Old 01-21-2002, 11:26 PM   #1126
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
Hi guys! just want to let you all know I had a great day today! it was a blast!
Ran at Crystal Park today, and finally got rid of the front push. It was probably because of the body I was running didnt have enough down force at the front! I switch back to my first body that I had long time ago! Mecerdes CLK GTR, Man it handles like it's on rail, I mean it's ON RAIL.
Setting I have today is:
Light Blue Springs, 60WT oil, 2 holes piston all around.
Elligi 40sh 26mm Front
Yokomo L32H Rear (I dont know what shore that is but someone mention that's 48sh), it sounds kind of a weired combination since most ppl run harder front and softer rear but the car was hooking so good today!
Front and rear sway bar
front toe out 1 degree
front camber 2 degree
front caster 8 degree
rear camber 2 1/2 degree
rear toe in 2 degree
Any question or suggestion welcome!
Ah10 is offline   Reply With Quote
Old 01-22-2002, 08:21 PM   #1127
FREAKAH's Avatar
That's funny, my rubber tire setup also goes against the norm by using softer front springs than the rear.
Here's my rubber tire set up for a small med. bite track:
FRONT:
60w, stock pistons, Mugen kit rear silvers springs
1.5 deg camber, all upper arm spacers in front.
Yokomo 138GH2 tires
5000w diff oil
0 deg. toe
No sway bar
REAR:
60w, stock pistons, Mugen blue rears.
1.5 deg camber, camber link mounted on lower inner hole on shock tower and upper outer hole on hub.
Yokomo 138GH2 tires
5000w diff oil with two O-rings removed from small gears(two only).
2.5 deg toe
No sway bar
FREAKAH is offline   Reply With Quote
Old 01-22-2002, 10:02 PM   #1128
Ah10's Avatar
FRONT:
Yokomo 138GH2 tires
5000w diff oil
0 deg. toe
No sway bar
REAR:
Yokomo 138GH2 tires
2.5 deg toe
No sway bar
With all the spacers towards the front you probably have great on power steering right?
I am going to try out grey front spring with light blue rear springs!
Old 01-23-2002, 03:30 AM   #1129
Default Slop
Question for long time owners: How often do you change A-arms? Do you change when the slop starts to show and how long does this take to happen? Do you just replace the parts or try to shim it up? And do you consider this slop when adjusting the car?
SHARP is offline   Reply With Quote
Old 01-23-2002, 01:42 PM   #1130
Ah10's Avatar
Default Re: Slop
I never replaced any of the front a-arm, lucky enough never broke one, but I had replaced afew rear lower a-arm, I cliped the board once and the other times were sent to the board by other racers!
Old 01-23-2002, 03:08 PM   #1131
got_speed?'s Avatar
Default Re: Re: Slop
you got_mail
got_speed? is offline   Reply With Quote
Old 01-23-2002, 04:33 PM   #1132
raffaelli's Avatar
Anybody race at Hobby Central in San Diego? What is a good setup?
raffaelli is offline   Reply With Quote
Old 01-23-2002, 06:01 PM   #1133
Motorman's Avatar
Hey Raf
dennis, hook up with Chris F up LA way He hangs on HPI's site fron time to time. He is a good guy and can direct you to tracks down that way. They have been running crystal park alot and its not to much of a drive from Diego. I'm not sure how much is actually going on in diego itself.
Do a search on his name and split him an Email
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 01-23-2002, 10:45 PM   #1134
SpeedTech's Avatar
Hi Guys,
we got a few new items from Mugen: Centax adjustment tool and also the pinion tool. We also have the light weight titanium pillow balls in stock (packs of 8).
We will also have Kawahara hop-ups back in stock this week, as well as some new goodies from Kawahara next week.
Steve Wang
Speed Tech R/C
www.speedtechrc.com
SpeedTech is offline   Reply With Quote
Old 01-28-2002, 12:20 AM   #1135
Default shredded rear belt
anybody else have a problem with the rear belt getting scored? . I've just started breaking in the car and notice now that a 1mm strip on the right side of the belt has been scraped off, I think by the tip of the screw SKA3x12holding on the bottom brake stop T01048. I just used the cutoff wheel to shorten the screw a bit.
PeterAiea is offline   Reply With Quote
Old 01-28-2002, 12:58 AM   #1136
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Default Re: shredded rear belt
Originally posted by PeterAiea
anybody else have a problem with the rear belt getting scored? . I've just started breaking in the car and notice now that a 1mm strip on the right side of the belt has been scraped off, I think by that screw. I just used the cutoff wheel to shorten the screw a bit. Guess I'll need a new belt. I think it's from the tip of the SKA3x12 screw holding on the bottom brake stop (T0104B) - see step 20. Maybe somehow I'm using the wrong screw?
I've owned the car for nearly 2 years and never needed to replace the rear belt. Might want to double check you have assembled it correctly
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 01-28-2002, 02:04 AM   #1137
Default belt problem
Must be. I've got the rear unit apart to find a construction problem. Thanks for the info.
Old 01-28-2002, 11:01 PM   #1138
Default belt problem - rock
As an afterward to this, I went down to the LHS on my lunch hour to buy a belt and asked the owner Bobby, and Marvin another racer who happend to be there, what they thought. They look at each other, Bobby sez one word, "rock". Marvin: "yeah, rock"
Old 01-29-2002, 02:01 PM   #1139
Default Servo type question
Hi Guys,
I had the MTX-2 out on my local track on Sunday dialling in the Centax clutch.
It had been raining during the day & a few puddles had formed.
I managed to avoid them for a while then splosh, high five, wipe out.
No response from my electrics!
Packed up & went home.
Stripped the car & let the electrics dry out.
Receiver was OK, but both servo's were fried!
I had thought of getting some digi servo's but at approx. $100 dollers each the above experience has turned me right off.
I only use cheap nasty servo's, Futaba S3003's.
In the case above does anybody think a digi servo would have survived? are they more watertight/robust?
Our weather in Ireland is very damp & wet, not good for electrics.
Any thoughts?
Click, Dublin
click, dublin is offline   Reply With Quote
Old 01-29-2002, 02:19 PM   #1140
Hi Guys,
Any thoughts?
Click, Dublin
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
