc.com
has a technical section on setting up the centax type clutches.
jd300zxtt is offline   Reply With Quote
Old 02-12-2002, 04:50 PM   #1255
Default ? on turbo glo plug in the mt12 turbo
i am tring to find out what brand of turbo glo plug is in the mt12 turbo engine, and where can i get replacements. the one in my engine has a # 5 on it but i don't know if it is hot or cold plug . but the engine is new and i am wanting to get some extras. thanks for the help.
Old 02-12-2002, 05:03 PM   #1256
Directly from the Novarosi site:
Turbo Plugs
HOT
C.5TC Turbo glowplug hot
C.6TC Turbo glowplug hot
C.7TC Turbo glowplug hot
C.8TC Turbo glowplug hot
COLD
C.5TF Turbo glowplug cold
C.6TF Turbo glowplug cold
C.7TF Turbo glowplug cold
C.8TF Turbo glowplug cold
Technical specifications of turbo glowplugs
Turbo glowplug was conceived to give to the engine higher performance and it is available in 8 versions: 4 hot and 4 cold.You find here with a description schedule that gives to the drivers the possibility to choose the suitable glowplug according to the situation he is operating.
Type Features Nitro % Increas Perf Outside temp
C.5 TC Hot w/ hot filament 10-20% + 10% from 5° to 10°
C.6 TC Hot w/ avgfilament 10-20% + 8% from 5°to 20°
C.7 TC Hot w/ coldfilament 20-30% + 6% More than 20°
C.8 TC Hot w/verycold filament 20-30% + 5% More than 20°
C.5 TF Cold w/ hotfilament 20-30% + 15% from 10° to 20°
C.6 TF Cold w/ avgfilament 20-30% + 13% More than 20°
C.7 TF Cold w/cold filament More than20% + 12% More than 20°
C.8 TF Cold w/verycold filament More than 20% + 10% More than
30
Merits and failings of turbo glowplugs
Hot glowplug guarantees a better adjusting of the engine at low RPM while the cold glowplug gives a better performance at high RPM. If you have a cold glowplug on your engine and have difficultes to keep it regular at low RPM, we advise you to make the base speed a little higher. In case the engine goes out again, we advise you to replace the above mentioned glowplug with a cold one; these difficulties in the carburation aren't due to a bad running-in of the engine but to anomalous climatic and meteorological conditions (see high degree of humidity, altitude, low pressure, etc...).
Important
During the installation of a turbo glowplug on the under head verify that no dust or any other material come inside because they could make precarious the seal of this glowplug during the compression.
tekrsq is offline   Reply With Quote
Old 02-12-2002, 05:11 PM   #1257
Default re:
so what do you all use hot or cold plugs? for racing. and tuning.
i have a mugen/novarossi MT12 turbo engine and the plug in it is a # 5 . but i am not sure if it is a hot or cold plug that comes in it from the factory. so i am needing replacements for my engine and i have tried contacing mugen but no reply. so i run it in temps from 40-70 degrees from fall untill spring then the temp ranges 70-90 summer and i am using 20% nitro. can you help me out on the plugs to run and the part# for those plugs to order.ok thanks alot ,chris
Old 02-13-2002, 01:59 PM   #1258
Default Re: re:
[QUOTE]Originally posted by carpet_killa
[B]so what do you all use hot or cold plugs? for racing. and tuning.
carpet_killa: The MT12 Turbo engine comes with the C5TC hot
plug...the difference between the C5Tc and the C5Tf (cold plug)
is the thickness of the wall around the glow element...thin wall
is hot, thick wall is cold. For colder temps, run the hotter plug.
If temps get above 90F, you may try either a colder range:
i.e. C6 or the C5Tf. With 20% nitro, I think you will be fine with
the stock C5Tc. I have raced the MT12 Turbo with both 30%
and 40% nitro with the stock .3 mm head shim...30% for the
large 1/8 type tracks and 40% for small parking lot tracks and
was able to use the C5Tc glow plug in 60-70F weather.
As for turbo plug availablility...Ace Hardware Hobbies always
has plenty of all ranges in stock.
Old 02-15-2002, 02:01 AM   #1259
Default rear camber link
any tips on what parts to use for an adjustable rear camber link?
PeterAiea is offline   Reply With Quote
Old 02-15-2002, 05:56 AM   #1260
Michael_T's Avatar
Here ya go boyz :
Quick change front axles
http://www.radiocontrol.gr/images/nurnberg133.JPG
Mugen tools
http://www.radiocontrol.gr/images/nurnberg135.JPG
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
