Old 01-29-2002, 05:35 PM   #1141
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: Servo type question
Originally posted by click, dublin
Hi Guys,
I had the MTX-2 out on my local track on Sunday dialling in the Centax clutch.
It had been raining during the day & a few puddles had formed.
I managed to avoid them for a while then splosh, high five, wipe out.
No response from my electrics!
Packed up & went home.
Stripped the car & let the electrics dry out.
Receiver was OK, but both servo's were fried!
I had thought of getting some digi servo's but at approx. $100 dollers each the above experience has turned me right off.
I only use cheap nasty servo's, Futaba S3003's.
In the case above does anybody think a digi servo would have survived? are they more watertight/robust?
Our weather in Ireland is very damp & wet, not good for electrics.
Any thoughts?
Click, Dublin
you can use silicon sealant to seal your servo to make it water tight. there are water proof spray for circuit board, which you can spray directly to your receiver circuit broad or you can use balloon and tie wrap to seal your receiver.
Manticore is offline   Reply With Quote
Old 01-29-2002, 09:37 PM   #1142
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Hi Guys,
Any thoughts?
Click, Dublin
Dude trust me - upgrade the 3003s. They simply do not have another torque or speed to turn the wheels at high speeds.
Invest in some high speed digital servos and stay away from those puddles
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 02-01-2002, 09:02 PM   #1143
carpet_killa's Avatar
Default mtx2 pro spec VS. gt4 pro
hey guys , i am in a serious delima on these 2 cars . i am wanting to know in your all's serious opinion which one will i be more happy with for over all handling, quality of parts and company tech support and all of the other serious racing isssues. i appreciate the info on this matter. thanks ,chris
carpet_killa is offline   Reply With Quote
Old 02-01-2002, 10:10 PM   #1144
Regional Moderator
kansasracer's Avatar
I have been racing the Mugen for awhile, I like it alot. But, I would go with the one that your hobby store has better access to parts...
The Mugen is a great car, but I am sure that the Yok is a good car also. I have never owned a Yol so I can't comment on any of their products. This is my first Mugen (had an HPI before) and it is much better than previous gas cars I have owned.
kansasracer is offline   Reply With Quote
Old 02-01-2002, 10:41 PM   #1145
Default re : mtx2 pro spec vs. gt4 pro
my hobby shop is stocking both. but the people there are not that on top of the racing side of it and they just are stuck on the tc3 elect.
Old 02-01-2002, 11:13 PM   #1146
Ah10's Avatar
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
Default Re: re : mtx2 pro spec vs. gt4 pro
Have you seen a GT4's front suspension arm compare with MTX2? I have seen one and they look wimpy! and one of the parts supplier told me he has been selling a lot of GT4 front suspension arm,(A-arm). And besides, Pro-Spec comes with Centex Clutch, front oneway and a bunch of good stuff to go with it!
So you know my answer already!
Ah10 is offline   Reply With Quote
Old 02-02-2002, 12:26 AM   #1147
both are very good car.... but you want the one that will let you finish a race.... haha
agree, everyone?
ME-student is offline   Reply With Quote
Old 02-02-2002, 12:30 AM   #1148
Regional Moderator
I agree with AH 10, I have hit ALOT with this car and it is very durable, much more than any car I have ever owned. PLus, you get the best engine out there if you buy it with the Mugen engine...
Old 02-02-2002, 08:08 AM   #1149
raffaelli's Avatar
what clutch spring comes with the pro?
raffaelli is offline   Reply With Quote
Old 02-02-2002, 10:44 AM   #1150
Ah10's Avatar
Are you referring to the spings on a regular 3 shoe clutch? if you are then the answer is it doesnt come with any because it's running Centex Clutch.
If you are asking the coil spring inside the centex then the spring is exactly the same as MRX2.
Old 02-02-2002, 12:34 PM   #1151
raffaelli's Avatar
ah10, i realize what clutch comes with the car. thannks for the info,
Old 02-02-2002, 03:10 PM   #1152
Chris, I do not know this to be fact because I haven't seen one yet, but I've been told the Centax on the pro kit comes with the standard spring and shoes, and the new "racing clutch set" comes with the heavy duty spring and light weight shoes. If you can track down Robbie Collins, I guess he would be the best person to confirm this.
While we're at it, has anyone tried the heavy duty spring and lightweight shoes on the MTX-2? I'm wondering if our .12s have enough power to make use of those parts noticeable and beneficial.
tekrsq is offline   Reply With Quote
Old 02-02-2002, 03:42 PM   #1153
raffaelli's Avatar
Tom, That is where I was heading. I was going to try to figure out if the .12 has enough for the harder spring. I have a bunch of them from my MRX3 and thought about giving it a try. Dennis' MT12 RTU was just dropped at my door. I am going to run it in in the morning.
Old 02-02-2002, 04:49 PM   #1154
Manbik's Avatar
Robbie does not know that much about the new Racing Clutch either. He has said that sometime the communication isn't what is should be between Mugen Japan and Mugen USA.
We beleive though that the new clutch comes with the lightened weights, Heavier spring and the Gray clutch shoe.
-Jason
http://www.jasonjenkins.com
Manbik is offline   Reply With Quote
Old 02-02-2002, 07:57 PM   #1155
Manticore's Avatar
this is what the alta vista translation master said
The pinion gear (selling separately) it has not belonged to this racing * clutch set. Adjusting to each chassis, please select. The D0603 thrust bearing /C0603 clutch bearing has belonged. The clutch spring hard / clutch shoe of option (Gray) / spreads width of set with such as ~Ǣǣ~Ǩ shoe.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
