Old 02-02-2002, 08:02 PM   #1156
raffaelli's Avatar
well, that great but....
has anyone tried the stiff spring?
raffaelli is offline   Reply With Quote
Old 02-02-2002, 08:05 PM   #1157
Manticore's Avatar
R/C Tech Charter Subscriber
i am using the grey shoes n lightened weight. it is great. great acceleration. i might try on the heavy spring later on.
Manticore is offline   Reply With Quote
Old 02-02-2002, 08:07 PM   #1158
raffaelli's Avatar
thanks. i have a hard time telling the difference between the grey black and this other brownish one. do you have part numbers for what you use?
Old 02-02-2002, 08:17 PM   #1159
Manticore's Avatar
i dont !!
Old 02-03-2002, 06:30 AM   #1160
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
I've run the stiffer spring for a while with my old Axial clutch.
I now run the stock spring on the new pro, with both the Gray clutch shoe (H0765) and lightweight flys (H0766). This combo gives more then enough punch. Using the stiffer spring with the above combo would make the clutch engage way too hard and possible make handling worse.
The lightweight flyweights will make the clutch engage/disengage slightly quicker and the gray shoes are softer then the stock shoes which will allow you to set the clutch higher and will slip alot less then the standard shoe.
Just don't forget that adding/removing shims will also make the clutch engage harder/softer and not enough shims will result in early thrust bearing failure.
NR signing off
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 02-03-2002, 07:19 PM   #1161
Manticore's Avatar
NR signing off
That is what I think.
Old 02-03-2002, 09:17 PM   #1162
Ah10's Avatar
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
Had a great run today at Crystal Park! Here is my setting for today:
Front:
Camber: 2 degree
Toe out: 1 1/2 degree
Caster: 8 degree
Ride Height: 4 1/2mm
Spring: Mugen Grey(1.8)
Shock Piston: 2 holes
Shock Oil: 60wt
Front Sway Bar: Softest setting (flat)
Rear:
Camber: 2 1/2 degree
Toe In: 2 degree
Ride Height: 5 1/2mm
Spring: Mugen Light Blue(1.7)
Shock Oil: 60wt
Rear Sway Bar: Softest setting
Tires: 26mm Ellegi 40sh front
32mm 45sh Yokomo L compound (L32H)
Engine: RB X12T 5 ports, RB exhaust manifold, X12 pipe.
Front Oneway, Rear Negative Diff, Tech mid oneway.
Shell: HPI Mercedes CLK GTR.
Man, with this set up the car handles like it's on rail, fast sweeper, tight corners, it is just perfect!
Ah10 is offline   Reply With Quote
Old 02-04-2002, 01:06 AM   #1163
FREAKAH's Avatar
AH10, what diff oils were you using?
And what is that "Tech Mid" oneway?
Also, are you still using that parallel rear camber link set-up? If not, what positions are you using now?
Thanks!
FREAKAH is offline   Reply With Quote
Old 02-04-2002, 06:43 AM   #1164
dtm
dtm's Avatar
Send a message via ICQ to dtm
It works out that this was the combination that I was running on my RS this weekend; Kawa small flywheel, hard spring, lightened weights, and grey clutch shoes (didn't even know I had these). Anyway... had difficulty getting a smooth engagement with 0.5mm on the spring and 0.4mm on the bell housing.... will be trying 'almost flush' on the spring and 0.4mm on bell housing next week.... maybe!!
dtm is offline   Reply With Quote
Old 02-04-2002, 06:44 AM   #1165
dtm
dtm's Avatar
A mid one way bearing/pulley for the end of the front long belt made by Tech Racing!!! Works very well!!!
Old 02-04-2002, 07:10 AM   #1166
Ok, so what's the purpose of it? If you've got a one-way front diff, how does putting in a one way center "diff" make things better? To me, it seems like it make the car impossible to slow down.
tekrsq is offline   Reply With Quote
Old 02-04-2002, 07:46 AM   #1167
dtm
dtm's Avatar
When you let go on the gas with just a front one-way; all the friction on the three belts will be acting on the rear axle to brake it. With the centre or mid one way you lose the friction on the front belt leaving less friction to slow down the rear/car! This will lead to slightly faster entry speed into the corner and less tendancy for the back end to step out. The effect is similar to mid one ways on EP but the effect is less drastic because you do not have motor braking with GP.
Old 02-04-2002, 07:48 AM   #1168
dtm
dtm's Avatar
I do not know the exact effect of just a front one way on GP because I have always had full time 4WD or dual one ways on GP. What I have put below is based on my EP experience!
Old 02-04-2002, 08:04 AM   #1169
Manticore's Avatar
if you want smooth engagement, you need the stock shoe. It will reduce the punch that the grey shoe provides.
Old 02-04-2002, 08:10 AM   #1170
dtm
dtm's Avatar
I didn't even realise it was the grey shoes I bought until you mentioned it at PYC and I compared the two when I got home!!!!
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
